Big Red - 1987 4Runner Build-Up Thread
Old Mar 11, 2012 | 09:22 AM
  #81
jaredbishop's Avatar
Saturday I cleaned the injectors. It fairly easy and really gets them cleaned. I replaced all the o-rings and on they went. Here is a video of how I did it on my MR2:
I you want to more about how I my DIY injector cleaner you can read about it here:
http://mr2.bishopart.com/?p=357
[YOUTUBE]http://youtu.be/HIazJ4WqzvY[/YOUTUBE]
The engine is slowly coming together. All the parts are clean except the hoses nuts and bolts. I've been cleaning those by hand. I still manage to get my nice clean engine dirty. Oh well.
I hope to have the engine ready to go in next Saturday the 17th. Between then and now I've got to add all the little sensors vacuum lines and and replace the wire looms in the bell housing.
Old Mar 13, 2012 | 07:00 AM
  #82
I found this part. What is it and where does it go?
Here are a few more images of it. I'm still trying to identify where some of the hoses go.
I'm still trying to find out if there is a gasket that should be here.
Old Mar 13, 2012 | 07:16 AM
  #83
irab88's Avatar
tis a water line. i never found a gasket for that. i think you can use a coolant-compatible o-ring. i used a little bit of black rtv, and no leaks in a year of driving
Old Mar 28, 2012 | 06:57 AM
  #84
The engine is in. Need help wiring it up!
I've got the engine in. There are a lot of wires that I need to find where a they go.
Old Mar 28, 2012 | 07:03 AM
  #85
irab88's Avatar
ground
alternator
that's all i can see for now... the others are too greasy, haha
Old Mar 28, 2012 | 07:06 AM
  #86
Originally Posted by irab88
ground
alternator
Thanks. I've been sick so I just thew the engine in and connected up what I could. I still have a lot of cleaning to do on the wires.
Old Mar 29, 2012 | 05:40 PM
  #87
Help help help
I started adding coolant and it started to drain out from where the engine block and the transmission meet up. That did I miss?
Old Mar 29, 2012 | 06:10 PM
  #88
ioumateo99@yahoo.com's Avatar
Check the rear coolant blockoff plate. Also the hoses for the heater.
  #89
Terrys87's Avatar
On post #83 I just get a rubber o-ring for it and put the bolts in.
As far as the water leak, ar you sure your heater hoses are hooked up? There is a plate on the back of the head. I think it has the possibility of leaking water. It is such a pain in the rear, I always put sealant and a gasket to make sure I dont have to try and get to it again, excpet to bolt the water pipe to it.
Old Mar 29, 2012 | 06:13 PM
  #90
Terrys87's Avatar
I was just scanning the most recent post on 86-95 and seen yours. Let me know what hoses or wiring and I can try and post some pics tomorrow.
Old Mar 29, 2012 | 06:29 PM
  #91
all the hoses are connected and everything above the oil pan is dry. I drained the oil and no water came out.
Did i forget some gasket seal or not torque something? I'd hate to have to pull the engine out again.
Old Mar 29, 2012 | 06:34 PM
  #92
I think I forgot to ad a freezer plug as seen in this image:
Old Mar 29, 2012 | 06:51 PM
  #93
Yopar's Avatar
Isn't this the block water drain plug?
Old Mar 29, 2012 | 06:54 PM
  #94
Yopar's Avatar
That would make it leak!
I think you can see the block drain plug on the rear drivers side in this pic. Not sure if you had already figured that out.
Old Mar 30, 2012 | 08:06 AM
  #95
I'm going to be pulling the engine this weekend. Damn freeze plug.
Here are some electrical connections that I have not found where they plug into to. They are all on the drivers side.
Here are a few vacuum lines I'm having trouble finding where they should go.
Old Apr 3, 2012 | 04:55 PM
  #96
I tried to start it up. I heard the starter try to turn for about half a second then it stopped. Then next couple of times I header it try to turn a little but nothing. The starter does have the power and ground wires attached. Any ideas?
Old Apr 4, 2012 | 09:21 AM
  #97
racerflea's Avatar
If it clicks u have a loose connection or a weak or dead battery
Old Apr 4, 2012 | 09:27 AM
  #98
I've done a bit of research on in and found several solutions including what you mentioned. As I was reading them I was thinking, I knew that why didn't I think of it.
Battery tested good so I'll throw it back in and tap the starter a bit with a hammer. Try rolling the truck a bit. If that doesn't work I'll clean and test the connections. If it still doesn't work I'll replace the starter with one from the pick an pull. If that still doesn't work I'll rebuild my starter.
Old Apr 4, 2012 | 09:33 AM
  #99
racerflea's Avatar
Might just be the solenoid
Old Apr 4, 2012 | 09:40 AM
  #100
racerflea's Avatar
Also did u check ur battery with a volt reader? Because if half the battery dies it will still read 12volts but wont have any cranking amps... a parts store near u aught to check it for free and they will beable to tell u...that happened to me in a ranger i use to own... the soleniod happened on a chevy... lots of problems ive had lol
