dark_fairytales 1986 Pickup Build-Up Thread
Old Dec 24, 2011 | 09:14 AM
  #141
dark_fairytales's Avatar
They may push the rearend to the sky, but.... If you notice I bought the Ruffstuff Frenched Hangers. This means in the future, If I find the rear is to high for my liking, or setup. I can cut the Hangers off and then french them into the frame. There is also a lot of adjustment you can achieve with the shackle placement, or the type of shackles you use.
I am still working with the philosophy of working with what you have and improve what needs improving.
Old Dec 24, 2011 | 09:47 AM
  #142
MaK92-4RnR's Avatar
It probably wouldnt be bad if you had some weight in the back. remember, you are bumperless, sliderless, and nothing in the back. If you add all that, it'll lower it quite a bit, im sure.
Old Dec 26, 2011 | 08:22 PM
  #143
Made some more progress today. The plan today, was too mockup the drivers side chevy spring and make sure that the Hangers were true and parallel.
So after getting the frame to sit on the Jack-stands and removing the rear wheels. I started loosening all of the fasteners to the driver side rear suspension. Sense everything has been off twice before in the past, the disassemble went graceful. Here are some pictures of the drivers side completely removed and the Jack relaxed to make room for the chevy spring.
I then placed the 63" spring in position. At this point I was very happy with my work. The tacked Hanger stayed absolutely rigid and the tack welds held firm. I needed to mockup the U-bolts and U-bolt plate, so too trace an outline where I would need to grind away at the Leaf-spring. For those of you who may not know. The chevy Leaf-spring is wider then the stock Toyota springs. For the U-bolts to fit in the proper location. You must grind away at the sides of the Leaf-spring. Here is a picture of the traced outline.
There is very little grinding that needs to be done on both sides. Here is an example of how little grinding is required too get the Chevy's to fit a Toyota U-bolt flip kit.
When I finished with the needed grinding. I began to remove the locator Pin so I could take the overload leaf out of the spring pack. I then discovered during the reassembly of the spring pack, that I needed too make threads further down the shank of the locator pin, or the pack would not be tightened up properly. Once the Pack was all back together, I mocked up the Chevy again too look at Shackle-hanger placement and ride height. I put the wheels back on and removed the Jack-stands. Then relaxed the Jack so the truck could sit on the new spring. You will see a 4x4 between the frame and the spring-eye where the shackle will be placed. Here are a few pictures of the truck sitting on all fours with the new spring and no shackle.
I was truly happy too see that everything turned out strait. There will be a little rake in the rear but it is not really noticeable. I am sure the springs will settle just a hair and when I get the bumper/ tire carrier built, the suspension will be as level as it needs to be.
Next up will be too do some trimming of the stock shackle hanger, tack up the new shackle hanger and then most likely finish welding everything up. I do not foresee any issues or hiccups, so the next update I should have the Chevy springs burned in and finished.
Old Dec 26, 2011 | 08:42 PM
  #144
space-junk's Avatar
Finally!!!
Old Dec 26, 2011 | 09:23 PM
  #145
Wow, that is all you have to say Troy?
I can tell you this much. I measure six times and will only need to weld once. LOL. I have been very happy with my progress.
Old Dec 26, 2011 | 09:41 PM
  #146
stockwell45's Avatar
Alright now I really need to see this thing. It's come a long way since I last saw it in August.
  #147
RMP8080's Avatar
You should be happy, great job. Earlier I was thinking why go to all that trouble, but I see now why. If I do a Chevy spring replacement I'll go back the this build thread, thanks ......Bill
Old Dec 26, 2011 | 10:09 PM
  #148
Yes it has come a long way stockwell. I may have to go south and meet up with you. Then you can show me around your stomping ground. I am wanting to plan a trip along the lost cost. There will be some camping involved at RMA's property.
Thanks for the props RMP, I do my best too document what I can. I also try to post up the things that are not posted about much, such as grinding the Leaf-springs.
Old Dec 27, 2011 | 03:33 AM
  #149
B-yodaful's Avatar
Looks I second that about coming back here when I do my 63's. Great work.
Old Dec 27, 2011 | 07:28 AM
  #150
vang_22re's Avatar
The 63s setup looks pretty good. I have a set sitting in the garage and still wondering when I'm going to start the swap. Haha
Old Dec 27, 2011 | 07:35 AM
  #151
Just be sure too give your self enough time too do the install when that time comes. The process will not be enjoyable if your in a hurry, B-yotaful.
