JDs 86' 4Runner DLX Restoration/Build
Old Jan 27, 2015 | 10:32 AM
tonkatruck_79's Avatar
Here is a shot of the cabinets and sub. I keep knocking the sub loose, so that is going to be changed. I think I will add onto the right cabinet and use the mounting holes for the loops on the bed to help secure it.
Old Jan 27, 2015 | 11:50 AM
RBX's Avatar
RBX
I like those boxes, might have to steel that idea when I create some rear cabinets for storage.
Old Jan 27, 2015 | 02:27 PM
84 yota dude's Avatar
Nice looking tan interior! So what's the problem with the vent? Don't you already have the dash out so you can access the vent? If not here are some great instructions on getting the dash removed.
From a member on here (Rds)
Hey,
technically you need to remove the far passenger vent to get to a bolt, but the vent is put in after the dash goes in, and held by 4 clips. I really cant see anyway to get these vents out cleanly from the front.. so I wouldn't even attempt it.
Luckily you can get around it though!
- remove the 6 or so screws along the edge above the glovebox and HVAC controls
- remove the plastic pod around the cluster. is held with another 4 or so screws.
- remove the cover off the altimeter. 2 screws
- open the glovebox and unhook the dust sheet thing (held with 3 clips).
The dash pad at this point will still have all the vents and altimeter attached.
- unbolt one nut on the edge closest to the driver, that was under the cluster cover/pod thing.
- look up under the dash behind the centre of the glovebox; there will be a small length of air-vent plumbing slipped to the pipework, and held with one screw. remove this to access the second nut up under the dash. This little section of vent plumbing is here for this exact reason.
- the dash is now held on with only one more bolt on the far passenger side (behind the vent!) and two clips (will slide off when pulled away).
Now carefully swing the dash around on this last bolt, so you can get to the bolt that was behind the vent.
- unplug the altimeter when you lift the dash up. the whole dash pad assembly will now be free.
Done.
Should take no more than half an hour or so. definitely easier than some cars!
Good luck!
Old Jan 27, 2015 | 03:21 PM
Hey,
SWEET! Thanks yota dude! This is exactly what I was looking for. I agree with Rds, trying to remove the vent from the front is damn near impossible. After 30 years, the plastic is very brittle and the soft dash is fully hardened. This is very helpful. I will give this a try this weekend. I plan to wrap the dash in the brown vinyl I used for those cabinets. Should all match quite nicely.
Cheers to you both!!
Old Jan 27, 2015 | 03:23 PM
  #25
Yeah man they make the rear of the truck a little more useful. The only kicker is it knocks out the deck light. I plan to add a Rigid A-series low intensity light on the base of the rollbar and wire it to the deck light. This way the switch on the dash is still functional, just have a way stronger light
Old Jan 27, 2015 | 03:25 PM
  #26
Anytime!! I was going to take the dash out of my old truck but never got around to it. But great directions non the less!
Old Jan 28, 2015 | 03:28 AM
  #27
Terrys87's Avatar
Your rear seat doesn't appear to me to be factory but still looks great. I like how it turned out. Your speaker boxes look great as well.
I will eventually give that a try and see if I can get the dash out without pulling the vent. Thanks for the info.
Old Jan 28, 2015 | 06:04 AM
  #28
Originally Posted by Terrys87
Your rear seat doesn't appear to me to be factory but still looks great. I like how it turned out. Your speaker boxes look great as well. I will eventually give that a try and see if I can get the dash out without pulling the vent. Thanks for the info.
That's the rear seat that came with my truck Terry. It's being removed and replaced with the split rear from my 84.
Old Jan 30, 2015 | 06:55 AM
  #29
AZkid's Avatar
I'm going to say that rear seat is from the factory. I have that same exact seat in mine. I like the boxes! Maybe oneday I'll see you running around town, you live up by me. Post pics of the scoobie.
Old Jan 30, 2015 | 11:41 AM
  #30
Cool sounds good man! Yeah I often go out by Cow Town and the other trails off Lake Pleasant Blvd. Name:  03D4FB1F-1E2D-451B-B466-153192238DAA_zpsdxiavc0e.jpg
Old Jan 30, 2015 | 05:42 PM
  #31
Well yesterday sucked. First accident in 19 years of driving. Thankfully the recently installed rock armor took the brunt of it. The rear axle was dislodged and passenger leaf bolt was sheared off. Fabbed something up to get all the leafs back in line and realigned the rear today. All in all I think the rig is gonna be ok.
Attached Thumbnails JDs 86' 4Runner DLX Restoration/Build-image-739988130.jpg
  #32
All fixed.
Attached Thumbnails JDs 86' 4Runner DLX Restoration/Build-image-905356796.jpg
Old Jan 30, 2015 | 05:43 PM
  #33
Also took a peep at the SR5 seats. They are going to match the interior very well.
Attached Thumbnails JDs 86' 4Runner DLX Restoration/Build-image-3396069657.jpg
Old Jan 30, 2015 | 11:07 PM
  #34
I saw your subaru in the welcome thread of yours. That thing is sexy!! Glad your ok from that accident. Scary stuff. How did it happen? And any body damage? Nice looking seats btw too!
Old Jan 31, 2015 | 07:17 AM
  #35
AZkid's Avatar
Dang! Glad to hear everything is OK. The Subaru is sweet! that engine bay is super clean. If you ever want to go wheeling hit me up.
Old Jan 31, 2015 | 09:22 AM
  #36
Thanks! I was making a left turn through an intersection and a guy in the southbound lane hit my passenger side. Thankfully I'm higher than most vehicles especially cars. The BMW smashed into my rock slider and then knocked my axle out of place. No body damage at all. It's amazing how strong that armor is haha.
Attached Thumbnails JDs 86' 4Runner DLX Restoration/Build-image-1628398598.jpg
Old Jan 31, 2015 | 09:25 AM
  #37
Cool sounds good, I will do. I'm trying to get a group of five or so together for a weekend trip. I have a buddy with a lifted Legacy wagon. Thing is pretty sweet
Old Jan 31, 2015 | 04:23 PM
  #38
Wow sounds like it all happened so fast. Awesome there is no body damage though! Is the rear axle bent at all?
Old Jan 31, 2015 | 09:16 PM
  #39
Right?! I thought the same. Nah the rear axle seems fine. The leaf suffered the most. Had to bend the shackles straight and put a new stud through the leaf spring.
Old Feb 1, 2015 | 04:42 AM
  #40
Terrys87's Avatar
Glad to see you are ok from the accident. Seeing the axle that far back it could of been worse. That armor paid for itself already.
