yotarob2005's 1986 4Runner Build-Up Thread
Old Mar 30, 2011 | 10:31 PM
  #1101
ChefYota4x4's Avatar
Hey Twisted... I think he's saying he gets "325" total, cuz the last 1/4 tank he's lucky to ge 25mi. Most every toyota I've owned has stayed on full for 30 miles, then down to half tank takes it's time, ...then POOOOOOF, lol... then last 1/8th tank seems to last forever again. Strange stuff, lol.
Old Mar 31, 2011 | 02:56 AM
  #1102
Terrys87's Avatar
Chef... sounds like you have driven my trucks. I should of worded it better.
I get 200 on the first half of the tank and lucky if I get a hundred on the last half.
I had posted earlier but it didnt make it to your thread. The frame looks clean and it always nice when you get a lot more then you were expecting when you got the complete gear set up.
Rob, are making fast progress. Keep up the great work.
Old Mar 31, 2011 | 04:54 AM
  #1103
irab88's Avatar
yeah, those numbers are right. it's about what i got. i actually have gotten more than 400 on occasion... but that was back in '08...
the reason for the sharp drop-off at the end is because the fuel sender is at the top of the tank, with an arm that swings down. the first 9 gallons or so move the arm about the same, but the rest move the arm a lot. if the arm's pivot was at the bottom, it would be opposite; the first ¼ tank would go by in 25 miles, and the last ¼ would take forever to deplete
Old Mar 31, 2011 | 07:11 AM
  #1104
yotarob2005's Avatar
Originally Posted by yotarob2005
According to UPS my new mount will be here Friday but I checked the tracking status this afternoon and it was already in Houston so maybe I'll get it tomorrow? Would be nice to get a package early for once.
False alarm on the mount showing up early, What was I thinking? Looks like it is going to be tomorrow.
Old Mar 31, 2011 | 07:47 AM
  #1105
Thanks Terry, I have been hitting it hard to get as much done as possible before my next big wheeling trip coming up in 2-1/2 weeks. It's a 3 day event with my local wheeling group. I still have a long list of things left to do so expect good progress for the next couple weeks.
- Replace sagging trans mount
- Repair and reinstall exhaust, take it to the exhaust shop
- Install rear axle shims
- Install new fuel sending unit
- Replace shifter linkage that I mangled while installing BL
- Replace rear 3rd and front diff with the 5.29's
- Fix drivers side manual hub
- Throw (fab) together a quick and dirty rear bumper, just something to get me by
- Weld on my rock sliders
- Weld on my front frame brace
- Raise front bumper mounts.
I could keep going but I think I will stop there. Last night all I managed to do was get the new diffs cleaned up and ready to go in, also put all of my tools away and got the garage organized again. I decided to go to bed early and catch up on some rest so that I would be ready to get something done today after work.
Old Mar 31, 2011 | 10:36 AM
  #1106
Terrys87's Avatar
You get all of that done in 2 1/2 weeks you got something accomplished. The wheeling trip adds incentive to get it done. 3 days of wheeling ought to be nice. Sounds like you havent been in a while. Gets some pics when you do go. Ive learned shipping is never early. Never on the day I can get things done, but the next day.
Old Mar 31, 2011 | 12:01 PM
  #1107
No kidding, I have alot to do. I am pretty sure I can knock most of it out this weekend but we'll see
I just ordered a couple of these Liquid Caddy's
http://www.liquidcaddy.com/
They are a little pricey but really cool.
Old Mar 31, 2011 | 12:18 PM
  #1108
WOW, NOW YOU'RE BRINGING A CADDY! HAHAHA. Very cool looking buy, man! I have my 99C store Over the Door hinge Cup holder that I put in my Console upper lid and let it sit on the pass. seat right up against the console....I then put my cold bev in the can insulator foam thing and then slide it in the cup holder, ..VOILA, 2$ and I'm keepin cold drinks near me! hahahaha. That thing looks really sturdy!
Old Mar 31, 2011 | 12:24 PM
  #1109
LOL, I know a couple of guys that have these in their wheeling rigs and they pivot 2 directions and keep your cold beverage of choice upright and level on any terrian. You can turn the bottom to make them adjust to any size beverage and they telescope to make them longer for taller drinks.
Old Mar 31, 2011 | 12:55 PM
  #1110
VERYYYYYY cool!
Old Mar 31, 2011 | 09:06 PM
  #1111
Check install rear axle shims off the list.
Add mount cup holders to the list
Old Mar 31, 2011 | 09:17 PM
  #1112
nvtoyota's Avatar
Your list will never go away if you keep adding stuff when you take soothing off
Old Apr 1, 2011 | 04:37 AM
  #1113
LOL, I know, I know.
Becuse I raised the transmission with the DT lift I also changed the drive shaft angle. I decided as a precaution and to keep my driveshaft happy to install some 4 degree angled axle shims. I got these from suspension connection for under $25, they come with a new longer center pin for you leaf springs.
Here they are with the old center pin removed and the new longer pin bolted in and holding the shim to the leaf pack.
Installation complete. For only being 4 degress they made a noticeable difference in the angle of the differential. Now the flange is point more in an upwards direction and this will surely help with drive shft angle.
Old Apr 1, 2011 | 08:08 AM
  #1114
New transmission mount finally showed up today so I can finish installing the crossmember.
Old Apr 1, 2011 | 08:23 AM
  #1115
mightymouse's Avatar
very nice! hope the shims help out. Figure they can't hurt right.
Old Apr 1, 2011 | 08:33 AM
  #1116
xxxtreme22r's Avatar
Good deal on the shims, I might need some to since using the longer shackles. Even though you raised the t-case, did it actually tilt? Have to ask because you also raised the engine right? It was my understanding if the flanges are still parallel to one another that the actual angle of the driveshaft doesn't matter as far as vibrations go. U-joint wear is a different story.
Old Apr 1, 2011 | 08:38 AM
  #1117
That was my logic, can't hurt
Yes I raised the engine and transfer case both 2", so no the case is not tilted. The axle is now titled with the shims in, so the faces are not parrallel. I guess I will just have to get it on the road and see if I have any vibes or not.
Old Apr 1, 2011 | 10:05 AM
  #1118
nvtoyota's Avatar
If you had not shimmed the axel there is a chance that you could have bound up the u joint under load when you had the runner flexed out also it being at less of an angle makes it less likely to break in that situation and yes this should help keep the vibration monster away or make it less of a vibration than if you had not done the shims
Old Apr 1, 2011 | 10:06 AM
  #1119
Lumpy's Avatar
Some say vibrations are good... :jessica:
Old Apr 1, 2011 | 02:59 PM
  #1120
Terrys87's Avatar
Does the list ever go away? I sometimes thinks it keeps growing. Things are looking better. Just keep at it. It will pay off soon out on the trail. I like that you can DD and trail ride.
