oneIwilly's 1991 ex cab pickup Build-up Thread
Old Feb 23, 2012 | 03:21 PM
  #61
oneIwilly's Avatar
np205
I figured I would post a pic of the shift rail ready to be ground down for the twinstick.The blached out areas need removed.
Old Feb 23, 2012 | 03:25 PM
  #62
oneIwilly's Avatar
front wheel drive hi
Old Feb 27, 2012 | 02:34 PM
  #63
oneIwilly's Avatar
Steering
This is the 1 ton,inverted Y steering that I got from east coast gear supply.Needs to be cut and welded to length,but this seems like serious over kill.
Old Feb 27, 2012 | 02:48 PM
  #64
RMP8080's Avatar
nice, High steer?
Old Feb 27, 2012 | 03:02 PM
  #65
oneIwilly's Avatar
hi-steer
Yes,ballistic hi-steer arms.
Old Feb 27, 2012 | 03:12 PM
  #66
oneIwilly's Avatar
Oh yea,I actually had to pay money for the Y link.That brings the total cash outta pocket for this truck to about 1250$.
Old Feb 27, 2012 | 03:15 PM
  #67
RMP8080's Avatar
Thanks, looks good, I plan high steer in my truck
oh it's only money
Old Feb 28, 2012 | 08:16 PM
  #68
oneIwilly's Avatar
latest
On Sunday Jordan came up from Arlington and helped me get the np203 out of the truck.I didnt have the np205 painted or the twin shifters built yet,so the truck sits without a t case.I decided to try to start the next project.Cooling.I want the biggest radiator I can get in there, so I started cutting.I think I have figured out that the radiator from a 94-95 s10 4.3 will fit perfect,plus it has a tranny cooler.What do you all think?think?
Old Feb 29, 2012 | 02:24 PM
  #69
RMP8080's Avatar
I wonder if an extra radiator some where either on the truck would work to keep it cool?
Old Feb 29, 2012 | 09:54 PM
  #70
oneIwilly's Avatar
Radiator
This is the s 10 4.3 V6 radiator.It measures 32x16.5.With a little more cutting on the front end this should fit.I just hope it keeps things cool.Anybody have any info on how big of a radiator per cubic inch a guy needs?
Old Mar 2, 2012 | 09:32 AM
  #71
oneIwilly's Avatar
gm short water pump
Everyone at all of the parts stores and wrecking yards know that I am trying to build this truck for nothing.All of the big magazines do these budget builds where big name companys give them stuff for free.Im trying to do the same thing, to show it can be done for cheap.Yesterday Carl,a local guy who has been watching my build, decided that I needed a brand new GMB GM short waterpump to fit behind the s10 radiator.FREE Thanks Carl!
Old Mar 4, 2012 | 12:45 PM
  #72
oneIwilly's Avatar
Radiator
I spent a good part of my morning with a plasma cutter and a grinder.I made a piece of dimond plate to go in where the core sopport was and bolted it in and cut the core support out.Then cut cut cut.I got the s10 radiator to fit pretty good in the space I had.I still need to mount it completely but this is where it will sit.
Old Mar 4, 2012 | 12:47 PM
  #73
oneIwilly's Avatar
radiator
Old Mar 4, 2012 | 12:50 PM
  #74
oneIwilly's Avatar
frame
The radiator that came with the truck fit inside of this frame.
Old Mar 4, 2012 | 12:58 PM
  #75
oneIwilly's Avatar
water pump
This is the clearance between the long waterpump and the radiator,I understand that once I get the short pump on it will shave 1.25 inches off of this.I think ill be able to run a regular fan!
Old Mar 4, 2012 | 04:12 PM
  #76
1986yota4x4's Avatar
will the grill still clear the rad?
Old Mar 4, 2012 | 04:17 PM
  #77
RMP8080's Avatar
nice work, looks like the whole front is a radiator.......keep cool.......
Old Mar 4, 2012 | 04:28 PM
  #78
oneIwilly's Avatar
Grill
Alot of people I have talked to, that have done a similar swap have told me, keeping it cool would be a problem.It gets hot here in the summer.So I wanted the biggest slab of radiator I could squeeze in.It fit perfect with alot of cutting.And yes the grill clears fine also with some trimming to the back of the grill I could probably fit an electric fan too,which I will probably do.
Old Mar 5, 2012 | 07:55 PM
  #79
oneIwilly's Avatar
exhaust
So today My wonderful girlfriend bought me the ramhorn manifolds I needed to complete my exhaust 130$ this brings the total cost of the truck to 1380$.This also means I have all of the major parts to finish the truck,now I just need time to work on it!.
Old Mar 6, 2012 | 04:02 PM
  #80
oneIwilly's Avatar
crossmember
Nothing new on my truck,but I did build this handy crossmember for putting a 4.3 vortec and 5 spd in a nissan.
