RBx 1988 4Runner Build-Up Thread
RBX 88 4Runner Build Up Thread
In April of 2010 I found a college student willing to trade his 87 4Runner DLX with 110k on the clock for my 90 Acura Integra with 256k. No matter the condition, I wanted a 1stGen 4Runner, and with 110k on the 22re how bad could it be. This truck was aptly titled 4Ruster, I think it was parked in the Atlantic Ocean for a few years, the rust is impressive, but the interior is in great shape. This pic makes the truck look so wimpy...
RBx-1st-4Ruster by unholyburns, on Flickr
In August 2010 I picked up this glorious SR5 3.slo for $800 with 224k on the clock. Truck runs but needs a tune up (+ O2, Temp & Knock Sensor codes thrown) and TPS adjusted. Interior is pretty trashed, broken panels, missing tailgate trim. Body is in amazing shape, car history says it came from Florida. Now the addiction begins.
RBx-4Runner-DC-stockish by unholyburns, on Flickr
Some serious ghetto *stuff* going on under the hood....this simply will not do!
RBx-4Runner-ghetto-1 by unholyburns, on Flickr
Wrong battery size, no washer bottle, battery tray rotted from leaking battery(can't see it but there are two paper magazines under the battery to keep it from falling thru. This is the worst of the metal rot
RBx-4Runner-ghetto-2 by unholyburns, on Flickr
RBx-4Runner-ghetto-5 by unholyburns, on Flickr
Some interior Shots....ARGH!! Red...yick, who the hell thought this looked good?
RBx-4Runner-int-2 by unholyburns, on Flickr
RBx-4Runner-int-1 by unholyburns, on Flickr
Second 4Runner I have bought with no rear head rests???...What the *hell*??!! Did people just throw them away? And, NO, the 2ndGens don't fit...I've tried
RBx-4Runner-int-5 by unholyburns, on Flickr
Since the Interior is pretty ratty i am going to switch out as much of the interior with the '87 4Ruster's interior.
Broken List:
That is the short list, and I overlooked a few things
The truck does run, I drove it up from DC(45miles) to her new home in Baltimore. Even though there seems to be a few issues, electrically (ill get into this later) it seems to be a very solid 4Runner to base my build on. Plus, having two almost identical vehicles is proving to be very handy, misc clips, fabrication, broken pieces.
Then Phase 2, new shoes, interior complete, engine issues resolved OBA, OBHS and Trunk:
RBx-4Runner-phase 2 by unholyburns, on Flickr
Current State SAS, 4Wheel underground 3-Link, bumper, sliders and Full Float rear axle:
RedCloud-10-2014 (51) by unholyburns, on Flickr
RBx-1st-4Ruster by unholyburns, on FlickrIn August 2010 I picked up this glorious SR5 3.slo for $800 with 224k on the clock. Truck runs but needs a tune up (+ O2, Temp & Knock Sensor codes thrown) and TPS adjusted. Interior is pretty trashed, broken panels, missing tailgate trim. Body is in amazing shape, car history says it came from Florida. Now the addiction begins.
RBx-4Runner-DC-stockish by unholyburns, on FlickrSome serious ghetto *stuff* going on under the hood....this simply will not do!
RBx-4Runner-ghetto-1 by unholyburns, on FlickrWrong battery size, no washer bottle, battery tray rotted from leaking battery(can't see it but there are two paper magazines under the battery to keep it from falling thru. This is the worst of the metal rot
RBx-4Runner-ghetto-5 by unholyburns, on FlickrSome interior Shots....ARGH!! Red...yick, who the hell thought this looked good?
RBx-4Runner-int-1 by unholyburns, on FlickrSecond 4Runner I have bought with no rear head rests???...What the *hell*??!! Did people just throw them away? And, NO, the 2ndGens don't fit...I've tried
RBx-4Runner-int-5 by unholyburns, on FlickrSince the Interior is pretty ratty i am going to switch out as much of the interior with the '87 4Ruster's interior.
