04 4-runner Transmisssion VSC Trac VSC off lights
Old Mar 9, 2005 | 01:05 PM
freemanc's Avatar
Unhappy 04 4-runner Transmisssion VSC Trac VSC off lights
I need some serious assistance I own a 04 SR5 4runner and I am in the army in germany. The germans do not make a 4 runner so dealer support is very limited. My 4runner check engine light, transmision light, vsc trac, vsc off lights are all on. The dealer has no clue. The codes C1201 and P0156 comes up in the computer. Can anyone please tell me what these codes are and provide some recommended solutions. The computer has been reset twice and the lights went off for about a week and now they are back on. This vehicle has only 9000 miles and I'm really frustrated. This is my first toyota and I think my last..
Old Mar 9, 2005 | 01:13 PM
Good Times's Avatar
C1201 ABS Inlet Valve Coil LF Circuit Short To Ground
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
Fix these two parts and then make sure you use a OBDii scan tool to clear the codes as this is the only way to reset it.
Old Mar 9, 2005 | 01:14 PM
Good Times's Avatar
Any toyota dealership should be able to make these repairs as it should be all done under warranty.
Old Mar 9, 2005 | 01:34 PM
freemanc's Avatar
I appreciate this, now I will have to see how long it will take this german dealer to get these parts.
Thanks
Old Mar 9, 2005 | 01:38 PM
Good Times's Avatar
you'll want them to diagnose the points of these error codes as it could stem from a single item that is triggering these errors. I don't have my service manual on me as I'm at work but I'm sure any toyota dealer would be able to follow the instructions on the service manual and determine what steps they need to run thru to determine what the faulty item can be.
I've personally never seen these errors as I even had to look it up so hopefully they'll be able to figure out the exact cause of the problem based on these error codes and order the correct item associated w/ the errors.
Good luck
Old Mar 9, 2005 | 06:36 PM
aowRS's Avatar
Andreas
Old Mar 9, 2005 | 06:39 PM
89macrunner's Avatar
Originally Posted by aowRS
Andreas
americans dont make 4runners eaither
Old Mar 9, 2005 | 11:06 PM
freemanc's Avatar
OK correction there is not a german spec 4runner for them to use as a guide or problems they have seen before.
Old Mar 10, 2005 | 09:57 AM
Good Times's Avatar
keep me posted on what you find. i have the 03 service manual so if they give you the run around i can try to take photos of the directions on how to diagnose the problem and send em to you or something.
good luck
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
daddio
Jul 18, 2015 10:20 AM
cgilley
Jul 15, 2015 03:32 AM
wilbertd
Jul 6, 2015 07:39 AM
