Swimmerboy2112's 1986 4Runner Build-Up Thread
#1282
ok, so you can get rid of that wire from the lights to the battery. the frame of the runner is ground/negative, so just connect the neg of the lights to bare metal on the frame/body. also, give the lights their own fuse. if you plugged something in the outlet with the lights on (with what you've drawn), you could blow the fuse.
here is a circuit for the front lights
for each light (55 watts or less) add 5 amps to the fuse. here, you would use a 10 amp fuse
edit: the upside-down x-mas tree thing means "ground". in this case, its the frame or body
#1283
Attachment 84397
Attachment 84397
#1286
yes. the frame is better than the bumper. but as long as it's bare metal and not something like a winch you're connecting, you should be fine. if not, then yeah, attach to the frame.
#1288
#1289
What exactly do you need i have a few things.
#1290
to control a large load with a small load. in other words, you can control a bunch of lights with a tiny switch. that also keeps high amperage out of the dash. if the starter motor didn't have a relay, then 4 gauge wire would be needed to run to the ignition switch (key hole)
#1291
(my biggest fear). So are you suggesting that i get multiple relay's and switches for my lights or run them all on 1 relay and switch? OR can you run multiple switches off 1 relay? Sorry i'm so unexperienced in electrical. I can do bodywork, i can do mechanical but i can't do electrical.
#1292
ha, it's ok. i'm big into electronics, but have no bodywork talent
i suggest using one relay for the front lights, one for the yellow roof lights, and one for the white roof lights, each with it's own switch. if you want, you can run multiple relays from a single switch, so, for example, the roof lights would be controlled by 2 separate relays, but those relays would be controlled by a single switch:
#1293
Attachment 84398
Attachment 84398
#1294
if you really wanted to make it fancy, you could do something like this. 100% solid state! i'm actually thinking of adding a micro-controller to the truck to control lights and stuff
#1295
#1296
WOW, Ian,
You're a Proverbial 'Electronic Rock unt Rolllller'! hehe... THANKS, I was hoping to find this info on a search. Now, between you and YotaRob, I'M SET!
Looks good, and Brian, you gonna light that thing up like "Christmas Block" in Connecticut, eh? lol.... Can't wait to see the pics!
...... PICS, PICS, PICS! lol.
Have a good one, guys,
Mark
...... PICS, PICS, PICS! lol. Have a good one, guys,
Mark
#1297
the only reason my rig aint wired yet is lack of time and income. if i had said items, there would be more wiring in that truck than hoover dam! lol.
i just looked at sparkfun's site, and was thrilled that the micro-controllers can now be recognized as a joystick on any computer! i love geeking out!
#1298
WOW, Ian,
Mark
Mark
