swapped89's 1999 4Runner Build-Up Thread
Old Jul 23, 2009 | 05:03 PM
  #81
Elton's Avatar
you gotta tell me where you got those jack stand lifts
Old Jul 23, 2009 | 06:16 PM
  #82
swapped89's Avatar
Improvise man. use what ya got. had to get it high enough to work on and drop the axle.
I would'nt be laughin if i was u this thing is gonna walk all over yer e-locked runner.
I dont know what else you would use. if it works it works
Old Jul 23, 2009 | 06:37 PM
  #83
86Toyrunna's Avatar
sweet man, hopefully i can make it down.. i wont swear to it but im going to try i really wanna see it in action. i might give ya a call tomarrow night, i gotta run over to bastards (aka baxters, over on division) and get a few things for the bronco project and i might swing by and see it. tell ash i said that her runner is officially the sickest 3rd gen in this area lol
btw you owe me a new laptop.. due to the massive ammounts of drool thats all over it from seeing them sexay KINGS!!!!
Old Jul 23, 2009 | 11:08 PM
  #84
swapped89's Avatar
Right on man. come check out the kings in real life i'll be here all night after work 2mro. workin on it.
Old Jul 23, 2009 | 11:28 PM
  #85
swapped89's Avatar
Started tearin down the rear end tonight
Used a ratchet strap to squeeze the coils(kinda scary)
cut the panhard bar with a sawzall cause it was givin me trouble
And theres only one shock cause the other one broke last wheelin trip
Dropped the axle and removed all the link bars so Ash can grind and paint everything. ( make it look new again)
Thats all folks!
Old Jul 24, 2009 | 03:32 PM
  #86
CYi5's Avatar
http://www.trailslesstraveled.com/ar...ndra-cv-axles/ <-works
Not sure if you got the link...it should work on OEM tundra axles, but it won't work on the kragen/autozone replacement axles. Tried it on my buddy's truck and the axles are setup differently inside the boot and it will just bind.
Old Jul 25, 2009 | 02:35 AM
  #87
swapped89's Avatar
Did u guys cut the extra 1/2inch or so off the kragen/auto zone axles and use new boots?????
no bueno. these EMPI axles i got are different than the oem ones too. i all ready returned the expensive ones so ima just cut'm, and hope for the best
Old Jul 25, 2009 | 09:25 AM
  #88
CYi5's Avatar
From what I remember they didn't have the lip that you would normally grind off to allow the extra travel. And it wasn't the straight forward tripod design that you're used to seeing inside of our axles. Soo we put them in and tried to just run them as is, it wouldn't turn easily by hand, so we of course used the vehicles power. It would roll, bind, then bang, repeat. Not optimal
Old Jul 25, 2009 | 11:54 AM
  #89
swapped89's Avatar
Ok these EMPIaxles i got have the straight forward tripod design. and a bit of a lip so ima try cuttin them and puttin on the porsche boots. wish me luck
Old Jul 25, 2009 | 07:09 PM
  #90
swapped89's Avatar
so it looks like i just wasted 200$ on these POS axles. they say they are made to oem manufactures specs but once you open them up they are completely different *&^%!!!
So i'll be calling total chaos monday and ask them to send back the axles i had in the first place. I dont care how much they are. i have just had it with the axles. &^%$!!!!
Old Jul 25, 2009 | 08:18 PM
  #91
86Toyrunna's Avatar
no bueno.. wasted $$$ sucks... heck 4wd is overrated, real prerunnners do it 2wd anyway lol well looks as if im not gonna be making it down to the SL for the maiden voyage if ur still going next weekend. i got to much random shiz i gotta fix or work on lol .. haha you guys oughta get a set of rear paddles for that beast and really tear up the dunes... damn you jason now you got me wanting to build a desert rig lol but i suppose i better get the fo'runna running first or nicole might strangle me in my sleep
Old Jul 26, 2009 | 01:16 AM
  #92
swapped89's Avatar
you at least gottA GET the fo'runna runnin for some winter wheelin. ZP is supposed to be gettin that 1st gen runner from superior on monday comes w 529s and detroit un installed. and new 22re
Old Jul 26, 2009 | 01:57 AM
  #93
Elton's Avatar
looking great are you gonna bring it down to sand lake on the 1st ?
Old Jul 26, 2009 | 02:11 AM
  #94
toyospearo's Avatar
Great work!!!
Great thread!
Old Jul 26, 2009 | 11:16 PM
  #95
swapped89's Avatar
more pics of the progress.
Painted calipers
Put on the fenders
And mounted the resovoirs
Cleaning up surface rust on the rear end and primer
Painted the links gray and the drums blue (blue paint is 1300-2000 degree ceramic paint)
Old Jul 26, 2009 | 11:18 PM
  #96
swapped89's Avatar
This is the next victim of the wire wheel
Old Jul 26, 2009 | 11:25 PM
  #97
904_runner's Avatar
Progress is looking good man!
:beerchug:
Old Jul 27, 2009 | 09:04 AM
  #98
dannomite's Avatar
Awesome! This is an awesome build
Old Jul 27, 2009 | 11:23 AM
  #99
swapped89's Avatar
:beerchug:
Thank you
and Thank you
Rear end SONORAN STEEL kit should come 2day or 2mro.
Word of advice to anyone planning on doin the TC long travel kit. Just buy the modded Tundra axles they have, (unless you can get stock oem cv axles for under 460 a piece like the stealership quoted me you will save yourself a big headache) Most all aftermarket companys say there axles are built to oem spec or better. well they are NOT.!!!!!
Old Jul 27, 2009 | 11:48 AM
  #100
904_runner's Avatar
Post pics of it done already.. i want to see the stance
