irab88's 1993 PickUp Build-Up Thread
Old Jul 20, 2011 | 12:37 PM
  #721
irab88's Avatar
Originally Posted by 4ever4running
So do you have any experience with changing out the timing belt, water pump, etc. in a 3rd generation 4Runner? If so, I may wait to do mine and commission your help after I move up to the D.C. area...
i do not. but since looking it up, it doesn't look too hard. i don't need to take anything apart or drain anything (unless i do the water/oil pumps, which i'm not). if you want to, i'm willing to come over one weekend and help you out. like i said, shouldn't take too long
...Wow that looks brand new, nice find!
thanks. scouring ebay and craigslist paid off. and with free shipping, too!
Originally Posted by alfio
hey ian,
two quick questions: a) can you explain the no-kickback diode in your 'aux-box' and b) what are your plans for the center console?
i have a 4runner console waiting to be installed between the buckets i put into my truck (also from a 4runner, see my sig) and i wanted to set it up so that my CB set up was hidden inside the console but i'm still working out the details.
a) when you activate the solenoid, a steel rod is magnetized and pulled to the contacts by a coil of wire. when you turn it off, the spring inside the solenoid pushes the rod back through the coil of wire. however, since the rod was slightly magnetized, it produces a short burst of high voltage in the coil. without the diode, this is like sending a static shock to everything else in that circuit. the diode shorts this voltage spike, or kickback, so there is no danger to the rest of the circuit
b)i plan on hiding a bunch of stuff in the console, namely my cb. however, i have a cobra 75 wx/st. the "box" for it is smaller than a deck of cards, and all the controls are on the mic itself (display, ptt, squeltch, scan, 9/19, etc). that makes mounting it easy, as i only have to find somewhere to mount the mike, not a whole box like most cb's. and as for the switches below: compressor, locker, and lights
mounting idea for the cb:
Old Jul 22, 2011 | 06:26 AM
  #722
4ever4running's Avatar
Cool, that sounds like a plan to me. I wanted to try to get it done before the trip, but I don't think I am going to have the time or the $$...
Gotta love craigslist! I have found a ton of stuff for killer deals.
Old Jul 22, 2011 | 08:34 AM
  #723
irab88's Avatar
i have a bit of a problem. my passenger aal keeps wanting to slide out. any ideas on how to keep it from rotating?
(ignore the brake stuff)
Old Jul 22, 2011 | 08:47 AM
  #724
xxxtreme22r's Avatar
might be because the center pin isn't tight enough.
Old Jul 22, 2011 | 10:08 AM
  #725
Lumpy's Avatar
Did it break? I have one that does that but it's broken...so a wire coat hanger to the rescue. For now...
Old Jul 22, 2011 | 10:18 AM
  #726
irab88's Avatar
it's not broken, but i like the coat hanger idea
Old Jul 25, 2011 | 08:35 PM
  #727
irab88's Avatar
Old Jul 26, 2011 | 05:07 AM
  #728
RBX's Avatar
RBX
Are you going to install the front piece that goes around the shifters also. I don't recall if the trucks had just the carpet to the rubber boot or the plastic frame and decorative boot cover.
Old Jul 26, 2011 | 05:50 AM
  #729
irab88's Avatar
there are frames, but i'm not putting it in. i'll be making a front-end cap for this
Old Jul 26, 2011 | 06:23 AM
  #730
WD_40's Avatar
What did that console come out of?
Old Jul 26, 2011 | 07:45 AM
  #731
irab88's Avatar
ya know, i don't remember. though i know some of them come out of sr5 ext-cab 2nd gen pickups and 2-door 4runners. and they're hard to come by. there's a guy selling a blue one on here without it's lid
Old Jul 26, 2011 | 07:55 AM
  #732
irab88's Avatar
quick stop for some bolts and finding the holes with a skewer makes quick work of installation
Old Jul 26, 2011 | 07:59 AM
  #733
RBX's Avatar
RBX
There are two u shaped brackets you could easily make with some aluminum stock from home depot, just sayin.
That console looks like it is out of a 2nd gen runner
Old Jul 26, 2011 | 08:14 AM
  #734
irab88's Avatar
"two u shaped brackets"? where do they go?
edit: mine mounts to the trans tunnel with 4 m6-1.0 bolts, like in this diagram:
Old Jul 26, 2011 | 10:29 AM
  #735
RBX's Avatar
RBX
The brackets are more shaped like this l_____l. The front have tabs from the tunnel ram, but I would fab a bracket if you don't have them. I'll see if I can snap a shot later.
Old Jul 26, 2011 | 10:35 AM
  #736
irab88's Avatar
i only have the 4 holes in the bottom of the console and the front two holes that connect it to the shifter trim. are the front two where the bracket attaches?
like part #58991 in the picture below?
Old Jul 26, 2011 | 03:20 PM
  #737
RBX's Avatar
RBX
thats it ian, the shift trim slides into the console
This screw is what attaches to the tabs on the tunnel ram, so you could just make another bracket for the front and attach it to the tunnel ram, or let it float and see how that works
  #738
RBX's Avatar
RBX
oops double post
Old Jul 26, 2011 | 03:28 PM
  #739
irab88's Avatar
yeah, i know about the trim. thanks for the pics. i'm not going to put it on because it would interfere with my power outlets. i'll put an end cap on soon enough
Old Jul 27, 2011 | 05:34 AM
  #740
irab88's Avatar
moar pikturs!
i'll make a cap for this end:
