Andersej: 1993 2nd Gen 4runner
Old May 4, 2016 | 02:00 AM
  #121
space-junk's Avatar
Where'd you go?
Old May 7, 2016 | 08:15 AM
  #122
andersej's Avatar
Been racing Mx. Haven't been really doing to many big changes on the runner lately.
Old Sep 17, 2016 | 09:41 AM
  #123
andersej's Avatar
I recently got a question in my messages about my build and I thought this info could help others with the same question... ( I deleted the users name just in case he didn't want to be public with it)
Hey there,
I've gone through your 4runner build several times and liked what you did, thanks for sharing!
I've been thinking about sticking with IFS and now plan on going with the blazeland kit myself. The biggest worry I've had with LT was the possible breakage of front axles/CV's.
You mentioned breakage in your thread but I didn't quite understand what caused it. You talked about a bolt loosening but which bolt was that? Would you mind telling me more?
Other than that, have you had CV's break on you while wheeling (and not due to that bolt loosening)?
Thanks again for sharing your experience!
Best,
Hello !
OK so my breakage of CV's has since stopped. So with that said I have had other issues along the way associated with the Long travel but I'll explain that in a sec.
My main issue from the start was the front IFS axle mount bracket bolts on the driver side. (My Original issue was that the bolts had backed out or gotten loose which made the bracket sloppy and the axle was allowed to move WAY to much) but If you look at post #108 on my thread I am showing the where I had made a whole extra mount for the axle to help it from being able to flex so much. I also tack welded those smaller bolts on the bracket to hold them in place indefinitely. After I did this mod (which I imagine was a little overkill) I have not had any more CV Breakage.
***Now bear in mind I have absolutely beat the sh** out of this truck by Rally Racing it hard, Jumping it at the dunes and just downright getting silly when wheeling, etc etc***
So now just a heads up from some other things I have run into. Your steering components will wear pretty fast. I replaced my Idler arm 3 times now? Which is about 1 per 6-9 months? I will absolutely be upgrading all my steering here soon. The main thing is to get some decent Tie Rod Ends and then upgrade your Idler Arm with the Brace from Blazeland. *** http://blazeland.us/idler-arm-kit/ ** It's well worth the investment.
The 2nd thing you have to look out for is your ball joints Make sure you are running a good product like OEM or I run a 555 brand that I like (It's good Japanese quality = http://www.sankei-555.co.jp/ ). I had first started out with Napa's "premium" product ball joints ((Being a mechanic for 5-6 years now I found that that word premium means NOTHING but the price they sell it at. Everything premium from NAPA has been just crappy POS Chinese knock offs.)) So I found out what happens when you break a ball joint while driving and believe me its not pretty. My lower ball joint (NAPA) broke and it drove my lower control arm into the ground and shoved my wheel up into the body and destroyed my fender and messed up most of my steering components. So with that said be sure that you always have fresh ball joints and keep them well lubed always.
I hope I covered what you were initially asking here and then some. Over all I have had nothing but great success with Blazeland and I will continue to stick by it through an through. You would not believe how many people will doubt it's potential out on the trails and then in turn get blown away by how well it really does!!![/QUOTE]
Old Sep 17, 2016 | 01:41 PM
  #124
andersej's Avatar
Here's the damage from my ball joint breaking going down the road....
Here's how she sits today...
I changed up my exhaust Because I was tired of how loud it was with the Thrush muffler I had on it. So I bought a Dynomax muffler and it sounds WAAAAAAY better and quieter to boot.
Old Sep 18, 2016 | 07:39 AM
  #125
andersej's Avatar
Well now my passenger side valve cover is leaking going to have to replace them here soon. I've also noticed that my power steering gear box is leaking out of the steering input seal. I guess that means its time for it to be ripped out and fixed as well. I've heard from a buddy of mine that rebuilding the gear box can be a real pain. What do you guys think?
Old Sep 18, 2016 | 04:47 PM
  #126
dropzone's Avatar
Fossilized
I have a post in my Mini- FAQ thread about rebuilding a steering box, forget where I stole the info from.
on my 81 i just replaced the steering box with a good freebie from a friend of mine. I tore apart the leaking one and it looked like a PITA
I am looking at rear lift options for my 94, how much lift do you think you got from the OME springs?
Old Sep 18, 2016 | 06:34 PM
  #127
andersej's Avatar
Thanks I'll go check out that link!
I would say at least 3 inches of lift. It definitely raised up a bit. In fact its so high that I can't get my damn headlights to adjust up enough to see good with them heheh,
Old Sep 19, 2016 | 06:52 PM
  #128
andersej's Avatar
I think I am going to try to locate a used one, Pull out the one I have and rebuild it in the meantime. I have confidence I can do it just fine.... or do I?
Old Mar 2, 2017 | 09:48 AM
  #129
SgtSuprman's Avatar
I love what you did with your rig, I read your whole post, found it when looking for people running the blazeland kit, which I plan on getting ASAP. But, I noticed you haven't updated in a while, anything new with your rig, also how has the shock hoop kit worked out in the long run? Subbed, for whenever you update!
