'02 T4R with cracked head and strange piston damage, ideas?
Old Jul 8, 2017 | 05:16 PM
toyotaforlife's Avatar
2002, 150k, bought in Feb. It's had a HC in coolant issue since I bought it, slight burning of coolant, no coolant in oil, very manageable until just recently. It has overheated twice when left running in park, but no noticeable changes after overheating, and that was months ago. After sitting for 2 weeks it started up and was billowing white smoke so i tore into it and found a cracked head, and what looks like loose foreign body damage to the top of piston #4 and some scratches along the cylinder.
the coolant passages behind the water pump are pretty rusty and the block has some exterior rust. I'm going to pull the rest of the engine and swap in a spare from a 2000 and tear apart the rest of the 2002, see how much trouble I can get myself into.
can a machine shop fix a piston with scratches that deep? seems doubtful. the cylinders will need work too, maybe more than a honing, how much can they take off? i've never cracked an engine open before and was not prepared for this level of damage. I had a plan for a cracked head, but these scratches threw me for a loop.
Any suggestions? I'm planing on completing the swap to get it running, then taking my time with the 2002 engine to make sure it's worth fixing.
I have the FSM for the 2000, and it's pretty close to the 2002, at least as far as the engine goes. theres a few minor differences with the accessories that can be swapped over.
thanks guys, I'd never have the stones to do this without a group like this available!
Attached Thumbnails '02 T4R with cracked head and strange piston damage, ideas?-img_20170708_143440086_hdr.jpg   '02 T4R with cracked head and strange piston damage, ideas?-img_20170708_143536723_hdr.jpg   '02 T4R with cracked head and strange piston damage, ideas?-img_20170708_152313586.jpg
Old Jul 9, 2017 | 01:47 AM
wyoming9's Avatar
Red face
If you swap the engine harness and all the sensors onto the engine your swapping in you should be good.
The only way to tell about the other engine is to see how much it takes to clean the cylinders up.
In the scope of things pistons are not all that expensive .
If one needs to be machined to clean things up they all do
Do it right bore the cylinders new pistons
Then you will see what the bearings look like it there was antifreeze in the oil hope the crank is not scored as well beyond turning .
That is the thing with engines until every thing is apart and inspected you have no clue what you have.
