sinneDBTB's 1990 4Runner Build-Up Thread
Old Apr 2, 2009 | 11:34 PM
sinneDBTB's Avatar
home made bj spacers, sway bar lower and diff drop
should be pretty self explanitory. enjoy!
(*all pics were taken after build when i had to replace a bj.*)
remove upper bj. try not to tear cv boot like i did.
make a template i used cardboard and paper (3/4" UHMW on left for swaybar lowering)
got some scrap 1/2" alum. not sure what grade. gonna stack two spacers for 1"
used a 2" hole saw to bore out the middle and 5/16" bit for bolts
finished product *note oblong shape of bolt holes to acc. for the angle of the bolts when installed
had to do a lil bit of trimming of a-arm to fit
installed
i used the center cutouts stacked up to lower the dif 1"
the 3/4" UHMW and a piece of 1/4 steel flat bar to lower the sway bar 1"
also added KYB shocks to all 4 corners
and overload springs
and i painted my brake drums red
http://i678.photobucket.com/albums/v...e/DSCF1197.jpg
Old Apr 2, 2009 | 11:40 PM
sinneDBTB's Avatar
some of the pice didnt show up
spacers with oblong bolt holes
sway bar lowered
red drums
Old Apr 3, 2009 | 02:42 PM
mattaway's Avatar
very nice. how much was the cost of materials?
Old Apr 3, 2009 | 03:30 PM
toyota4x4907's Avatar
Neat. Good job at fabbing them yourself.
Cute coolant leak
Old Apr 3, 2009 | 03:35 PM
sinneDBTB's Avatar
i got the aluminum and UHMW free from friends as they were small scrap pieces. all that i bought was mounting hardware which probably cost me less that $20.
Old Apr 3, 2009 | 03:50 PM
j0hNnI's Avatar
unless you dont have the tools an machines to make it yourself good job to btw
Old Apr 3, 2009 | 04:09 PM
sinneDBTB's Avatar
Cute coolant leak
thats not a real coolant leak. its me being to lazy to drain out the system when i took out my intake manifold. but thats a whole nother thread.
Old Apr 3, 2009 | 04:11 PM
sinneDBTB's Avatar
the only tools i used were a circular saw to cut the alum. and UHMW, a drill press and a grinder to clean up the edges and trim the upper a-arm.
Old Apr 3, 2009 | 06:45 PM
abecedarian's Avatar
well, for $20... I'll take two sets.
Old Apr 3, 2009 | 11:08 PM
sinneDBTB's Avatar
i will make you a set if you will replace my cv boot for me? really not looking forward to that.
Old Apr 3, 2009 | 11:41 PM
you can build a spacer but are afraid of some grease?
Honestly, you put more work into the spacers than is necessary for the boot.
Old Apr 4, 2009 | 12:12 AM
sinneDBTB's Avatar
is that a yes then? i've never had any good experiences with cv's.
Old Apr 4, 2009 | 12:33 AM
you going to pay to ship them down then back up, and buy the boot?
you could probably buy a new half-shaft for that.
you're making the proverbial mountain out of the mole hill
Old Apr 4, 2009 | 09:05 AM
RMA's Avatar
RMA
Great Job !! Cant beat it for $20 .
Old Apr 4, 2009 | 09:18 AM
Justinlhc's Avatar
I'm impressed. I love seeing people fabbing their own parts instead of swiping the credit card.
I have one question though. On the front mount of the differential it has a different mounting position. How did you lower that? Or did you? I'm just thinking without lowing that your front driveshaft is going to be on a crappy angle, like even worse than it would have been without those rear differential spacers.
Old Apr 4, 2009 | 03:48 PM
sinneDBTB's Avatar
no you are i was just kidding man lighten up. jeez why so serious?
i took rogers advice, this should explain it.
http://www.4crawler.com/4x4/ForSale/DiffDrop.shtml
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
ptb12
Jul 5, 2015 01:49 PM
