psychotech's 1990 Pickup Build-Up Thread
Old Oct 15, 2011 | 08:45 AM
psychotech's Avatar
I got this truck for $1700 with a bad water pump and stripped #1 plug hole among other numerous problems. I replaced the radiator, water pump, timing belt, idler pullies etc. The truck ran like hell but still drove ok until one day at a stop the engine started to run erratically and rough. After some investigation I found that the #6 valve shim had popped out of the top of the lifter and the intake valve was stuck open. Got new heads for $220ea shipped and a gasket set for $84 and set to work. After many tools and much pain I am at the turnaround point. I found a blown gasket upon removal of the opposite head. I have reinstalled the new heads and cams and I am getting ready to replace the cam sprockets, timing belt and intake. I need to resize my pictures when I have time. Will post later.
Here is a link to the photo album if you want to see the pictures.
https://www.yotatech.com/album.php?albumid=3702
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
crashburnoveride
Aug 28, 2015 09:20 PM
Nickdigg
Jul 7, 2015 06:04 AM
ptb12
Jul 5, 2015 01:49 PM
