sbarnesvta's 1992 Pickup Build-Up Thread
Old Aug 15, 2010 | 09:35 AM
  #61
sbarnesvta's Avatar
Rear end clearance
Old Aug 15, 2010 | 09:39 AM
  #62
sbarnesvta's Avatar
Yesterday was a day to finish up a couple loose ends.
- Bleed brakes
- Reinstall bed
- Adjust pinion angle with bed and bumper installed
I had to drive the truck down to my shop (only a short drive) because i do not have a welder at my house.
- Install front shock hoops
- Install upper rear shock mount
- Burn in rear axle spring perches
- Fab up some new brake line mounts
Still left to do
Old Aug 23, 2010 | 08:55 PM
  #63
sbarnesvta's Avatar
I thought I lost a bunch of pictures, but i managed to dig them up of the swap.
Current status:
- Front shock hoops installed
- Front shocks installed
- Rear upper shock mount fabbed and mounted
- Rear shocks installed
- Brake line mounts finished (Still need to install springs to keep them out of the tires)
- All welding is complete for now
I have been driving the truck around town a little bit the last couple days and it is just about ready for a test run off-road to see what it will do.
Old Aug 23, 2010 | 09:01 PM
  #64
sbarnesvta's Avatar
Here are some more pics- Front Axle
An easy way to get the long axle shaft in
E-Locker installed
Marlin Crawler Motor Armor
Old Aug 23, 2010 | 09:04 PM
  #65
sbarnesvta's Avatar
Working on the Rear End
My buddy curtis finishing stock spring perch removal
Old Aug 23, 2010 | 09:10 PM
  #66
sbarnesvta's Avatar
Now time for some flexy pics-
Front End-
Old Aug 23, 2010 | 09:11 PM
  #67
sbarnesvta's Avatar
I need to get some shorter shocks or come up with a new rear shock mount because the shocks are currently limiting the flex in the front. As of right now I only have about 4" of down travel with the shocks. When I get that worked out I should be able to get another 6" or so out of the front end.
Old Aug 23, 2010 | 09:14 PM
  #68
sbarnesvta's Avatar
Back End Flexing
Front View
  #69
sbarnesvta's Avatar
Front End Stuffed
and drooped out
Old Aug 23, 2010 | 09:16 PM
  #70
sbarnesvta's Avatar
I am really happy with the front end flexing, and once i get the rear figured out we should be good to go.
I still need to install the bump stops maybe ill get that done this week.
I also found a freshly rebuilt front drive shaft out of an 85 pickup that I am going to get tomorrow afternoon.
more pics to come.
Old Aug 23, 2010 | 09:34 PM
  #71
Crimson Yota's Avatar
Originally Posted by sbarnesvta
I have not wired anything up yet, it is just installed for the moment to make sure everything fits. I am planning on pulling it off and etching all the labels into it. The plan so far is
1- Front Locker
2- Rear Locker
3- Front Lights
4- Rear Lights
5- CB/ Radio/ Interior Misc.
6- Not Use Yet
I need to still play around with the fitment a bit, but it is close.
That's really cool, looks awesome, this is what I'm wanting to do in the future.
Great build thread. Your truck is looking good.
Old Aug 24, 2010 | 02:15 PM
  #72
BigSwole's Avatar
nice lookin truck bud...
i know nothing of sfa but to me it seems that the tire should line up with the wheel wells still? am i right? wrong? (most likely)
regardless good looking truck and congrats on finally finishing it.
Old Aug 24, 2010 | 09:52 PM
  #73
sbarnesvta's Avatar
It was just a starting idea, I need to add 2 more LED's for each locker switch (locking, unlocking, and locked LED's) and it will be powercoated and cnc etched when it is done. I also need to play with the fitment a little more, but its coming alont
Old Aug 24, 2010 | 09:56 PM
  #74
sbarnesvta's Avatar
thanks for the compliment,
As far as the axle being forward, it is about 1-2" further than normal. The point of this is the axle actually moves back as it travels up due to the shackle being in the rear of the spring. This also allows me to run larger tires and I can trim the bumper and front of the fender vs cutting the the rear fender and firewall which can be a PITA if you have to relocate all your electrical and ECU(on the passenger side).
Let me know if you have any other questions.
Old Aug 24, 2010 | 09:58 PM
  #75
sbarnesvta's Avatar
I got a new set of speakers and a little sub hooked up for some tunes to get to and from the trail.
I will post pics tomorrow
Old Aug 24, 2010 | 10:01 PM
  #76
sbarnesvta's Avatar
Projects im hoping to finish before the end of the year.
- Larger tires 35" or 37" cant decide yet.
- Dual Cases (I have the second transfer case just need adapters and mounts)
- Rear E- Locker
- Rear Gear 5.29 front and rear
- new headers and exhaust
- tune up motor
Well see what gets done.
I have some more pics just need to upload them
Old Aug 27, 2010 | 05:47 PM
  #77
sbarnesvta's Avatar
Well i think i found a rear e-locker with 4.30 gears. I am going to take a look at it tomorrow on my way down to work, and if all goes as planned I will be good to go on the front and rear locker.
Old Aug 27, 2010 | 05:54 PM
  #78
sbarnesvta's Avatar
I decided now was the time to redo my switch panel and get my e-locker wiring going.
I didn't like the spacing and mount of the last switch plate I made so i decided to redo it.
Marking up the aluminum.
drilling holes
Cleaned up
Old Aug 27, 2010 | 05:57 PM
  #79
sbarnesvta's Avatar
Next was to check fitment and layout of locker LED's.
Painted, switches and LED's installed
-First 2 switches are for Front and Rear lockers
-Red LED "Locked"
-Green LED "Locking"
-Amber LED "Unlocking"
Old Aug 27, 2010 | 06:01 PM
  #80
sbarnesvta's Avatar
Than started wiring in switches and relays for lockers
4- Relays mounted on bracket
- Front Lock
- Front Unlock
- Rear Lock
- Rear Unlock
Also wired in quick disconnects in case i need to remove the switch panel or need to pull the wiring harness.
