irab88's 1993 PickUp Build-Up Thread
Old Sep 19, 2011 | 08:46 PM
  #901
ChefYota4x4's Avatar
Sounds good, I'm gonna go get pics right now and then you can ........ oh, wait, you meant him^^ lol.... Jk, and YES, your "Spark Juice Skills" are SUWEET! lol.
Old Sep 21, 2011 | 08:05 AM
  #902
irab88's Avatar
scary moments yesterday:
first, i blew the turn signal fuse on the highway, so no signals for a good 5 miles. 4-ways still worked (i know they're on a different fuse, but that just means it's not the light's wiring that's bad)
then, i get done fueling up before i get on the road. i go to start it, and everything goes dead (like when you don't have the clutch pressed), except everything's still dead after i stop twisting the key. radio, clock, dash warning lights, outlets (never did check the headlights). i took off the stereo faceplate and the theft light was steady-on, as opposed to blinking like normal. i pushed buttons and kept trying, then it finally came back to normal.
driving down the freeway after that, the hood was loose. i forgot to push it back down. as i was heading down to a turn-out to close the hood, i smelled something like oil/grease on a hot exhaust pipe. it went away eventually.
i think all the electrical stuff is related, as in, it's been raining here, and all the fuses and circuitry for the problem areas are in the driver's kick-panel. time to go check for leaks
Old Sep 21, 2011 | 08:09 AM
  #903
toyospearo's Avatar
WOW
I had a similar day in my 82. Replaced the break master bled the system and I was at a stop sign and a lady rolled up next to me and said "your rear break lights aren't working!" Ironically they sensor gave out right after I swapped the master. Then I got on the freeway and my hood was unlocked and ready to fly open. I forgot to shut it all the way. THEN I am driving down my driveway and my alternator light goes on and the alternator is not charging. Turns out it was a bad wire.
Hopefully there are no more surprises with this thing.
When it rains it pours!
Old Sep 21, 2011 | 08:14 AM
  #904
Z's Confederate Toy's Avatar
Sounds like a nightmare day. I had a couple of those in dads 85 before I got my 87. It was a leaky windshield that caused our problems.
Old Sep 21, 2011 | 08:17 AM
  #905
irab88's Avatar
i'm thinking its the wires i ran for my indication light
thanks guys
Old Sep 21, 2011 | 10:12 AM
  #906
RBX's Avatar
RBX
That sucks. I hope it is obvious what the problem is, i have had electrical issues that resolved themselves, i don't like that.
Old Sep 21, 2011 | 10:19 AM
  #907
irab88's Avatar
rb- i forgot to mention, you'll need to cut the chokes like this to be able to fit the sensor:
Old Sep 21, 2011 | 10:26 AM
  #908
Wow, Ian, .... DEFINITELY scary! I hope you get it figured out and I know you'll have a good write up of what did/can go wrong. Best wishes on a quick resolution!
Old Sep 21, 2011 | 12:08 PM
  #909
irab88's Avatar
thanks mark. i pulled the kick panel off earlier, and found no appearant problems. i'll keep an eye on it, seeing if it happens again. the scary thing isn't that it happened, but rather that i have no clue about the cause
Old Sep 21, 2011 | 03:48 PM
  #910
Could it just be that there is an 'internal' wire issue? Meaning, within the insulation, as with many acutely developed Harness-to-ECU issues? Sounds like most 'ground/short' issues I've had.... And they were USUALLY pretty difficult to find when within the dash/chassis electrical......but still very 'findable'! lol.
Old Sep 21, 2011 | 04:25 PM
  #911
irab88's Avatar
i have a hunch of where it is, but not 100% sure. i'll see about tracking it down if it happens again
Old Sep 21, 2011 | 06:49 PM
  #912
RBX's Avatar
RBX
I hope you find it Ian, i know that stuff drives me crazy( not knowing).
Old Sep 21, 2011 | 08:39 PM
  #913
irab88's Avatar
(this was on the shoulder tonight, so i was just revving)
i noticed this after ~30 mins @50 mph. the needle moved with rpm, but that's as high as it went. maybe i just bumped the needle when the gauge was apart? jeez, i can't win! no ill-effects, noises, or smells... just what appears to be low oil pressure
Old Sep 22, 2011 | 03:45 AM
  #914
RBX's Avatar
RBX
Maybe oil sending unit is broken?
Old Sep 22, 2011 | 04:25 AM
  #915
irab88's Avatar
i hope that's all it is... grrr
Old Sep 22, 2011 | 04:29 AM
  #916
xxxtreme22r's Avatar
That's almost as low as mine goes (rebuilt engine) but only when idle at 700 rpm and engine hot. It that your CEL on?
Old Sep 22, 2011 | 04:31 AM
  #917
irab88's Avatar
nope. i'll check for codes this morning
Old Sep 22, 2011 | 04:35 AM
  #918
I see seat belt and anti lock on, what's that other light? IIRC these "sr5" gauges don't have an idiot light for low oil pressure, not sure if low oil pressure triggers a cel or not on the sr5 gauges.
Old Sep 22, 2011 | 04:41 AM
  #919
irab88's Avatar
the "antilock" is the fan indicator. seatbelt and parking brake are the only other two lit up, as i was parked and getting out. like i said, nothing was abnormal except the gauge, which leads me to believe it's the sender or gauge itself
Old Sep 22, 2011 | 04:46 AM
  #920
LMAO @ antilock. Sounds like something I would do. Which reminds me, now I know what I am gonna do with those LED's (ECT) on the auto trans sr5's in mine to re-purpose them. Green low and red high. I was gonna use em as fog light indicators, but I think I will use my deck lamp switch I picked up a while ago for that. If I can find it.
