1999 Muffler advice
Old Feb 10, 2014 | 03:45 PM
ConnerLiam's Avatar
1999 Muffler advice
Hey guys, I'm new to the forum and somewhat new to cars. So forgive me if anything I ask about is generic knowledge or somewhat stupid. I'd like to know what exactly I need to look for in a muffler if I want a deep, loud but not annoying noise. I was looking at flowmaster 40 series and a borla, but the Borla is expensive compared to other mufflers. The biggest problem is, I don't know the dimensions I need to get. I know either 2.25 center in, offset out or 2.5 but what length muffler and all of that do I need? I don't want to have to buy extra pipe or modify the exhaust too much at all. I just want an easy installation. What about Thrush? Which muffler do you guys recommend for the 3.4L V6?
(I got a Thrush but it was the wrong size btw.) So sizing help is definitely needed.
Old Feb 10, 2014 | 04:34 PM
CJM's Avatar
CJM
It wont ever be deep like a V8, it will always sound raspy or sort of higher pitched. I just replaced the cat and everything back from there with a bosal system. Its a stock replacement, very easy to put on.I got the entire setup from www.rockauto.com
Old Feb 12, 2014 | 04:58 PM
MistaMota's Avatar
there is also a few videos on youtube.
thats i how made my choice for a flow master 40.
Old Feb 13, 2014 | 11:11 AM
Gamefreakgc's Avatar
It's usually a good idea with a new cat-back system to up the piping 1/4 in larger in diameter. You can still keep the stock piping but may not be claiming the full HP/MPG gains that it has to offer.
Old Feb 13, 2014 | 11:39 AM
highonpottery's Avatar
Welcome to YT!
Do you own a tape measure? the easiest way to know what length is to go measure what's on your truck. just saying.
for the in/out diameter, you need to decide what you're doing wit the rest of the exhaust. if keeping it stock, it would make most sense to stay the same size, or you'll either need adapters or new pipe. of course, ideally you would do a full exhaust but that is more expensive.
I would personally choose something like a turbo muffler, which is more like an oversized glasspack with way more insulation. The reason why I'd say go with turbo muffler is because of the straight-through design where you can see right through the center, which will technically flow much better than the Flowmaster "style" rectangle mufflers - which are all diverted/baffled design, which inherently effects flow and sound. you may have to do some slight tailpipe mods to deal with the linear design, but the benefit would outweigh the inconvenience IMO. Turbo muffler from Magnaflow or other brand will likely be significantly cheaper than a flowmaster branded muffler. Check out YouTube vids of tacomas with turbo muffler and compare to flowmaster
Old Feb 14, 2014 | 04:52 PM
FJHammerHead's Avatar
You will get tired of the noise, I know I did and went back to oem style.
Old Mar 10, 2014 | 01:12 PM
Potomacduck's Avatar
I replaced mine with one of the high flow systems. Big mistake.
Now my 4runner sounds like one of those Honda Civics owned by the punks in the movie, Gran Torino.
I will be scrapping the high flow and buying a stock system. Stick with factory parts.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Longbed 90
Mar 11, 2019 12:38 PM
wberry85
Apr 6, 2018 08:45 AM
93RedKrawler
Sep 25, 2015 04:03 AM
sonorn67
Sep 19, 2015 05:39 PM
