Stanz's 1986 4Runner
Old Feb 7, 2013 | 10:29 AM
  #101
ChefYota4x4's Avatar
Hey Stanz, nice turn signal upgrade! Nice wore up as usual, as well.
Old Feb 9, 2013 | 06:34 AM
  #102
ddv1126's Avatar
I bought the same blinkers. The led ones on the bumper. How did you. Wire them to the oem plug? These have three wires
Old Feb 9, 2013 | 06:58 AM
  #103
ddv1126's Avatar
I put the red and back to the green wire. The white to the white wire. The blinker works, but goes really fast. How do I slow it down?
Old Feb 9, 2013 | 09:29 AM
  #104
ddv1126's Avatar
I've been searching for this led flasher mod for my 89 runner. Only thing I found was tbruce's mod for a tundra. Also I read that I can replace the flasher in my runner. Found a few links to some places that sell them. I have no clue which is the one I need though. I'd appreciate any help. Is my flasher unit under the dash too? Will running the new LEDs that fast harm my runner?
Old Feb 9, 2013 | 02:54 PM
  #105
kelvinb's Avatar
No it won't hurt it. Its flashing faster because its pulling less amperage to light up and thinks a bulb is out, so its telling you to find the burnt out bulb and replace it. I'll have to look it up, but you will need to replace your flasher with a lower amperage one.
Old Feb 9, 2013 | 02:58 PM
  #106
ddv1126's Avatar
I've seen a few posts where I can cut something in the flasher relay. Just want to make sure that wont effect the rear flashers. Those are just bulbs.
Old Feb 9, 2013 | 03:10 PM
  #107
ddv1126's Avatar
Stanz, how did you get the lights to stay in the bumper, did you just push then in with the runner fitting? No glue or adhesive?
Old Feb 10, 2013 | 04:00 PM
  #108
stanz's Avatar
I'm not in a place that I can look at the wiring right now, but I can tell you that the black ground wire on the LEDs should go to a chassis ground. LEDs will only work if wired correctly, thus use a test light to find the factory wire with juice, hook that to the + wire on the LED. Hook the remaining to the -.
You will also need to put in an inline resistor (from superbrite, ebay, amazon or your local parts store) to get them to flash correctly. LEDs don't have as much resistance as a regular bulb and therefore may either flash slower or not at all without the resistor wired in.
Old Feb 11, 2013 | 06:10 PM
  #109
stanz's Avatar
I did my last post on my phone while at work and just realized that I answered the wrong question.
The LED lights just press in and stay puts with friction. No cutting or adhesive required. No need for the rubber grommet.
Old Feb 11, 2013 | 06:11 PM
  #110
stanz's Avatar
I've never messed with the flasher under the dash. I just wired these in inline behind the LED bulb:
Amazon Amazon
Works perfect.
Old Feb 17, 2013 | 10:23 AM
  #111
stanz's Avatar
Another update as of this weekend: Custom carbon pattern headliner installed in rear canopy.
http://www.flickr.com/photos/72188695@N05/8483325598/
Full write up at: https://www.yotatech.com/forums/f116...nt-how-251771/
Old Feb 17, 2013 | 10:44 AM
  #112
Nice! Great write up over there on the headliner thread,...
As usual, of course! Hahaha.
I saw the carbon stuff at pepboys, but not that wide. Ebay eh? Wooot! Thanx again!
Redeth, a buddy is looking to do headliner.... Ima send him here for sure!
Old Feb 27, 2013 | 06:05 AM
  #113
liveoffroad's Avatar
Looks awesome stan! your gonna have to start putting that truck in shows if you keep it up!
Old Feb 27, 2013 | 06:38 AM
  #114
stanz's Avatar
Thanks! I hate truck shows though. Haha.
Old Feb 27, 2013 | 10:17 AM
  #115
Terrys87's Avatar
Your top looks great. Something I am going to want to do as mine looks terrible. Great job!!
Old Mar 4, 2013 | 02:36 PM
  #116
kinsey.clay's Avatar
I just wanted to say that I absolutely love your runner!! You have done an amazing job building it!!! The diamond panels I think are an awesome idea and I'm probably gonna steal your idea when I get the time to fab them up!
I also am in process of putting in a rear seat since mine did not come with one and has the delete panel but I didn't know where to start with finding seatbelts so your thread helped me a lot, now I know where to find some good 3 point ones!!!
Old Mar 6, 2013 | 11:52 AM
  #117
hey stan
what thickness did you go with on the diamond plating for your tailgate?
also what color of SEM paint did you use on the gray interior? (color code on can preferred) looks like it matches really well with factory!
Old Mar 6, 2013 | 12:55 PM
  #118
I too love the work u have done and I've had quite a few good ideas through said work. Thanks again for the awesome write ups!
Old Mar 6, 2013 | 08:00 PM
  #119
stanz's Avatar
hey stan
3/16 on the diamond plate.
The SEM color is called Graphite. I used it on the hard plastic, vinyl door panels and the door panel fabric. Just be sure to get everything super clean first.
Old Mar 7, 2013 | 05:34 AM
  #120
great thanks for the info
