1998 Limited rear window issue
Hello back again just finished up replacing pretty much everything that has to do with front suspension parts today! So now my rear window will not go up or down when earlier in the day it was working just fine it wont work from the switch or the key. I tried to search for a possible answer but any help is greatly appreciated! Thanks Ahead Russ
I have an 98 and had a similar issue. no wiper, no window action. had 3 different mechanics look at this.... they were all stumped. then i started to have battery issues, a parasitic draw....took it to the dealer and they killed it. found that it was the key switch in the rear hatch. it was stuck in the close position. 30$ part. it solved both problems
Rear window
I am the original owner of a 1998 base model 4Runner and recently my rear window switch stopped controlling the window although the key still works. I am not a mechanic but would love to trouble shot the problem if someone would be willing to help me find the possible issues.
Now would be a good time to invest in a Multi Meter !!
Did you put the window lock switch on by mistake??
The switch just died from all the coffee and other liquids spilled on the switch.
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
toyoda8488
Jul 5, 2015 10:18 PM
