15x7 or 15x8?
Old Oct 27, 2003 | 01:50 PM
Flygtenstein's Avatar
You ought to get your bodylift from 4Crawler, great product, fellow Toyota guy, extremely knowledgable and helpful. One inch is all you need.
I then ground down my fender seam, hammered the remainder and called it good. If you have mudflaps, plan on ditching them.
In the rear, a little coil lift will help, most importantly, I think, is adding the bumpstop spacers.
Then you can do this:
If you look close, you can see, thanks to my thicker torsion bars, I am not on the compression bumpstop.
Old Oct 28, 2003 | 01:03 PM
data's Avatar
Senior Member
Originally posted by 4x4Fink
What would I need to fit 33x12.50's on my rig? I am thinking just a 1" body lift. I would definately end up going Roger Brown...how much would that cost? I just hope I can find a place around here that is able to do that...hmm...
So pretty much, what would I need to do in order to fit 33x12.50's without rubbing? They will be running on those new wheels that I just ordered.
Thanks fellas!
Fink
I just ordered my Roger Brown 1" BL. Should be here Friday if all goes well. Install it Sat morning. Then do a little wheelin' when its finished
Old Oct 31, 2003 | 10:18 AM
Fink's Avatar
WHEELS ARE HERE AND THEY ARE AWESOME!! I'm excited and they are still sitting in my living room!!!!
I will hopefully be getting them mounted as soon as I can get some lugnuts here locally...if I can't get them locally I will have to order them through Wheelers Off-Road and wait a few days to ge the wheels mounted.
I also need to get some Aisins here soon but that will probably come a little bit later.
Anyway, thanks for all the help in picking these bad boys out...from what I can see in the box it was well worth it!!
Thanks again,
Fink
Old Oct 31, 2003 | 12:36 PM
cvlighthouse's Avatar
Get 15 x 10's for 12.5 tyres http://community.webshots.com/photo/...97506845EiIhcb
theduck21
Sep 10, 2015 07:01 PM
Yotoder865
Jul 9, 2015 07:51 PM
4x4Lamm
Mar 25, 2005 09:32 PM
Scofco
Jul 25, 2004 04:07 PM
