malteserunner's 1987 4Runner Build-Up Thread
Old May 19, 2011 | 04:10 AM
  #381
Terrys87's Avatar
Just got done going through your build theread. You have got some great scenery pics in there. Wish I had a place like that to go wheeling.
Your engine is looking great. Glad to see you got it running. As far as the leaks goes, I dont think you are ever supposed to get it right the first time. At least that been my experience. No matter how hard I try, it still happens, and I have worked on quite a few 22res.
Great build and enjoy your wheeling shots.
Old May 19, 2011 | 05:32 AM
  #382
c0ugar69's Avatar
looks good, bet it runs great. ready for some wheelin!!!
Old May 19, 2011 | 08:26 AM
  #383
Philbert's Avatar
Looks great!
To mate the engine to the transmission, did you just use (tons of) general purpose grease on the transmission/spline, and "wedge" it in there until the bellhousing snugged up? And then fastened bolts of course? Is it like when you put on a timing cover and you just wiggle it enough so that the spline on the crankshaft and oil pump line up finally, after a few tries?
Here's another dumb question....the hook on the front of the 22RE is obvious, but where on the back of the engine do you mount the chain for hoisting??
-Phil
Old May 19, 2011 | 08:52 AM
  #384
ChefYota4x4's Avatar
HOLY CRAPOLI!.... THAT'S GREAT! Nice work, Adam, ... hope you get all the lil pesky leaks fixed without much drama and labor, lol.
Old May 19, 2011 | 11:16 AM
  #385
Outsane's Avatar
congrats, I wanna hear this quiet motor!
Old May 19, 2011 | 01:39 PM
  #386
Originally Posted by Philbert
Looks great!
-Phil
Looks like on the head, .....I was wondering the same thing, ...lil chills were had when I spied that! lol. I think I have pics of where i did mine. I wanted to get the motor out this time(short block) without removing the hood..... so I mounted the cable eyes a lil lower/driver side and middle/pass side, adjusted the cable and it fit JUST SO, coming out! lol. Sorry, ...just wanted to share, hahaha..... My bad, Adam,....I'll let you answer your own question lol.
Old May 19, 2011 | 09:49 PM
  #387
malteserunner's Avatar
Thanks for the compliments, guys! As far as the install/hoisting goes...no need for a lot of grease on the input shaft (you don't want that slinging all over your clutch), as long as the engine and tranny are at the right angle, they will mate together easily. Dbcfr made it look easy with the help of the leveler on the hoist. My engine hasn't got the hooks any more, and since an incident with an engine coming loose due to a failed hook, I don't really like using them anyway. I use the holes for the M10 bolts, and make sure they are snug. I just feel it's safer to have the chains fixed to the engine.
I put 25 miles on the 4Runner today, and everything looks and sounds good. My oil pressure reads about a quarter higher on the gauge than before, which is nice. I'll put another 300 miles on it this weekend, then mid week I will adjust the valves, re-torque the head, change the oil and flush the coolant. I'm also going to check the plugs to check if it's running rich or lean. I did notice a little quirk in my electric fan controller, so I may upgrade to a better unit. Otherwise, I can't wait to get out on the trails again.
Old May 20, 2011 | 09:44 AM
  #388
Philbert's Avatar
Thanks Adam for the details on lifting - you just use M10 bolts (and washers I'm guessing) to hook up to either end of the head? No worries about putting tension on the head/gasket seal?
Phil
Old May 20, 2011 | 11:51 AM
  #389
Phil
I would be more concerned with the threads or the head possibly stress fracturing due to the weight all being on the top end of the head bolt hole, ...but there ARE a couple back there that don't even get used, from what I remember(turbo application stuff? lol). Now you got me a lil freaked, Adam, lol.... Regarding the bracket..... Although, mine is cable/brackets and it is a SnapOn.... it's done 460's, etc., for my neighbor, ....should be fine I guess.
How's it runnin?
  #390
PS> Sorry for the tangent, Adam, ...but I must ask ...... HOW THE HECK ARE YOU, PHILBERT?????? LOL.
