YeloSub7's 1990 4Runner Build-Up Thread
Old May 21, 2008 | 02:41 AM
  #101
894runner1990's Avatar
sounds good thxs for the help. truck is pretty good offroad as all toyotas are. but shes no good on the rocks. i think im getting an 03 f250 super duty in feb so this will be a strictly offroad truck
Old May 21, 2008 | 02:43 AM
  #102
will the 4.10 ratio hold up when runnin 33?
Old May 21, 2008 | 08:25 AM
  #103
birfieldbuster's Avatar
I think that this is truly a thread Hy-jack now...
As far a strength goes, the 4.10s are strong enough.
Nevertheless, they are the incorrect ratio for 33s.
Personally, i have run 33s on your exact same truck with 4.10s. I would have liked to have run 4.88s, but it got me there and back again plenty of times. Without incurring the cost of re-gearing.
Old May 21, 2008 | 10:53 AM
  #104
sorry guys just tryin to get some info thanks for all the help. sry for bein a newbie n havin no diea how to run this site lol but that 4runner the 1990 in this thread is lookin sick
Old May 21, 2008 | 01:50 PM
  #105
YeloSub7's Avatar
So here are a few updated pics of the rear. All the grinding is done (I hope) and will hopefully get the hangers welded next week!! And hopefully drivable
And I decided to keep things this way, cap off that cross member, and squeeze that shock hoop in there while keeping those bump stops for now too. It's always easier to go back and cut more out later
And no worries about the hi-jack, try to use the search button or start a new thread to ask your questions. I think there is a sticky or FAQ that will help you navigate the site. Welcome! We all look forward to seeing your rig in action
Old May 21, 2008 | 04:03 PM
  #106
thxs for the tips man you ride is looking sick, keep postin pics of the updates. i wont be starting my build up till sometime in the fall. gotta graduate highschool first. and need a rig to cruise in the summer with. thxs again for the tips and goodluck with the rest of ur project
Old May 21, 2008 | 05:05 PM
  #107
nice turn down out of your muffler.
Where did you pick that up from?
Old May 21, 2008 | 09:02 PM
  #108
YeloSub7's Avatar
Made it from the scrap that i cut off originally, cut it right, cleaned it up, and welded it on to the best of my noob welding abilities. It'll work for now until I can redo the entire exhaust, or have the money rather. Wouldn't trust myself at this point for all the main welds, so thanks to you this is actually happening
Old Jun 9, 2008 | 04:38 PM
  #109
YeloSub7's Avatar
some more progress!!
rear springs on!
with the axle under it
sorry for my brother's lack of photographing skills
Old Jun 9, 2008 | 04:39 PM
  #110
YeloSub7's Avatar
the front
I'm gonna have to move my steering box forward a bit this can't be good...
Old Jun 10, 2008 | 06:44 AM
  #111
Blizzard's Avatar
Looking good!
Whats the problem with the steering? The tie rod contacting the drag link?
David
Old Jun 10, 2008 | 08:48 AM
  #112
YeloSub7's Avatar
Originally Posted by Blizzard
Looking good!
David
unfortunately yes...
Old Jun 10, 2008 | 08:08 PM
  #113
Marc P's Avatar
I had the same problem when I first did my swap....fixed with a 3/4 drop pitman from Sky. Yours may be a little worse than mine was...
Your 4Runner is looking real good!!
Old Jun 11, 2008 | 11:13 AM
  #114
Wheelingnoob's Avatar
I moved my axle back one inch by redrilling the springs pads on the axle. I still have tones of room at full stuff and 33's and my pitman arm clears....just.
My 3" TG kit has come down about 1.5" in the front from when I first installed it. I just did a 2300km trip with it and it has seated in nice now.
Runner is looking really good.
Jeremy
Old Jun 11, 2008 | 11:39 AM
  #115
sutsch13's Avatar
looking good i wanted to know what it would look like wit 33s looks good in my opinion
Old Jun 11, 2008 | 12:03 PM
  #116
dirtoyboy's Avatar
Looks tits....now you just need some bigger meats
Old Jun 20, 2008 | 06:13 PM
  #117
YeloSub7's Avatar
Some sexy welds from yesterday by my buddy (birfieldbuster) with the new welder
motor mount plate
rear leaf brackets
spring perches
Old Jun 20, 2008 | 07:19 PM
  #118
YeloSub7's Avatar
and to fix the steering problem we removed the old steering box mounts, drilled and sleeved some new holes with TG's steering box mounting plates.
Old Jun 20, 2008 | 07:21 PM
  #119
YeloSub7's Avatar
steering box mounted up! moved forward a little over an inch and rotated down, as you can see I had to switch to the flat pitman arm. Clears everything perfect!
and now have awesome clearence!!
Old Jun 21, 2008 | 12:08 AM
  #120
boof's Avatar
Looking great mate I have to move my steering box forward as well for the same reason.