Old Mar 3, 2017 | 11:03 AM
  #130
CreeperSleeper's Avatar
Hey James, now that you have stopped snapping CV's, you need to get back up to TSF!
Old Oct 21, 2017 | 06:11 PM
  #131
95YotaPickup's Avatar
Sorry to revive an old thread, but what size tires are you running, and what are your wheel specs? I really like the stance on your rig and when I get my Blazeland set up, I don't want to run fiberglass fenders. Also, any problems with the wheel spacers in the rear? It seems like 3 inches on each side is alot.
Old Nov 20, 2017 | 06:16 AM
  #132
andersej's Avatar
I run 315/75 R16 , The wheels are a 16 x 8 inch steel rim I think they consider them a trailer wheel?. As for the wheel spacers in the rear, I have not ran into any issues using them whatsoever. I made sure to torque them down real good every time I rotate my tires.
Old Nov 20, 2017 | 06:30 AM
  #133
andersej's Avatar
I have not really been doing much with the truck in some time. Been working on other projects and working hard. The shock hoop kit worked out great! I love the 2.5 in coilovers they work very well. No issues with them.
Old Nov 28, 2017 | 06:18 AM
  #134
andersej's Avatar
Old Jan 1, 2018 | 07:18 PM
  #135
andersej's Avatar
Well we ran our annual Hangover run today and it was a blast! The sun was out, the mud was slick, and the trucks were plenty! Happy New year to you all!
Andersej: 1993 2nd Gen 4runner-ozpfxyr.jpg
Andersej: 1993 2nd Gen 4runner-flcxw56.jpg
Andersej: 1993 2nd Gen 4runner-tlo0hbt.jpg
Andersej: 1993 2nd Gen 4runner-lzcpbkz.jpg
Andersej: 1993 2nd Gen 4runner-vuv9q4z.jpg
Andersej: 1993 2nd Gen 4runner-f3sdan0.jpg
Andersej: 1993 2nd Gen 4runner-ghhq0ff.jpg
Andersej: 1993 2nd Gen 4runner-yhpsvse.jpg
Andersej: 1993 2nd Gen 4runner-zjjwq76.jpg
Andersej: 1993 2nd Gen 4runner-ddsrclp.jpg
Andersej: 1993 2nd Gen 4runner-i3tucpr.jpg
Andersej: 1993 2nd Gen 4runner-n6b2gwp.jpg
Old Jan 26, 2018 | 06:44 PM
  #136
BlazeN8's Avatar
Looks like it was a fun outing!
Old Jan 28, 2018 | 09:18 AM
  #137
andersej's Avatar
It was a fun trip. The weather was nice and the company was even better.
Well Moving on I started running into some steering issues here of late so I decided that it was time to take a look. I found the Pitman arm was clapped out so I replaced that. Then I found that my lower control arm had been loose and shifted out of alignment. Rock rash on the lower control arm mounts had started taking its toll and actually was pinching the arm and preventing it from articulating very well. I bent all that back into place so the arms were free again. (THIS IS WHY A GOOD SKID PATE OS NECESSARY) Then I had play in my front left wheel. Figured meh probably wheel bearing needs repacked, WRONG Wheel bearings had been running a while in some water.... They're shot, but after about 5-6 years of abuse I cannot complain. so I ordered the front end bearing kit from marlin crawler and will be disassembling this beast today.
Old Jan 28, 2018 | 02:24 PM
  #138
andersej's Avatar
So Started some disassembly and cleaning today.
Andersej: 1993 2nd Gen 4runner-7kmdhb6.jpg
Jacked up and ready
Andersej: 1993 2nd Gen 4runner-gdtfk8b.jpg
Rotor is still looking alright brakes are at 60% or so
Andersej: 1993 2nd Gen 4runner-qxiuw0k.jpg
So you can start to see here that the red grease is not very red in fact its a brown/black mixture....
Andersej: 1993 2nd Gen 4runner-ux3glvc.jpg
Andersej: 1993 2nd Gen 4runner-bejacic.jpg
Heres the inner bearing as you can see the pitting and what you cant see is how clapped out it is. It has quite a bit of movement and the bearings themselves are worn.
Andersej: 1993 2nd Gen 4runner-vb6ta2l.jpg
Outer Bearing
Andersej: 1993 2nd Gen 4runner-wf34no7.jpg
A few smacks with a punch and out comes the Bearing Race
Andersej: 1993 2nd Gen 4runner-fsmt3xb.jpg
Yep some wear signs on the race but nothing like a new set to cure all that.
Andersej: 1993 2nd Gen 4runner-duydnfu.jpg
Took some time with a wire brush, brake clean and compressed air and cleaned up the spindle and backing plate.
Well now for a couple day wait for the kit to come in.
Old Jan 29, 2018 | 05:37 PM
  #139
andersej's Avatar
Anyone have any experience with the JD Fab steering upgrade for long arm systems???
https://jdfabrication.com/products/t...4-steering-kit
Old Jan 30, 2018 | 02:29 PM
  #140
odonekanobe's Avatar
No experience but have been considering upgrading my steering as everyone seems to think that is the weaker point w/ blazeland kits. I already have the TC idler arm though.
