sbarnesvta's 1992 Pickup Build-Up Thread
Old Jul 6, 2010 | 07:32 AM
  #41
sbarnesvta's Avatar
I also pulled the front bumper to start working on the SAS, I am still up in the air on cutting to the ARB mounts to make it work with the SAS or sell it and buy a new tube bumper.
Old Aug 6, 2010 | 08:22 AM
  #42
sbarnesvta's Avatar
Progress has been pretty slow lately, I was planning on having the swap done by now. I got a call for a tour with an artist iv'e done a little bit of work with in the past. So I was off to Europe for a week and a half, home for a couple days, than Japan for 4 days. Here are a few pics.
Fuji Rock Festival Japan
Ill have to upload some europe pics later
Old Aug 6, 2010 | 08:26 AM
  #43
sbarnesvta's Avatar
I was planning on starting the build this week, but found out Genright was having a customer appreciation run at Hungry Valley, Ca on Saturday. SO I put the swap off for another week.
Here are a few little project I have been working on.
Custom Switch Panel-
Old Aug 6, 2010 | 08:29 AM
  #44
sbarnesvta's Avatar
I have not wired anything up yet, it is just installed for the moment to make sure everything fits. I am planning on pulling it off and etching all the labels into it. The plan so far is
1- Front Locker
2- Rear Locker
3- Front Lights
4- Rear Lights
5- CB/ Radio/ Interior Misc.
6- Not Use Yet
I need to still play around with the fitment a bit, but it is close.
Old Aug 6, 2010 | 08:34 AM
  #45
sbarnesvta's Avatar
I have also been installing the SAS stuff that I can get away with.
-Install front spring hanger
-Install front shackle tubes into frame
-Install rear spring hanger
-Modify and reinstall bumper to work with all the new stuff on the front end
I think I am going to be investing in a decent mig welder one of these days. The stick has been a pain in the butt to get into tight spaces, but it is working for the moment.
Old Aug 6, 2010 | 08:37 AM
  #46
sbarnesvta's Avatar
Next project was to install the CB Radio Antenna.
I ran the wire for CB Radio along side the trailer wiring harness, than up the front side of the bed. See picture below.
Old Aug 6, 2010 | 08:38 AM
  #47
sbarnesvta's Avatar
Followed up by some safety-
First Fire Extinguisher installed in the bed for easy access.
I still need to find a spot for the second one.
Old Aug 6, 2010 | 08:40 AM
  #48
sbarnesvta's Avatar
Next was some rear off-road lights.
This is a temporary install as I eventually want them in the rear bumper, but this will keep them out of harms way for now and still be effective. I was going to mount them on the bottom of the bumper, but there is already some rock rash on the bottom and I knew the lights wouldn't last long.
Old Aug 6, 2010 | 04:02 PM
  #49
bend's Avatar
Sweet build thread. Good work. Seems like you have a pretty decent job too.
Old Aug 6, 2010 | 07:01 PM
  #50
sbarnesvta's Avatar
Thanks.... the IFS will be all alone on sunday night if all goes as planned. I am hoping to have the SAS done by tuesday or wednesday.
And yea the job has been good lately, but 60hrs in an airplane in the last 3 weeks is a little rough.
Old Aug 6, 2010 | 09:46 PM
  #51
sbarnesvta's Avatar
Heading to Hungry Valley, CA tomorrow if anyone is interested in meeting up there. We will be there all day.
Old Aug 9, 2010 | 08:04 PM
  #52
sbarnesvta's Avatar
Well the SAS is taking a bit long than expected.
I thought I would check the Gear ratio's one last time before we got started and it turns out my truck has 4.30 gears in the rear end. So i ended up putting the 4.30 e-locker I had in the front axle. That took the majority of sunday. On the bright side I am getting pretty good at pulling the front end apart.
I will post up pictures when I get home.
Old Aug 9, 2010 | 08:05 PM
  #53
sbarnesvta's Avatar
Today was a long day but i managed to get all the IFS out and started cleaning up the frame.
Pics to come.
Old Aug 10, 2010 | 02:21 PM
  #54
buel09's Avatar
Nice build thread
Old Aug 11, 2010 | 06:14 PM
  #55
sbarnesvta's Avatar
Yesterday was a LONG day....... 7:30am- 8:30pm.
-Front shackles and springs installed
-Front axle installed
-Steering almost completely installed (just need to be adjusted and tightened)
-Replaced an oil seal in the passenger side hub
-Installed brake calipers
-Installed tires to check for clearance
BREAK
-Pull bed off
-Pull rear axle
-Remove stock leaf springs
-Grind off old spring perches
-Install new spring perches
-Install new springs
-Adjust pinion angle
-Tighten everything down
It was a long day but I had some help from a couple friends dylan and curtis. All in all i think it was a 6 beer job.
Old Aug 11, 2010 | 06:17 PM
  #56
sbarnesvta's Avatar
I am going to have to take a little break for work the next couple days, but the truck is rolling.
Things left to do-
-gusset front spring hanger
-install shock hoops
-finish cleaning up frame
-adjust steering
-finish brakes and bleed system
-install rear shock mounts
-install shock all the way around
-rework the emergency brake system
TEST RUN!!!!!!!!!!
Old Aug 15, 2010 | 09:31 AM
  #57
sbarnesvta's Avatar
I just realized i only have a few pictures from the swap, but here are a couple.
The typical IFS is missing pic
Useless IFS stuff now
Old Aug 15, 2010 | 09:32 AM
  #58
sbarnesvta's Avatar
E-Locker installed in the front axle, axle ready to go in the truck.
Old Aug 15, 2010 | 09:33 AM
  #59
sbarnesvta's Avatar
The truck as it sits now. I was really worried about the rear being too tall, but by the time I got the bed and rear bumper back on all was good.
Old Aug 15, 2010 | 09:35 AM
  #60
sbarnesvta's Avatar
Front end clearance
