JusToyotAdkins' 1986 Toyota 4x4 Build
Old Jul 28, 2014 | 01:21 AM
  #81
Terrys87's Avatar
The diff extenders is a very useful upgrade. Easy to do as well. I need to see if my tag lights work. Not sure if I ever checked them. Thanks for reminding me.
Old Jul 28, 2014 | 04:16 AM
  #82
JusToyotAdkins's Avatar
Yeah it was a simple diy. And I picked up those tag lights at oriellys.
Old Aug 1, 2014 | 02:58 PM
  #83
Did the quick release door mod with the trailer hitch pins. It takes longer than you think to line the hinges up, but i guess it's better than having to take the fender off. I was only able to do the passenger side but the door still shuts great.
I also ordered a set off cragar d windows for the rig
Old Aug 2, 2014 | 11:03 AM
  #84
rustED's Avatar
Nice work on the quick release doors! Are you planning on running tube doors, or just go doorless? I like the wheels, they'll look sweet on your truck!
Old Aug 2, 2014 | 12:09 PM
  #85
Probably just doorless. There isn't much rock crawling around here
Old Aug 2, 2014 | 03:44 PM
  #86
My dad gave me his old tool box. Been wanting one for a good while now. It's gonna be extremely useful.
Also took a few nubie flex pics
Old Aug 7, 2014 | 05:00 PM
  #87
Just a little update...
I'm in process of replacing the rear shoes and wheel cylinders.
I really wish they were disk breaks all around.
I've got two of my four wheels on the way
Along with a set of tail lights
And a decal saying "Chicks Dig Body Damage"
Hopefully ordering the other two wheels this weekend then tires or BJ spacers
Old Aug 9, 2014 | 05:11 PM
  #88
Pretty new shoes and cylinders(little bit blurry)
Shiny remanufactured master cylinder
I'm having problems with bleeding the rear brakes, it seems as though they aren't getting pressure but the fronts are. Any suggestions????
And the new decal
Old Aug 11, 2014 | 01:35 AM
  #89
Terrys87's Avatar
Toyotas are a pain in the rear to bleed for me. Never had such problems in the past with other models. I bleed them and wait a few days and then do it again at a later time seems to work for me. Are you bleeding the Proportioning Valve on the passenger side of the frame on the rear?
Old Aug 11, 2014 | 04:34 AM
  #90
Yeah I was trying to do the brakes first then that last.
Old Aug 12, 2014 | 06:40 PM
  #91
Well yesterday i got bored and decided to tear into the the manual hubs.
I plan on cleaning up and painting the cover to stock colors(black and red)
Cleaning out all the old grease and replacing with new.
Along with new gaskets
And gasket maker on the studs so they don't back out
I started on the passenger side to find this yummy messs
Also you can see where i started taking out the studs and putting gasket maker on them.(I ringed off the top one )
This is the best i have for a before pic of the cover(not much)
And here's the outcome so far. Hopefully i won't scratch it up to bad putting it back together.
That's all for now.
Old Aug 12, 2014 | 11:42 PM
  #92
Terrys87's Avatar
Not only getting to looking better but getting the maintenance caught up on it so it is a lot really. It all adds up to a more dependable ride.
Old Aug 13, 2014 | 04:37 AM
  #93
I just don't wanna get my self caught out on a trail broke down. Which seems to be no fun. Haha
Old Aug 13, 2014 | 05:52 PM
  #94
Here's the drivers side but the passenger side looked just as bad..
Old Aug 14, 2014 | 04:37 PM
  #95
rustED's Avatar
Nice work on the hubs, they turned out great!
Old Aug 14, 2014 | 04:47 PM
  #96
rattlewagon's Avatar
Real nice work on the hubs! they cleaned up good!
Why were you taking the studs out to put gasket maker on them? Im a bit confused on that one.
Old Aug 14, 2014 | 06:30 PM
  #97
I heard they can back out over time and can put damage on the manual hubs. It's just gasket maker not thread lock so it won't be to hard to remove
Old Aug 15, 2014 | 10:00 PM
  #98
Having trouble with making the hub retract. It just wants to stay in one position when I turn the dial but I can hold the hub in my hand with a little pressure from the back and it will work fine...
Old Aug 17, 2014 | 09:26 AM
  #99
Found out it was the large spring was out of line
Old Aug 17, 2014 | 09:40 AM
  #100
kornhuskerwizard's Avatar
I've never seen a center cap like that before,the black plastic one that fits on your front wheel around the hub.nice work by the way.
