yodathespian87's 1990 4Runner Build-Up Thread
#42
I was looking at mine today - the stock sunroof slides back inside the roof - there isn't much room left to put one behind it, unless you went with an aftermarket pop-up one in both locations, and that wouldn't let in as much air as the factory setup (and likely would leak)
#43
I was looking at chopped 4Runners and if I chop it I don't think there is enough space to go double. I just trying to think of ways to open it up inside. Cause spring and summer, and most of autumn is gorgeous for trail riding. I don't have to tell you that. It's beautiful where you are.
#44
As metioned above, with all the windows down and the sunroof open there's A LOT of airflow. If you do something about the rear cargo area glass (which, if you can't find one in a junkyard will run you $427.19 new as a dealer only item) then it's pretty wide open!
#45
What part of california man?
Even not being at higher altitudes having no power sucks be it on hills or flat ground.
I love the difference between the 3.4 and the 3.0. After the swap i can pull the hills i travel every day in 5th gear. Opposed to the 3.0 where i would have to downshift to 3rd to pickup speed at all.
#46
I was looking at chopped 4Runners and if I cop it I don't think there is enough space to go double. I just trying to think of ways to open it up inside. Cause spring and summer, and most of autumn is gorgeous for trail riding. I don't have to tell you that. It's beautiful where you are.
#47
http://image.4wheeloffroad.com/f/922...part1+page.jpg
thats the best side view I could find. sorry it's not that great lol
#49
Ok so I was looking around and I can get a wrecked Tundra for roughly 2 grand. Entire thing. Now would it be best to use the Tundra transfer case and front diff. Seeing as everything else is going to be Tundra? I would be using most everything off of the tundra but due to the wrecked tundras using the 4Runner body and chassis. Right? Or am I way off base here.
#50
I'm parting out all the stuff I won't need right now on CL thats why I was wondering. i like the idea of a V8, Tundras are pretty common up in the Denver import wrecker yards. I have found a few folks with Tundra wrecked that they are willing to sell whole. Figure on using the engine, trans, transfer case, front diff. All that good stuff.
#52
Yeah, as I see it. The running lights, brake lights, and interior windows, sun roof wires would be from the 4Runner everything else would be the tundra. Everything from the engine bay would be gone and I would take everything from under the dash out and use that.
#54
It will be interesting. Lots of custom fab. work I imagine. But that is half the fun to me is the process of building something. Though I'm wondering how this will fit. But look forward to the challenge.
#55
Reading around there are a few issues with the 2uz. 1uz is the around the same weight as the 3.0, and stronger. Does anyone know what years those came in? I can't seem to find it again. Anyone hear about the Lexus 5.2? Searching their forums over at http://www.lextreme.com/forums/forum...e=2&order=desc
#58
From: Yotatech, because Pirate is too expensive. NorCal.
Thats what I'm gonna put in my truck. Lots of 1uz swaps have been done so there is plenty of info so just search around.
Around here if you are lucky you can find them for about 1000 with body damage. Other wise they are up around 1800. And 3000 and up in perfect condition. Wouldnt wanna tear one of those apart though.
lextreme.com
https://www.yotatech.com/forums/f116...version-76701/
http://www.lextreme.com/1uzfe_info.html
lextreme.com
#59
I found just the engine for $400, so I'm sure if I keep looking I will find the entire vehicle for about a grand. And there are plenty of information on lexusextremes and uzswaps.com.
1UZ-FE- 256Hp, 260 ft. lb. Aluminum Block with Aluminum Heads
1989-2000 Lexus LS 400/Toyota Celsior
1990-2002 Toyota Crown/Toyota Crown Majesta
1991-2000 Lexus SC 400/Toyota Soarer
1992-2000 Lexus GS 400/Toyota Aristo
In 1997, Toyota's VVT-i variable valve timing technology 290 hp and 300 ft·lbf. In the GS400 application, output was rated at 300hp and 310 ft-lb of torque.
2UZ-FE- 4.7L, 271Hp, 315ft. lb. Cast iron Block with Aluminum heads
2003-2004 Lexus GX 470
1998-2005 Lexus LX 470
1998-2005 Toyota Land Cruiser
2003-2004 Toyota 4Runner
2000-2004 Toyota Tundra
2001-2004 Toyota Sequoia
TRD offered a bolt-on supercharger kit for the 2000-2003 Tundra and the 2003 GX 470.
2UZ-FE variation adds VVT-i and electronic throttle control.
2005-2009 Lexus GX 470
2006-2007 Lexus LX 470
2005-2009 Toyota 4Runner
2006-2007 Toyota Land Cruiser
2005-2009 Toyota Tundra
2005-2009 Toyota Sequoia
3UZ-FE- 4.3L, 290-300Hp, 325 ft. lb. ALuminum Block and Heads
Lexus LS 430
Lexus GS 430
Lexus SC 430/Toyota Soarer
Super GT
What are some things I can do to up the HP? Wasn't having a whole lot of luck. Other then headers. Do they all have super charger or turbo chargers?
Lexus LS 430
Lexus GS 430
Super GT
Though that rig does look awesome.
