xxxtreme22r's 1987 Pickup Build-Up Thread
Old Apr 21, 2012 | 01:08 PM
  #1381
ChefYota4x4's Avatar
PS> Is that thing leakin oil, B?
Old Apr 21, 2012 | 01:14 PM
  #1382
xxxtreme22r's Avatar
It's leaking oil, but that's not what's under the truck. That would be excess degreaser. I had to tighten down my carb spacer. Somehow it go loose and was leaking fuel.
Yeah those lights are just resting in that hole in the bumper which is almost a perfect "fit". The brights were bright in the BMW when they were in there prior to me switching the BMW to HID's.
I might keep there here in the bumper. I don't know yet. But I think the square fogs I might put in the back somewhere for unsuspecting tailgaters. They aren't that bright and are a driving beam instead of a flood beam. So who knows how well they will work.
Oh yeah and I have been following your NOX issue, but no input from me man. Sorry, that's a little out of my league.
Old Apr 21, 2012 | 01:33 PM
  #1383
Ahhh, ok... Well, you'll figure it out.... Sure it will look great.
Thanks on the NOX... I hear ya, don't sweat it, I know you'd chime in if you had something. S'all good cuz I had Roger and a couple other Smog guys chime in... I'll get to the bottom of it. Just gonna probably swap out the Modulator if it fails again with the timing retarded... But first, I have to MAKE SURE that the BVSV is working properly... That can truly effect the EGR as The EGR get's fed to the top it's vacuum by the BVSV(IIRC), lol.
Take care, Brandon... Post pics asap of the decision, k?
PS> How's the carb spacer and all that working?
PSS> Can you put a Snorkel on a Carb'd motor(sorry, dumb question, just curious as you're such a mudder! lol)
Old Apr 21, 2012 | 01:36 PM
  #1384
Yup you can but the two available carb hats alone are like $200+ I'll eventually build my own carb hat and run the air filter to the inside of the truck. Or I can get an adapter to run the factory air cleaner housing on top of the weber and run hose work into that.
Old Apr 21, 2012 | 02:18 PM
  #1385
Ah hah.... Ok, well, was just thinking on a concern that you might suck in some yuck and 'BABOOM', lol. I know, you're careful and you know what you're doin... Just hate to see something happen to this thing after all the good work you've gotten out of that sweet motor!
Old May 3, 2012 | 01:02 PM
  #1386
https://www.yotatech.com/forums/f11/...aff-az-250933/
Thanks AZ89LONGBED for a good deal. Saved myself some coin for a future mod.
Old May 3, 2012 | 01:37 PM
  #1387
WOOT! lol. AZ-FTW! lol.
Old May 6, 2012 | 05:26 AM
  #1388
There.......Fixed !!!
Old May 9, 2012 | 10:21 AM
  #1389
Boondockers Mud Bog Saturday !!!!
Old May 9, 2012 | 10:35 AM
  #1390
Hahaha... gotta love the resourceful nature of the XXX Beast! lol.
Best wishes at the Bog, Brandon!
Old May 9, 2012 | 11:03 AM
  #1391
Haha temp fix till I can afford a new tank, level sender and fuel pickup. Roughly $250-300 worth of crap. Unless I find a really good tank in a junk yard.
Old May 9, 2012 | 11:12 AM
  #1392
Heck, for that, I might be able to find you one and ship it to you for less! lol.
Old May 9, 2012 | 11:36 AM
  #1393
irab88's Avatar
http://www.summitracing.com/parts/SUM-290108/
just sayin'
Old May 9, 2012 | 12:27 PM
  #1394
yeah, trick is getting the level sender to work with the factory gauge. 0 ohms empty, 90 ohms full
Old May 9, 2012 | 02:53 PM
  #1395
irab88's Avatar
factory is 3-110 (f-e). i'm working on a conversion circuit
Old May 11, 2012 | 11:58 AM
  #1396
Meh, It'll do.
Temp fix just to pass inspection. LMAO. Didn't work, interfered too much with clutch.
And the Afters. Hopefully it doesn't make the tires rub.
Old May 11, 2012 | 12:21 PM
  #1397
Nice Improv, Bud!
Old May 11, 2012 | 12:38 PM
  #1398
RBX's Avatar
RBX
Seam seal and under coat?
Old May 11, 2012 | 12:42 PM
  #1399
hell no, stainless sheet (that I got for free), rivets and a few self tapping screws. Topped off with black rattle can. lmao.
Old May 11, 2012 | 02:35 PM
  #1400
Outsane's Avatar
