James Woods' 88 Bucket Build
#122
Here is the rest of the rock garden, remember my truck has no power steering which is why my line gets a little screwed
http://www.youtube.com/watch?v=HdHjx2ZGcs8
#126
Im not worried about it right now, I plan on installing Trail Gears rock assault kit with hydraulic assist when I do the SAS. That is if I don't just go full hydraulic, only time and funds will tell.
#132
All you should really need is just power and ground, it needs a constant so it doesnt reset everytime you turn the truck off. I would just tee into the power for your radio and find a plug somewhere and go that way.
#137
So it looks like it is grounded on the cigarette lighter circuit and also gets constant power from the same circuit for the memory, then there is ground from the tail light circuit for what I am guessing to make it dim when the lights are turned on, and then you have the power for the light coming from the dome light circuit. Hope this helps
Edit-I got my grounds right but after I thought about it for a second, the power for the light would come from the cig lighter circuit and constant power for the memory would come from the dome light circuit as the dome light always has power and the cig lighter is a ignition fed power source.
[/quote]