I am glad that you plan to use this build thread as a reference for your own project. If you encounter questions, hit me up.
Old Dec 28, 2011 | 02:52 PM
  #152
I am extremely happy with myself today. I finished installing the 63" Chevy springs. All of my time a patience paid off. The fab work turned out strait, true and parallel. So time to get on with the pictures and details of the grand finish.
This thing was in the way of the placement of the new Shackle-hanger. I did not want to cut it off if I did not need too. You never do know if it will come in handy for something in the future. I trimmed as little as need, so I measured 10" from the end of the frame and mad the mark you see in the picture.
After measuring and marking both sides of the stock Shackle-hangers. I grabbed the cut off wheel to start the trim job.
I then cleaned up the scares with 40 minutes of grinding on each side. After all the miserable grinding, I was glad too be able to put the grinder down. Here is my sexy grinding job.
That is right, 44 degrees. Not the perfect 45 degrees but close enough for me.
Here is what I used as a spacer to achieve the 44 degrees while the weight was on the spring.
Jacking the weight onto the spring worked great. The force kept the Shackle-hanger clamped to the frame while I tacked it in place. Both shackles are the same at 44 degrees.
Now to get to the bad news. My welds did not turn out as pretty as I would have hoped. The beads do look buggery, but I know I got good penetration, because I could see it in the puddle when I was running the bead. Some of the possitions were difficult to feel comfortable and made it hard to stay consistent. So to my shame here are my ugly welds.
For my personal pride in my work. here is the truck sitting on all fours and at ride height
I surely know I need more welding practice and flux core sucks. I am going to practice more before I tackle the drive-train lift of the Winch mount. So practice here I come.
Old Dec 29, 2011 | 04:32 PM
  #153
Well after driving around a bit sense finishing the install. I have determined that the three leaf pack maybe a little too stiff. I need to measure and order new shocks of course and mount the new shock tabs still. I also have not loaded up the rear with much weight, but I have a prediction the chevy's will still be a bit stiff. After I work out getting new shocks and all. I may pull the rear suspension apart once more too remove the center leaf. I am happy with the 63's as they are but a smoother ride would be nice.
Old Dec 29, 2011 | 04:56 PM
  #154
john4wd's Avatar
Looks great :} You can weld better than me :}
Old Dec 29, 2011 | 05:03 PM
  #155
B-yodaful's Avatar
Dark welds aren't that bad. the first time I welded I didn't have a helmet so I just kept tacking till it held. My face got so burnt I could hardly see for three days hahah. Keep up the good work.
Old Dec 29, 2011 | 06:03 PM
  #156
RMP8080's Avatar
Nice......for the welds, just grind off a little and some black paint it will look great.
or do what I did, send your kid to school and have them teach him to weld...LOL
Old Dec 29, 2011 | 06:53 PM
  #157
Thanks for the encouragement fellas. I am just my worst critic I guess.
I am actually head back to School too get a welding Cert.
Old Dec 29, 2011 | 09:18 PM
  #158
RMP8080's Avatar
Cool on the welding certification, had my son do a lot of welding before he did work on my Toyota. But I did buy him a welder. Best of luck on the build
Old Dec 29, 2011 | 10:36 PM
  #159
Thanks.
Old Jan 2, 2012 | 10:45 AM
  #160
Made some more progress yesterday. Due to the added droop the chevy's provide, the brake hose needs to be longer. I solved this problem with a different approach. Instead of ordering an extended brake hose from from Marlin or TG. I decided to order a stock replacement hose from a local parts store.
There is some purpose to my madness and you may agree as well. When looking at a stock replacement rear brake hose. I noticed one end was male and the other female.
Sense the threads on both ends are a mirrored image of each other. It is possible to thread two identical hoses together. This idea got me thinking. If one hose ever failed on the trail or off the trail. I could simply pull the extra length out and stick with the other half of the two hoses. I would not need to carry an extra hose around with me as spare parts. The other bonus is cash savings. Not only does the stock replacement cost much less. I can always find a stock replacement just about any place I may be, if I did have a failure.
Here are some pictures of before and after. Don't mind the shoddy shocks, they are being replaced soon.
