which 12v line for PIAA lights
Old May 18, 2005 | 06:58 PM
89macrunner's Avatar
So i have piaa 525 lights that i have yet to wire..sigh...anyways i need a 12v that turns on when the key goes to ACC for the wedge lights and for the switch power...i tried using the line from my stereo head unit and from my cigarette lighter outlet and its still not working...maybe my wiring harness is defective?..or maybe im an idiot
all these wire and colors confuse me
Old May 18, 2005 | 07:01 PM
jimbo74's Avatar
run a dedicated circuit for the lights... ise a switched ign power as a signal line only if you are going to even do it that way... i have my aux lights wired on their own and have them setup to run with the car off or on, on a dedicated circuit with an in cab switch... they also automatically come on when i flip on my highbeams
Old May 18, 2005 | 07:11 PM
how about a schematic or a detalied write up...im no electrician...nor do i want to fry my truck...thanks jim
i know im going to need a relay a fuse panel and a few other misc things.
Old May 18, 2005 | 10:00 PM
kevin444's Avatar
You need a relay with the +12v acc line source.
Old May 18, 2005 | 11:58 PM
Tacoma Dude's Avatar
Check out Corey's write ups.
I used those extensively when I was trying to figure out my aux. rear lights and that gave me a pretty good idea how to wire it to my liking.
Old May 19, 2005 | 12:01 AM
jimbo74's Avatar
https://www.yotatech.com/attachment....achmentid=4844 is ultimately how i wired it.. the top pic wiith the diodes... it allows me to run it switched inside the cab or automatically with the highbeams.... read the thread https://www.yotatech.com/forums/f2/aux-lights-wiring-help-needed-50001/ for the explaination i received from other members
Old May 19, 2005 | 11:38 AM
thats a good thread jim, ..but the thing is i dont want them wired with my high beams because they lights have a high and a low beam themselves i want them to operate independently...they also have a DRL which i would like to have hooked up....hmm i might use that wiring diagram on my dads runner tho
Old May 19, 2005 | 11:46 AM
jimbo74's Avatar
my original idea did not have them wired up with the highbeams... the bottom half of the diagram is how they were wired up without the highbeams..... https://www.yotatech.com/attachment....achmentid=4844
Old May 19, 2005 | 05:28 PM
hmm that works...will i be able to run the drls off that line as well?
thanks a lot
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