Old May 20, 2011 | 10:55 PM
  #391
I guess it's hard to tell in the pics, but the brackets attached to the chains on the leveler are bolted into the holes where the factory hooks would be. I don't see how it could make any difference bolting another bracket there, in place of the hooks, aside from there being no possibility of the chains coming loose. That is why I always prefer this method, plus I don't like those ugly hooks bolted to my motor.
I drove out of the mountains, into the valley today, racking up about 150 miles on the clock. The engine is running so sweet. I've got a little more noise from the valvetrain, as things are wearing in. The only problem I'm having is resisting the urge to stab the throttle. I'm truly amazed at the power this little motor is putting out, and I can't wait to take it higher in RPM's, and see what it's made of. I read so many different posts, here and other forums, from people running similar setups as mine. Some claim to have between 145 and 150 HP. Anyone care to comment on whether this is realistic? I suppose I should summarize all the engine mods into one post...
22RE Specs
-Block bored .020" over with matched pistons (stock quench)
-ENGNBLDR Street RV Head
-Oversized Stainless Valves
-268C cam
-Balanced Crank, Flywheel, Rods, Pistons, and Harmonic Balancer
-Downey Header with 2.25" Cat Back, Magnaflow Cat, and Flowmaster
-Supra AFM on passenger side
-Stock ignition, Toyota wires, cap and rotor
-NGK V-Power Plugs .035" gap
-Stock intake and throttle body
-Timing at 5 BTDC for now
With all this, do I need to use premium at the pump?
Old May 21, 2011 | 02:12 PM
  #392
Some pics of the finished product...
New motor mounts...
Old May 21, 2011 | 02:44 PM
  #393
Dbcfr's Avatar
125 to 130
Old May 23, 2011 | 10:41 AM
  #394
Outsane's Avatar
As far as premium gas goes, did you hear any pinging?
You could put a wideband on it once its ready for the throttle to be stabbed, and know for sure.
love that motor...and the set up
any idea's on MPG..
and how long did the motor mounts take to put in, unless you put them in with the motor....
Old May 23, 2011 | 11:51 AM
  #395
4runFreak's Avatar
Looking real good!
Old May 23, 2011 | 09:45 PM
  #396
450 miles into the break in period, and about ready to do the second oil change. I ordered Toyota oil filters today, that I'll be using from now on with this motor. Also, I'm going to get a fan control switch like Outsane used on his 4Runner, for my electric fan, so I can eliminate the Hayden controller I have now. Yesterday I had a small coolant leak, from the bypass hose on the lower intake to the throttle body. I got some bulk 5/16 coolant hose and routed it so it has less sharp bends. The hose has to be a custom fit, since my lower intake is off a 90 22RE and the upper intake is the original. I may switch to the later model upper intake in the future, since I read it flows slightly better.
any idea's on MPG..
I'm going to try premium at the next fill up, to see if it's any different. The motor sounds completely different than before, but I do hear a little pinging. But, I haven't messed with the timing yet. I'm loving the motor too... As far as mileage goes, I got 20 on it's first long trip out of the mountains (160 miles round trip) with the tires at 26 psi in front and 22 psi in the rear. I aired the tires back up to normal this morning.
Originally Posted by 4runFreak
Looking real good!
Thanks.
Old May 24, 2011 | 08:15 AM
  #397
Outsane's Avatar
holly crap..
I only get about 15mpg....
I need to do some more modding.. so far below are the differences between our motors..
22RE Specs
-Fuel injection (have parts, need fuel pump and time)
-Supra AFM on passenger side (I have an Supra AFM may need to swap internals)
-209K miles
Old May 24, 2011 | 12:33 PM
  #398
chancer6902's Avatar
clean!!
Very nice build!! I dig the engine rebuild, looks super clean. Do you plan on stickin with your suspension or are ya gonna change it up?
Old May 24, 2011 | 09:54 PM
  #399
In a perfect world, I'd find a smokin' deal on some TC longtravel, or maybe go with Blazeland. Time will tell, I suppose. The money I started to set aside for suspension is now under the hood, so I'm back to square one again. I do plan on swapping F150 springs in the rear sometime soon, but the front will have to wait. Thanks for the compliments.
Old May 24, 2011 | 10:04 PM
  #400
How bout a drive by video for all us junkies who love your rig??????? hahahaha.
