FSM Help
Old May 20, 2016 | 02:08 PM
n0idx80's Avatar
FSM Help
Hi Guys,
I haven't posted in long while. Been doing the buildup for the past 2 years and am close to finished. I have an 87 4runner with an 88 donor body. While rewiring everything, something is crossed and causing continuity across everything. Basically if I connect the positive cable to the batt I get continuity through the engine body and to the neg cable. I am trying to eliminate circuits but all I have is an 85 fsm which is missing a full wiring diagrams, and a crappy Haynes manual. I won't waste anymore of your reading time, but if someone can dropbox or email me a pdf of the 87 FSM I would be greatly in your debt. I'll post some eyecandy as a trade. Thanks,
Michael
Old May 20, 2016 | 02:17 PM
n0idx80's Avatar
Attached Thumbnails FSM Help-image-704583419.jpg   FSM Help-image-3982779897.jpg   FSM Help-image-280071238.jpg   FSM Help-image-3783458707.jpg
Old May 20, 2016 | 02:20 PM
n0idx80's Avatar
I've got more but here's eye candy to start.
Attached Thumbnails FSM Help-image-1979026096.jpg   FSM Help-image-1160985400.jpg   FSM Help-image-398472047.jpg
Old May 20, 2016 | 02:34 PM
millball's Avatar
I can't help with a wiring diagram, but have you removed every fuse and relay and tested for continuity then??
You might be able to narrow the problem down some by adding one thing back at a time.
Old May 20, 2016 | 02:36 PM
n0idx80's Avatar
Isolation of circuits is in progress...It would just really help to have the diagrams
Old May 22, 2016 | 07:22 PM
n0idx80's Avatar
Just wanted to say I could still use the fsm but thanks for the reply. The circuit was the dome light, radio, and courtesy door lock. There were some poorly soldered wires which were apparently shorting everything out.
Now just have to finish the engine and wait for parts.
Old May 23, 2016 | 11:52 AM
Justin Lenhardt's Avatar
I just found this link in CombatCarl's signature, and managed to get myself 93 pickup FSM, hope it helps you:
Old May 31, 2016 | 10:47 AM
n0idx80's Avatar
Thanks Justin. Their link is bad for my year though.
Old May 31, 2016 | 10:49 AM
n0idx80's Avatar
More pics
Before
Attached Thumbnails FSM Help-image-3558194237.jpg   FSM Help-image-3995255163.jpg
Old May 31, 2016 | 10:53 AM
n0idx80's Avatar
After
Attached Thumbnails FSM Help-image-2957017581.jpg   FSM Help-image-2753922089.jpg   FSM Help-image-1421766502.jpg   FSM Help-image-3954576985.jpg   FSM Help-image-233855056.jpg
Old May 31, 2016 | 11:10 AM
Damn dude, looks incredibly clean. Did you paint the cover yourself? Sorry the link doesn't work.
Old Jun 1, 2016 | 04:05 AM
junk4u's Avatar
If you still need the FSM PM me I could possibly help you
Old Jun 1, 2016 | 07:40 AM
n0idx80's Avatar
I did do the cover and plenum. I taped and painted using the rattle can engine enamel that was about $6 at autozone and then used a little touchup Toyota white from Toyota.
Old Jun 1, 2016 | 08:07 AM
junk4u's Avatar
PM and Email sent
Old Jun 1, 2016 | 01:45 PM
dropzone's Avatar
Fossilized
1987 service manual
http://www.ebay.com/itm/1987-TOYOTA-...dXTj18&vxp=mtr
admiralnahohkta
Mar 1, 2020 01:44 PM
Dismalbogs
Feb 26, 2016 07:08 PM
jeepfreak4648
Feb 26, 2016 07:16 AM
jeepfreak4648
Feb 26, 2016 05:39 AM
