Magichelmt 1988 Pickup
Old Jul 30, 2013 | 08:03 AM
JeremyW94's Avatar
Need to sell me that inclinometer you picked up btw haha
Old Jul 30, 2013 | 08:11 AM
Magichelmt's Avatar
Hell I may be going to Jasper this weekend to pick up some axles. I'll trade you the inclino thing-a-ma-bob for a set of solid axles?!?!?!?!?!?!?
Old Jul 30, 2013 | 09:35 AM
JeremyW94's Avatar
Haha I don't have any solid axles around man, could always have cash for you though.
Old Aug 3, 2013 | 02:45 PM
Magichelmt's Avatar
So my buddy and I had a little road trip today. I think we scored very well. In total we got 4 axels, a transfer case, spare tire, gauge cluster with tach, and a bunch of other odds and ends. The front and rear that I bought are open 4.10 gears and I got the stock transfer case. I'll post better pics after I clean them up a bit this week
Old Aug 3, 2013 | 03:00 PM
  #25
JeremyW94's Avatar
Still need to sell me that inclinometer:p
  #26
JeremyW94's Avatar
But nice score man.
Old Aug 6, 2013 | 07:26 AM
  #27
bbrideau's Avatar
DAMN! can't find sweet EFF all where i am for Solid axles. I want one just in case some day i decide to go that route. that and i like to hoard yota parts haha
Old Aug 6, 2013 | 08:59 AM
  #28
Magichelmt's Avatar
yeah I did not need the rear end as my truck is IFS and has the wider axle in the back, but for the money he wanted I could not leave it there. I gave $300 for the the two axles, transfer case, tire/rim, & a bunch of random parts. If nothing else I'll have a spare center chunk I can set up.
Old Aug 7, 2013 | 10:00 AM
  #29
bbrideau's Avatar
damn, sweet deal man
Old Aug 13, 2013 | 08:54 AM
  #30
Magichelmt's Avatar
We got the new IFS center chunk in last night. I now have working 4WD again. This weekend I plan to start going through the solid front axle I bought. No timeline on the SAS yet, but I want to go through it and pick up everything I'll need. I am going to order a TG doubler set up and all the goodies. It's only money right....
Old Aug 25, 2013 | 07:16 PM
  #31
Magichelmt's Avatar
So I ordered the TG dual case setup and some rock sliders while they were on clearance. I started looking at skid plates. When I look under my truck the first thing I see is that giant anchor AKA cross member. If I decided to attempt a flat belly do I need to lift the engine? This truck has a 3" body lift already. It seems like it is too much. I have been thinking of dropping it down to 2". I have been reading and searching here and on pirate for hours. My brain hurts.
Old Aug 26, 2013 | 04:46 PM
  #32
BajaYota88's Avatar
im new to the forum and the world of toyotas but i also have an 88 pickup and i was wondering if you could point me in the right direction for info on the sas swap.. any info would be awesome.. pm me info so we dont get away from the OP please and thank you
Old Sep 10, 2013 | 11:13 AM
  #33
Magichelmt's Avatar
Well the acquisitions keep piling up. I sold my narrow rear end and made some money off it and turned around and ordered the rebuild kit for the front axle, gusset kit, and some armor. New Motive 5.29 gears and 4cyl setups getting picked up today! I may have everything to do this in November.
Old Sep 10, 2013 | 06:37 PM
  #34
Magichelmt's Avatar
OK I picked up the Motive 5.29 gears, install kits and some trail gear solid pinion spacers. Not too bad for less than $400!
Old Sep 11, 2013 | 07:48 AM
  #35
Gizler00's Avatar
Nice truck you have there. And what a great deal on the Axles and other parts!! Looks like you are headed in the right direction with your SAS plans. Cant wait to see this project progress.
Old Sep 25, 2013 | 05:10 PM
  #36
Magichelmt's Avatar
And the parts keep coming! I got a few more trail gear items tonight.
Axle Gusset upper kit, 2 X Diff Armor Large, 6 Leg Kit, Creeper Gussets Kit, Knuckle Sandwich Bundle.
I am going to do some welding this weekend!
Old Sep 25, 2013 | 05:50 PM
  #37
kornhuskerwizard's Avatar
Inclinometers sell for $300??!! Wow. That ifs front gear is toast. Wouldnt be much to fix it, but sas would be better!!
Old Oct 12, 2013 | 09:02 PM
  #38
Magichelmt's Avatar
Got busy on the truck this weekend. I cut the 3" body lift down to a 1.5" on the cab. I then got side tracked onto other stuff. I will get the bed cut down this week. I did not have the bolts to do it. I replaced my exhaust manifold gasket only to find the rear most stud stripped out. I will get a helicoil this week. Then we finally welded up my trail gear rock sliders. I will try and keep working on the little things while I stockpile the parts to do the SAS. Next major purchase will be dirty 30's.
My little truck on the right next to my friends monster.
Old Nov 3, 2013 | 11:26 AM
  #39
Magichelmt's Avatar
OK so time out on buying toys for now as I have a head gasket that needs replacing. I was loosing coolant so I borrowed the coolant system pressure testing set up from Advanced auto parts. I found 3 leaking hoses and a weeping leak between the head and block under spark plug number one on the exhaust side. At least if I have to pull the head I can put a helicoil in to the head on cylinder number 4 on the bench instead of against the fire wall. Looks like I have a full week on my plate.
Old Nov 6, 2013 | 04:24 PM
  #40
Magichelmt's Avatar
Well pulled the head off the motor this week. I will replace all the gaskets and seals in the top end. Maybe the timing chain as well. Learning as I go. Name:  411433C9-E1F8-4AFE-9100-E848D9989900-339-00000095376F46AA_zps1249c8af.jpg
Size:  126.9 KB Name:  BAF1A5F6-443F-44EE-B9CF-83C1A50A4962-339-00000095252788F9_zps58124242.jpg
Size:  134.9 KB Name:  C96937BC-58D7-4441-B785-5C6E863FDBB2-339-000000952DC2CDA9_zps7ce7077a.jpg
mskalmus
May 28, 2017 07:51 AM
gary4runner
Sep 24, 2015 12:53 AM
andrewtexas123
Jul 14, 2015 04:29 AM
88yodabasket
Jul 13, 2015 01:32 PM
