peapicker's 1990 4Runner Build-Up Thread
Old Aug 16, 2009 | 05:00 PM
  #41
peapicker's Avatar
All primmed up!
Old Aug 16, 2009 | 05:01 PM
  #42
peapicker's Avatar
Inside all clean ready for the new used interior.
Old Aug 16, 2009 | 05:06 PM
  #43
peapicker's Avatar
I do have the finish coat on all the doors, right now im trying to decide what to do to the hinges. Thinkn about putting a good coat of rustoleum flat black on em. all the trim on the rig is gonna be black so it should blend nicely! And as a side note, Holy frikn crap!! It takes a lot longer to put back together! Than it did to take it apart.
Old Aug 16, 2009 | 05:08 PM
  #44
Fink's Avatar
What'd you use to clean the interior metal?
Fink
Old Aug 16, 2009 | 05:34 PM
  #45
peapicker's Avatar
Just soap and water. It was in pretty good shape to start with. Still had the original carpet down and no one had ever messed with it! Got lucky for a change!
Old Aug 17, 2009 | 04:08 AM
  #46
Fink's Avatar
Mine is almost in the same condition except for some areas of very dried/packed and almost welded on mud that crept in after the fenders were trimmed.
I'm hoping after Wabbit and I get the fenders tubbed, I can go in and hose that crap off and have a clean surface to start with.
Your rig is looking great, still looking forward to some more pics.
Fink
Old Aug 17, 2009 | 09:16 PM
  #47
RobD's Avatar
Since you've got the interior all pulled apart, why not lay down some Dynamat or some Second Skin to help keep the noise levels down?
Old Aug 18, 2009 | 04:06 AM
  #48
Fink's Avatar
Rob's got a point, the only reason I'm not going that route is I want to eventually bed line interior so obviously I wouldn't be able to do that.
One thing I have looked into is aftermarket molded carpet/vinyl options.
A little bit pricey but for a complete OEM matched floor set, not too bad.
Thought I'd pass it one in case you hadn't seen it yet, I may go this route with some Dynamat/Peel-n-Seal instead of just bed liner.
Just a thought,
Fink
Old Aug 18, 2009 | 04:08 AM
  #49
peapicker's Avatar
Good Idea!
I traided axledeep a set of wheels for his interior and i ended up with enough of the factory sound dampening material to cover everything again. Probley not as good as what your suggesting, but lots cheaper! Thanks for the idea though, I will take all you have! If the noise is untolerable, may back up and do that.
Old Aug 18, 2009 | 04:16 AM
  #50
peapicker's Avatar
Hey Mr super moderator sir!
Exaclty how do ya get more that one pic in a single post? Sorry im new at this! Still tryin to figure it out.
Old Aug 18, 2009 | 04:17 AM
  #51
Fink's Avatar
Just use multiple [IMG]**filename/URL**[/IMG] tags in a single post.
I'm assuming you are hosting your pics somewhere like Photobucket, imageshack, etc...?
Fink
Old Aug 18, 2009 | 08:52 PM
  #52
RobD's Avatar
There were some guys over on www.diymobileaudio.com experimenting with things like elastomeric roof coatings with good results. Cheaper and works fairly well. I'm looking at it for damping the rear quarter panels.
Old Aug 19, 2009 | 03:57 AM
  #53
peapicker's Avatar
Thanks robD
If it is to loud when I gets them meaty tires on, definetaly be looking into that.
And 4x4fink, Ive just used the drag and drop method from photobucket. Gonna take me awhile to process that info! Thank you, I see what I can do.
Old Aug 19, 2009 | 04:00 AM
  #54
Fink's Avatar
When you're in Photobucket looking at the pictures in an album look right below the thumbnail of the pic and there should a box that says, "IMG code" next to it.
Copy and paste whatever is in the white box next to "IMG code" into a thread.
It already has the forum code (HTML) attached to it.
You can copy and paste as many of those "IMG code's" as you want into one post and they will all show up.
I can get a screenshot of what I'm talking about if that'd be easier.
Fink
Old Aug 19, 2009 | 04:18 AM
  #55
peapicker's Avatar
Thanks fink
I believe I can find that, thanks a bunch! Good lord im low tech! I it doest have the smell of gear oil on it im pretty much lost! Dude I really appreciate it
Old Aug 19, 2009 | 05:29 PM
  #56
peapicker's Avatar
Some more progress! Just about have it together. Rained out today
Thats a lot of stuff! I will never buy another with power options!
Wish all that crap was already in here!
All done with that one, just 4 more to go
Vapor barier is lookn good!
Heres my Taco if anyone likes this sort of stuff on here!
Old Aug 20, 2009 | 05:11 PM
  #57
peapicker's Avatar
Finally got this thing put back together!
ok heres a couple of before picks
And after about a mounth of sweatn! Finally!!!!!
What yaull think??
Old Aug 20, 2009 | 05:15 PM
  #58
peapicker's Avatar
Man im glad thats done, still have a few minor things to finish up! Be able to finish up tomorow! I hope!
Old Aug 20, 2009 | 05:23 PM
  #59
Fink's Avatar
It's a whole new rig dude!
Can I make a suggestion or two?
That thing would look badass if with the front grille trim and bumper painted black, as well as some classic 2nd gen rims painted black also.
I'd also get some cheap white LED lights for the reverse lights, that'd look so sweet dude.
You can tell how much time and work you put into that thing man, inspiring to see what good work can do for a rig.
Fink
Old Aug 20, 2009 | 05:30 PM
  #60
peapicker's Avatar
Hey fink!
Thats a good idea! Think I will have to do that, The grill would look better black. The front bumper is gonna hit the dumpster though, got one from tg on the way and the rear to match! o yea! Didn't know you could get led reverse lights, I will definataly look for some. And thanks Fink! Its nice to hear some positive words dude !! On the rims, are you talkn about the aluminum or steelies?
