2.7 tacoma problems
Old Aug 5, 2008 | 08:21 PM
84 yota ex-cab's Avatar
2.7 tacoma problems
I have a 1998 tacoma 4wd 2.7 4 cyl. and it is cuting out and backfiring alot. I ran the codes and i came up with a o2 sensor. I replaced it with a new one and didnt change. I just cleared the codes tonight and now it will hardly idle. the cut out is mostly on the low end
Old Aug 5, 2008 | 08:30 PM
fez97T's Avatar
I had a similar issue on a 96 dodge dakota (i Know not a toyota) and it turned out that after i replaced the o2 sensor the new one got fried almost instantly after i started the truck
Old Aug 7, 2008 | 07:29 AM
ricky's Avatar
You replaced "it"? There's more than one O2 sensor.
Old Aug 7, 2008 | 07:50 AM
BigBallsMcFalls's Avatar
in any case, a bad o2 sensor won't make the thing run -that- bad. just rich
but it will get contaminated and fail from whatever else is causing the problem
test MAF first....MAF issues typically show up at idle speeds first
smthwsn357
May 1, 2024 07:28 AM
94whiterunner
Jul 12, 2015 07:15 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Poncho0206
Jul 10, 2015 06:21 PM
akaphilly
Jul 9, 2015 02:18 PM
