sbarnesvta's 1992 Pickup Build-Up Thread
Old Aug 27, 2010 | 06:04 PM
  #81
sbarnesvta's Avatar
25' of 9 conductor 18ga wire, one run to the front and rear is enough for everything.
I also put a protective plastic wrap on the parts that will be exposed under the truck.
Old Aug 27, 2010 | 06:05 PM
  #82
sbarnesvta's Avatar
switch panel roughed in with relay pack wired in
relay pack wired up
semi-finished product
Old Aug 27, 2010 | 06:06 PM
  #83
sbarnesvta's Avatar
I still need to wire up the locker end, but it is coming along.
Next step is to fab up a front drive shaft.
Old Oct 25, 2010 | 02:28 PM
  #84
socal85toyota's Avatar
Nice Rig, i see you've got your hands full with that one...haha im in the same boat with my 85. i see you took it out to gorman before the morp as did i, boy was that just a teaser. GL mayb c ya out there sometime.
Old Oct 25, 2010 | 06:47 PM
  #85
sbarnesvta's Avatar
I havent done much work on the truck in the last month or so, been way to busy with work.
I did manage to get somewhat of a front driveshaft going, but it needs some work, and i'm in the processing or changing the timing belt and water pump at the moment.
I have a couple friends that are going to be heading up to gorman in the next month or so for a shake down run if you want to join.
Shoot me a PM with your email.
Old Dec 18, 2010 | 05:34 PM
  #86
sbarnesvta's Avatar
Major updates:
-SAS finished but pinion angle was not happy so i pulled the front axle apart yet again to rotate the axle, now all is well
-Replaced rear axle with a 02' tacoma rear axle with e-locker.
-Finished up all the wiring
For detail on any of the stuff done check out this link, http://pirate4x4.com/forum/showthread.php?t=920474
Truck as it sits now, definitely needs some bigger tires probably 35-37's
Old Aug 11, 2012 | 06:51 PM
  #87
sbarnesvta's Avatar
Well I haven't been on here in a while figure it is time to update this thing.
The truck is just about done. Current specs as it sits
- freshly rebuilt 3.0L w/ downey headers and custom exhaust
- Front and rear e-lockers installed
- Clocked Front Axle
- Dual Cases (2.28/4.7)
- Custom drive shafts
- Roll Cage
- 37x14x17 Iroks on Pro Comp Steel Crawler Wheel
- Bobbed bed 12"
Today I finished up all the mounting of stuff in the bed, tools box, cooler, and spare tire.
Stuff to finish up
- Install Longfield axles in front
- Install 6 shooter knuckles
- Install Tunion Bearing Eliminators
- Install Speed sensor
- Figure out small T-Case leak
- Wheel the heck out of it!
Here is how the truck sits as of today.
Old Sep 2, 2012 | 12:42 AM
  #88
Tdub8's Avatar
Truck looks awesome! How did you apply the hurculiner? Spray or roll on?
Old Sep 2, 2012 | 05:46 AM
  #89
JeremyW94's Avatar
It's amazing what you've done to the truck. Looks Awesome.
Old Sep 2, 2012 | 05:50 AM
  #90
rattlewagon's Avatar
Trucks looks killer man. Whats the wheelbase on that after the solid axle? Killer job on that switch panel too!
Old Sep 2, 2012 | 09:32 AM
  #91
Tdub8's Avatar
No kidding! That switch panel is legit!
Old Sep 2, 2012 | 07:13 PM
  #92
sbarnesvta's Avatar
The bedliner inside the cab was installed with a couple cheap 4" paint brushes from Lowes.
I have found a new product that I like a little better than the herculiner, it is made by duplicolor and it called bed armor. This stuff goes on much thicker. I used it patch the bed liner in the bed when I bobbed it. I can take some more pictures if your interested. http://www.duplicolor.com/products/bedArmor/
Old Sep 2, 2012 | 07:14 PM
  #93
sbarnesvta's Avatar
Thanks!
Old Sep 2, 2012 | 07:21 PM
  #94
sbarnesvta's Avatar
Thanks guys, I could not find a solution that I was happy for a price that fit the budget so building it was the only option. I hate having 5 or 6 switches mounted all over the dash where they can be bumped randomly or forgotten about. This way everything is in one nice spot.
One issue I have run into was the lockers could be activated at any time (freeway at 65mph would not be good) it would be a reach to hit the switches but it could happen I guess. To get around this I have been pulling the fuses for the lockers when I am going to be driving around. I decided to make one of the
extra switches I had as a main power swtich for both lockers. This way the power switch would have to be activated before either of the lockers could be activated.
If you guys have any more questions let me know, I have taken a ton of pictures a long the way I just need to upload them in this thread.
Old Sep 2, 2012 | 07:23 PM
  #95
sbarnesvta's Avatar
To tell you the truth I have not measures the wheel base, I pushed the front axle forward about 2" when I did the SAS, and the rear axle has not moved (yet, I am planning on linking the rear one of these days. I will measure it tomorrow.
Old Sep 3, 2012 | 08:47 AM
  #96
Tdub8's Avatar
Thanks im going to look into the duplicolor and more pics would be killer!
Jun 1, 2021 01:51 PM
crashburnoveride
Aug 28, 2015 09:20 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Nickdigg
Jul 7, 2015 06:04 AM
wilbertd
Jul 6, 2015 07:39 AM
