Andersej: 1993 2nd Gen 4runner
Old Jul 23, 2014 | 07:02 AM
  #61
odonekanobe's Avatar
Originally Posted by BlazeN8
You can do it two ways.
A) coil over conversion- 400-700lb coil spring depending on weight/application.
B) coil over assist- 200-400 coil spring w/ stock T-bars.
The coil over conversion will put more loads on the shock hoops. Under severe duty a strut running over the engine connecting the hoops is a good idea. A engine cage would be even stronger. My shock hoops are lighter duty but have been holding up for the most part. The exception is "huck fest" big air on an early prototype using .095 wall pipe and not .120 wall DOM. Purposefully under built to see what would fail.
The coil over assist will reduce the loads to the shock hoop as the spring load is divided between the coil and the T-bars. The coil over assist is also nice as it gives two areas to make adjustments / tuning. T-bar and coil spring load up differently.
Either route will put more load on the upper BJ so adding a limit strap to control down travel will reduce the possibility of popping the ball joint "ball" from the socket. You would want to connect one end of the strap to the frame and the other end to the LCA. The old shock mounting tabs work well. For the upper attachment use an adjustable clevis for dialing in the droop stop.
Is there a difference in travel between the 2 setups?
Old Jul 23, 2014 | 10:23 AM
  #62
BlazeN8's Avatar
James, sorry to see you had the clearance conflict between the spring and the UCA. Like I mentioned before the space is limited to fit a coil spring behind the UCA. Its a fine line between the tire rubbing the spring or the UCA rubbing the spring. The alignment in the caster plays a roll in pushing the LCA forward or back which complicates clearance buffers. In your case the LCAs must be pushing forward causing the UCA / Spring contact.
Your solution is exactly correct. The UCA has extra material s that can be trimmed. Good Job! And yeah, using a 2.0 vs a 2.5 would make a difference. Personally I would rather use a 2.5 and have to adjust for clearance. I think for future shock hoops I may position the tabs to be wider and this will allow shimming the shock forward or back as needed. Oddly though, you are the first person to report the spring / UCA rubbing?
Odonekanobe, the difference in travel between having a coil over conversion, a coil over assist, or straight T-Bar don't vary. The pivot points are the same so the geometry is the same. The bump and droop stops (or limit straps if used) limit the travel so the spring method is irrelevant in terms of travel range.
The suspension system I pictured is a prototype design I am working on. I call it the Mega Travel. I just showed it as a visual for the limit strap. You can read about it on my 4 Runner build thread.
Old Jul 23, 2014 | 03:47 PM
  #63
andersej's Avatar
Well did a few test runs today and had to grind a little more off the passenger side.
I had the shocks filled with nitrogen to 150psi. Honestly think I am a little firm on my spring choice. But I am going on a trip this friday doing some moderate rock crawling so I see how she feels out there.
Old Jul 24, 2014 | 09:01 AM
  #64
andersej's Avatar
Getting ready for my trip and then I tried to roll the back window down....... Nothing. Arggggghhh always right before I want to go somewhere.
Old Jul 24, 2014 | 10:18 AM
  #65
Just in case you don't know, the drivers side front window will work for the tailgate also. It's more common to find in parts stores and I believe it's cheaper also.
Old Jul 24, 2014 | 04:36 PM
  #66
andersej's Avatar
Thanks for that Info!
Old Jul 24, 2014 | 04:40 PM
  #67
andersej's Avatar
Man I lucked out it was just my switch. I went down and grabbed a new one real quick and was able to get my window to work again. I run mine with this momentary switch.
That's an oreilly's part number if you guys ever run across needed to re- wire your tailgate window.
If anyone needs an explanation on how to wire up a switch like this I can show them.
Now it's time to finish packing for my trip to the McGrew Trail in southern Oregon. Have a good weekend everyone!
Old Jul 27, 2014 | 11:30 AM
  #68
andersej's Avatar
This weekend was an epic trip! I'll trow in some pics and info later.
Old Jul 28, 2014 | 04:02 PM
  #69
andersej's Avatar
Had a great time at the McGrew Trail. Lots of rocks!
Was about 20+ rigs on the trail and took aprox 6 hours to get through.
Had the driver side lower weld pull away from my shock hoop bracket. I wrapped it with a ratchet strap and kept going
Old Jul 28, 2014 | 04:04 PM
  #70
andersej's Avatar
Had a quick trail fix to help with.
Old Jul 28, 2014 | 04:08 PM
  #71
andersej's Avatar
Old Jul 28, 2014 | 09:00 PM
  #72
andersej's Avatar
Forgot to post these a while back when I was testing flex after installing blazeland kit.
Old Jul 30, 2014 | 03:24 PM
  #73
julsruls's Avatar
sweet looking rig
Old Jul 30, 2014 | 03:30 PM
  #74
andersej's Avatar
Thanks!
Old Jul 30, 2014 | 04:50 PM
  #75
rattlewagon's Avatar
Now thats some IFS flex! Great trail pics too!
Old Jul 30, 2014 | 05:17 PM
  #76
andersej's Avatar
Haha no doubt! I love this setup it runs so smooth compared to the leaf rigs I have rode in. I hope to make believers of IFS one day at a time
Old Sep 11, 2014 | 08:15 PM
  #77
andersej's Avatar
Andersej: 1993 2nd Gen 4runner-forumrunner_20140911_211419.png
Andersej: 1993 2nd Gen 4runner-forumrunner_20140911_211437.png
Andersej: 1993 2nd Gen 4runner-forumrunner_20140911_211505.png
  #78
andersej's Avatar
Made me a rear Bumpa
Old Sep 11, 2014 | 08:50 PM
  #79
chukarhunt's Avatar
Nice work on the bumper! Looks sharp. And the blazeland kit is looking great too! Wish i had went that route...
Old Sep 11, 2014 | 08:51 PM
  #80
dark_fairytales's Avatar
Nice writeup on the Blazeland install. Your post makes it look so easy and quick, however I am sure, you, like me, know it take all day and then some. My install took eleven hours. how long for you?
