irab88's 1993 PickUp Build-Up Thread
Old Apr 6, 2011 | 09:44 AM
  #561
irab88's Avatar
yup. eg- my blue-sea fuse box can handle a max of 125 amps total, so i'll put a ~125 amp fuse(able link) between the box and the battery. i'll also have a higher amperage fuse in line with the stock fuse box, just in case the cable decides to short out (because of the battery-intake swap)
Old Apr 28, 2011 | 09:12 AM
  #562
irab88's Avatar
just for fun...
Old Apr 28, 2011 | 09:23 AM
  #563
xxxtreme22r's Avatar
^^^^ haha I gave Ian the photoshop bug.
Old Apr 28, 2011 | 09:59 AM
  #564
RBX's Avatar
RBX
Ian try raising the black up on the wheel wells a few more inches.
I like it.
Old Apr 28, 2011 | 11:07 AM
  #565
irab88's Avatar
haha... more like the gimp bug. dam, that actually sounds like a real thing
I like it.
i'll try it out... i'm not going to be painting it anytime soon. the next thing i'ma paint is the intake chamber followed by my trailer
oh, and i got the washers today. oh it's soooo nice to be done!!!!
Old Apr 28, 2011 | 02:41 PM
  #566
4ever4running's Avatar
I like it.
I think he means something like this...
Old Apr 28, 2011 | 02:48 PM
  #567
irab88's Avatar
i was wondering when you'd post up your rig... nice! did someone draw it up for ya?
Old Apr 28, 2011 | 05:07 PM
  #568
irab88's Avatar
... like this, maybe?
Old Apr 28, 2011 | 05:16 PM
  #569
87hillbillyoter's Avatar
i like it red and black are the best colors
Old Apr 28, 2011 | 06:03 PM
  #570
RBX's Avatar
RBX
Yes like that. Now through on some nicer bigger shoes, and loose the sag. Hahaha
Old Apr 28, 2011 | 06:11 PM
  #571
irab88's Avatar
gee, wonder why you like them so much hah
Old Apr 28, 2011 | 06:14 PM
  #572
irab88's Avatar
that's before the aal's and t-bar crank
Old Apr 29, 2011 | 05:44 AM
  #573
Haha thanks! I saw a thread where a guy did the same thing and it looked awesome so when I bought my sport hood, I did the hood and the rocker panels at the same time.
Nice! I would go with something like that. Given the opportunity to do mine again, I would have gone a little higher on the wheel wells like this.
Old Apr 29, 2011 | 05:58 AM
  #574
irab88's Avatar
yeah, i heard the guy who drew it up for ya was a real loony
https://www.yotatech.com/forums/f2/f...l#post51582203
Old May 3, 2011 | 08:57 AM
  #575
irab88's Avatar
i've been planning out one of my next mods; the e-fan. i've created some logic here. the fan only needs to run if there is flow through the radiator. the thermostat controls the flow, so it would make sense to put the temp sensor in the t-stat housing, right? i've seen some housings with a tapped section for a sensor, and was wondering either where to get one, or what to search for. anyone know?
(like the one in this pic: )
Old May 3, 2011 | 09:14 AM
  #576
Yeah man that poor guy was off his rocker
This may be a dumb question, but what is the point of an e-fan? is is just to save gas because the engine does not have to work to pull the fan or is there some other benefit?
Old May 3, 2011 | 09:22 AM
  #577
irab88's Avatar
mechanical fans are always turning. this robs a little power under every condition. also, the fan clutch is dumb. if the clutch gets hot (not necessarily the coolant), the fan will turn on, even if the radiator is cool enough.
with an electric fan, it measures temperature right from the coolant, so it only turns on if the coolant needs to be cooled. so at highway speeds, when there's plenty of airflow around the radiator, there's no need for the fan, so it doesn't turn on.
also, the e-fan is silent when not in use
Old May 3, 2011 | 09:26 AM
  #578
Not to mention when doing water crossings although you would think an efan to be a drawback, but since it doesn't always spin, you turn the fan off manually and it won't fling water/mud etc etc all over the engine bay.
Old May 3, 2011 | 09:45 AM
  #579
Oh okay, that makes a lot of sense. Sounds like a pretty useful mod. Make sure to keep us updated on your progress and install, I am curious to find out how much they cost and how hard/easy they are to install.
Old May 3, 2011 | 10:01 AM
  #580
irab88's Avatar
sure thing. once i start the work on the mod, i'll be taking a bunch of pics. i've read that it's a relatively easy mod, and those who have done it love it. i need to upgrade the electrical first (i'll do some more work on that this weekend) to match the 140 amp output of my gm alternator. that's another nice swap, almost bolt-in, too.
