Locked_SR5 1987 4Runner Build-Up Thread
Old May 9, 2012 | 09:01 PM
  #101
RMP8080's Avatar
Every good work, coming along nicely
Old May 10, 2012 | 06:29 AM
  #102
ToyoTech559's Avatar
Originally Posted by Locked_SR5
The material is a foam backed vinyl that will tear once you try to remove it and couldn't think of a way to save it. Once I'm done I'll use some new automotive vinyl and recover.. BTW nice build.. who makes that rear bumper with tire carrier that was in your build?
ahh. figures it wasnt that easy lol
the bumper is from CBI as a weld together kit. fyi, price doesnt include tire carrier, just bumper. they can weld it together for you at more $
http://www.cbioffroadfab.com/store/i...2f9ac8cadd598a
Old May 10, 2012 | 02:38 PM
  #103
Locked_SR5's Avatar
PS> Happy Belated Bday
Hawaii, eh? :IWISHSMILEY: hahaha.
Chef... Thanks!! It ended being a good one too!
Old May 10, 2012 | 02:43 PM
  #104
Locked_SR5's Avatar
Thanks, Never heard of them before. Its actually better that its a weld together kit. Do you know of a good source where I could get the tire rack parts? I eventually would like to put an F150 tank where the spare tire carrier is now..
Old May 11, 2012 | 07:03 PM
  #105
you can buy the tire carrier parts from them as well. CBI has been lazy on updating that page. i think its because the lack of demand.
with the spare out. there is tons of room for a fuel tank!!
Old May 12, 2012 | 04:51 PM
  #106
rustED's Avatar
Just wanted to say I really like your build, you've got some really good fab skills, I look forward to seeing your top when its finished!
Old May 13, 2012 | 12:53 AM
  #107
Locked_SR5's Avatar
Thanks for the compliment. This is the first time I really tore in to such a huge project and undertaking.. As far as the top goes.. I have all the major work done with it and may do a mock-up to show you guys how it looks on the runner (i'll save the finish body work until I repaint the truck to factory colors). I think its going to look really nice and its something I haven't seen anyone try yet..
Things to do..
Get gear oil in the dual cases, headgasket replacement, redo the exhaust, tighten all bolts to spec and get truck ready for smog... Then 3.4 Swap!!
I'm happy with the progress so far and got all of expensive stuff out of the way. Now its just all the small things that I still want to do, but before that I want to make it drivable, and before that I need to finish a couple of term papers...
Old May 13, 2012 | 02:26 PM
  #108
Locked_SR5's Avatar
OK.. Had a bad case of writers' block, so I haven't worked on my paper yet... However, I was curious to see what my Runner looked like with the top off... I must say it looks purdy...
another angle
With the top off I wanted to mock up my half top to check out the fit and how it actually looked on the truck.. so for those who were curious on the top, here you go.
Old May 13, 2012 | 05:29 PM
  #109
rustED's Avatar
Dude, that looks sick!!!! When you get it done and paint it, its going to look so sweet! Hope you don't mind, but I might have to copy it!, LOL!
Old May 14, 2012 | 05:23 PM
  #110
good job on the top.
Old May 14, 2012 | 05:49 PM
  #111
thspittingllama's Avatar
wow i have never seen those tripple sticks before. i really like that! im going to have to add them to my build plans. your rig is way sweet, adds another point to my 4runner over pickup delema.
Old May 19, 2012 | 11:13 AM
  #112
Locked_SR5's Avatar
Thanks everyone for the positive comments... As of now I wont be working on the top until I get ready for paint.. I have to SMOG the truck in August, so I have to get the truck prepped so I can pass, which equals a new head gasket kit, reinstall the exhaust and tightening the bolts up to spec. Then I can start prepping the 3.4 swap.. Things I need for prep is new timing belt, water pump, clutch, V-6 motor mounts for the frame, passenger side exhaust for BAR, cross over pipe after BAR.. Anyone know how strict the Sacramento area BAR personnel are? Or is it case by case ..
Old May 19, 2012 | 11:39 AM
  #113
Locked_SR5's Avatar
Poser Shots..
I was finally able to move the truck for the first time in over 3 months and had to do the obligatory poser flex shots.. I'm not sure of the maximum amount of flex I should get.. Does anyone have an idea of what it should be with the springs and shocks I'm running? (14" shocks with 3"TG/RUFF hybrids in front and 12" shocks and 63" chevy's in the rear)..
Old May 19, 2012 | 05:33 PM
  #114
rustED's Avatar
Nice flex pics! I've seen some yota's with similiar suspension setups and wouldn't be surprised if you could lift the rear tire twice that height, nice work!....looking at your pics kinda makes me wish I'd gotten 35's for my build tho, LOL.
Old May 20, 2012 | 04:08 PM
  #115
Locked_SR5's Avatar
So, just yesterday I ordered one of these and hopefully i should get it on Weds.
http://www.sky-manufacturing.com/new...uct.php?id=142
I'll post pics once I get it installed and set up..
I'll finally be able to park on a incline..
Old Jun 4, 2012 | 07:42 PM
  #116
Locked_SR5's Avatar
Here's a follow up on some of the things I've been working on.. I was able to install the transfer case parking painted and installed. Additionally, I was able to weld in a bracket to hold the front portion of parking brake cable in place (cut out the rear torsion bar brackets from the frame).
Here are a couple of pictures. IMO, I believe the SKY parking brake is a better built unit when compare to the All-pro model for a couple of reasons. 1) it has a built in skid plate, and 2) the parking brake rotor bolt holes are threaded (provides a peace of mind that the driveline bolts and nuts will not fall off).
Now with the drivetrain complete, its now time to start on the headgasket repair.
I ordered a kit from engnbldr with new head bolts and all the associated gaskets and seals. Has anyone heard of well the headgaskets are from him or have heard of failures? the whole kit was only 66.00 with free shipping..
Next on my to do's is to start labeling the hoses and start taking pictures of the engine bay. Does anyone have a recommended link on headgasket replacement and what is the biggest priority when having the head looked at?
thanks
Old Jun 4, 2012 | 09:22 PM
  #117
looking good. nice flex test.
wow that is a cheap headgasket kit. i cant say much about it since i no nothing about it. as far as the head goes. just send it in for the usual. leak test, cracks and if it all checks out decked.
Old Jun 4, 2012 | 09:50 PM
  #118
1986yota4x4's Avatar
this build is awesome! would someone be able to use ifs rotors and calipers for the rear disk brakes?
Old Jun 5, 2012 | 04:23 PM
  #119
Locked_SR5's Avatar
I actually read something not too long ago that someone did use IFS rotors and brakes on the rear. However, I do not know if they are the same type I used or if they were custom made, etc.. so more research is needed.
Old Jun 5, 2012 | 05:35 PM
  #120
Locked_SR5's Avatar
As posted earlier. I'm finished with the driveline part of the build and it is now time to start focusing on the engine and headgasket.
I took pictures of the engine bay and a few close ups of the vacuum gauges and started to removed the valve cover. I was curious to see how it was going to look since the previous PO said the motor was rebuilt about 27K miles ago.. so with that said I took of the cover and much to my surprise, it was really cleat underneath and most likely the PO was telling the truth, the engine was rebuilt. Oh, forgot to mention I did a compression check. With a warm engine, all spark plugs removed, cold injector disabled, and WOT, I checked all cylinders and the compression reading were #1 160, #2 160, #3 165, and #4 162. Not quite to specs, but with a blown gasket, they seem alright.
Ok, back to the valve cover.. This is what I saw when I removed.. Pretty clean, eh?
Also checked the timing chain and the timing chain guides. The chain shows little to no signs of wear and both sides of the timing chain guides are intact and show little to no signs of wear. This, what the PO previously mentioned, is another reason why I feel this is a recently rebuilt motor.
Timing chain guides
Right side
Left side
The cam and valve springs were in good condition and also showed little to no wear.
I'll continue to post more pics of the progress on the head gasket repair.. On a side note, I plan on purchasing the DIY CBI offroad rear bumper for the runner sometime in the next couple of months (thanks Toyo) and have some round tubing tubing bent to match the wheel wells and welded to the front and rear bumpers and to the rocksliders. I want these to be removable, so I plan on using the interlocking tube clamps from TG at the connection points.
Enjoy..
