170 Thermostat ?
Old Aug 2, 2006 | 06:20 AM
saulgoode's Avatar
170 Thermostat ?
I'm going to flush my radiator this weekend and change out the thermostat while I'm at it, I was wondering if putting in a 170 therm on a stock 3.4 would have any added benefit over a 180 therm? I searched thru the threads and all I could find was engines that have the SC and or URD. Any feedback is appreciated!
Old Aug 2, 2006 | 06:58 AM
mt_goat's Avatar
It would help cool your auto tranny better, but I see you have a Hayden cooler so you may not need that benefit.
Old Aug 2, 2006 | 07:37 AM
saulgoode's Avatar
Will it give any performance such as better mpg, more hp assuming that the engine will be running cooler? Are there any drawbacks to using a cooler therm on a stock engine as opposed to using the 180 therm?
Old Aug 2, 2006 | 07:39 AM
04 Rocko Taco's Avatar
you want to make sure that your engine does warm up to 'operating temps' it burns gas more efficently that way, and helps keep the oil the right consistency, but I would think that 170 is as good as 180, my thinking is that it may not help a lot, but I dont really see that it can hurt.
Old Aug 2, 2006 | 08:13 AM
mt_goat's Avatar
Nope, if anything it will hurt the fuel economy just a fraction.
Old Aug 2, 2006 | 08:15 AM
Finelygotone's Avatar
Here is a good article on the benefits and drawbacks of using different temp thermostats. http://www.carnut.com/ramblin/cool3.html Looks like 180 is a good combination between power and engine wear.....
I think the reason a 170 is used at all is to help combat localized hot spots and the dreaded "pinging" that can be induced by supercharging and higher cylinder pressures/intake charge temperatures.
Old Aug 2, 2006 | 08:32 AM
saulgoode's Avatar
Good link, I think I'll just change out the old therm and put in an OEM 180 therm and flush the system. Thanks everyone for the feedback!
Old Aug 2, 2006 | 08:33 AM
mt_goat's Avatar
Yeah, good link. Thanks
Old Aug 2, 2006 | 08:59 AM
X-AWDriver's Avatar
A bottle of Redline's Waterwetter does actually help maintain a little cooler head temp. I ran a bottle of this and a 10/90 mixture of coolant/water in my Eclipse in during summer race season.
Old Aug 2, 2006 | 09:01 AM
jimbob's Avatar
Hmmm.... kinda makes you wonder about the 160 (I believe) that TRD puts in the 7th kit - don't it???
Old Aug 2, 2006 | 09:35 AM
saulgoode's Avatar
That's kinda why I started this thread, in searching all I found was 160 and 170 therm's in engines that were SC'd.
By the way not to digress from the topic, does anyone recommend a brand of flush or should I just stick with water?
Old Aug 2, 2006 | 11:37 AM
MTL_4runner's Avatar
Just flush with water, the flush chemicals can do more harm than good.
Check out this thread for all the coolant info (warning, possible info overload):
https://www.yotatech.com/forums/show...900#post811900
Old Aug 2, 2006 | 12:44 PM
saulgoode's Avatar
Jaime,
That is some well informed reading, Thanks for the heads up!
kawazx636
Oct 6, 2021 03:03 PM
wberry85
May 17, 2016 05:45 PM
White Stripe
Oct 6, 2015 10:47 AM
rmill05
Sep 27, 2015 01:43 PM
LotOMiles
Sep 14, 2015 11:45 PM