Broken List:
- Dash Coolant Temp Gauge (half-way when engine is cold)
- Oil Pressure Gauge (half-way when engine is off)
- Engine grounds missing, not hooked up or corroded
- Grill
- Horn
- Washer Bottle Missing
- Windshield Cracked and missing trim
- Battery Tray eroded
- Intake Hose Cracked(blue tape)
- TPS needs adjustment , plus codes 21, 22, 52, 41
- Tired/Flat Rear Springs
- Passenger Window will not respond to switch movement and is off track
- Fuses in fuse block wrong size…mostly 20A
- Odometer
- Tailgate missing gasket, wiring torn up will not work
- Front Bumper Bent
- Transmission shifter sloppy, missing grommets and spacers (more ghetto mechanics)
- Heater A/C face plate destroyed
- L-trim Driver side rusted, shotty repair
- Alarm system rats nest under dash non-functioning
- Missing Brake pedal cover
RBx-4Runner-phase 2 by unholyburns, on FlickrCurrent State SAS, 4Wheel underground 3-Link, bumper, sliders and Full Float rear axle:
Currently the entire interior(only the headliner was left in) has been pulled out to sound deaden the entire truck(took quite a while),rework some wiring, add some wiring, and fix some boogered wiring. Adding a sound system in a way that wondering eyes won't 'see' it. Changing ALL dash and accesory lights to red. lights Adding 2nd courtesy(all LEDs of course).
Moved Window swithes to the center console(like Land Rovers), and tied all windows into one 'lock' switch.
The wiring and such has become a larger project then i anticipated because i keep finding great mods, or tweaks i want to do, as well as thinking about future upgrades. And the phrase i keep falling back on time and time again is....
...Well its already torn apart, i might as well do 'this' also....and that keeps setting me back. But the wire job will be done right(nice and neat...factory like).
More soon
Little Mo Pix
vInterior Removed
RBx-4Runner-insul-int-1 by unholyburns, on Flickr
RBx-4Runner-insul-door-1 by unholyburns, on Flickr
RBx-4Runner-gut-int-3 by unholyburns, on Flickr
RBx-4Runner-gut-int-2 by unholyburns, on Flickr
RBx-4Runner-insul-int-3 by unholyburns, on Flickr
RBx-4Runner-insul-int-2 by unholyburns, on Flickr
Dash out also to make way for more wiring
RBx-4Runner-insul-int-4 by unholyburns, on Flickr
RBx-4Runner-gut-int-1 by unholyburns, on Flickr
RBx-4Runner-gut-int-4 by unholyburns, on Flickr
time to run wires for the Inverter, Audio Amp, and Sound deaden everything. As i mentioned before the interior was ratty, and the awful mono-red, so most of it was going to be removed anyhow. Removing everything makes wiring easier, and cleaning each part makes her smell nice again.
I am also moving the window switches to the three spots in the center console....more soon.
thanks for watching
RBx-4Runner-insul-int-2 by unholyburns, on FlickrDash out also to make way for more wiring
RBx-4Runner-gut-int-4 by unholyburns, on Flickrtime to run wires for the Inverter, Audio Amp, and Sound deaden everything. As i mentioned before the interior was ratty, and the awful mono-red, so most of it was going to be removed anyhow. Removing everything makes wiring easier, and cleaning each part makes her smell nice again.
thanks for watching
And painted the grill
Old and Busted:
RBx-4Runner-grill-4 by unholyburns, on Flickr
Kept the Chrome Lids
RBx-4Runner-grill-3 by unholyburns, on Flickr
RBx-4Runner-grill-2 by unholyburns, on Flickr
Old and Busted:
RBx-4Runner-grill-4 by unholyburns, on FlickrKept the Chrome Lids
Interior Pics, Sound Deadening & Insulation
Interior sound deadening
INTERIOR INSUL 4RUNNER by unholyburns, on Flickr
Inverter Installed(solenoid for switch is the two ten mm bolts next to the speaker)
Either i am launching a satellite or this will keep the Beer cold!code name: 4Cooler
Redoing the shifter trim cover...first try at upholstery using Sunbrella
yes that is adhesive seeping thru the fabric, acetone should clean it up
this stuff will highlight some interior pieces...Perforated Aluminium
More soon
INTERIOR INSUL 4RUNNER by unholyburns, on FlickrInverter Installed(solenoid for switch is the two ten mm bolts next to the speaker)
INTERIOR INSUL 4RUNNER by unholyburns, on FlickrEither i am launching a satellite or this will keep the Beer cold!code name: 4Cooler
INTERIOR INSUL 4RUNNER by unholyburns, on FlickrRedoing the shifter trim cover...first try at upholstery using Sunbrella
INTERIOR INSUL 4RUNNER by unholyburns, on Flickryes that is adhesive seeping thru the fabric, acetone should clean it up
INTERIOR INSUL 4RUNNER by unholyburns, on Flickrthis stuff will highlight some interior pieces...Perforated Aluminium
INTERIOR INSUL 4RUNNER by unholyburns, on FlickrMore soon
shifter console cover done:
I have 2 Runners, this red one had a ratty interior and the other 87 runner was in great shape, so she will be getting a grey carpet, black panels, and perferated aluminum accents and stuff
Thanks
Thanks
