A2theK's 91' Pickup Buildup Thread
Old Mar 12, 2013 | 07:52 PM
  #81
A2theK's Avatar
Got my parts in the mail today and went straight to work! Swapped out my steering damper first.. Had some trouble trying to hit out the tie rod looking connector bolt with a hammer for like 10 minutes then decided to torch it and popped right out with no force at all.
My truck really liked to grab ahold of every flaw in the road possible and jerk around so this should help out alot more. I just drove it around the block 30-40 mph and felt really solid. I'll really know how much it helps tomarrow hitting the highways.
Then got onto my 1" body lift I picked up from Sky's Offroad Design online. Good quality body lift imo. Went on relatively easy, pain in the butt tightening everything up with the little amount of room up in there. Got to use the new Hi Lift jack as well! Extra inch gives me clearance now to make full turns as well so no more grinding!! Woo!
Got her up 3 inches now and will most likely be as high as I'll go. More projects soon to come! I'll post a pic of the lift all on tomarrow. Finished up when it was dark out.
Old Apr 30, 2013 | 07:39 PM
  #82
A2theK's Avatar
Starting up some fab work for a new front bumper. Going for the TG rock defense low profile look or with a smaller stinger. Getting the rest of the piping tomorrow and will go from there.
Old May 9, 2013 | 05:41 PM
  #83
A2theK's Avatar
Well got her all welding up. Didn't have access to a tube bender so ended up cutting and welding all the corners up and sanded it down flush. Off to the store to get some primer and paint and will be ordering my winch soon. Still need to make a few more braces to hook up to the factory bumper mount but other than that I think it looks great. Any opinions or things I should change?
Old May 9, 2013 | 07:24 PM
  #84
A2theK's Avatar
Too dark to bolt it on to see what it looks like but all painted, just needs extra support brackets and a nice winch on there and will be set!
Old May 10, 2013 | 08:14 AM
  #85
gilbert72's Avatar
great job on the bumper! really love the look of your truck and its going to look even better with the bumper mounted
Old May 12, 2013 | 04:36 PM
  #86
A2theK's Avatar
Got everything all hooked up. Ordered my winch and got some smaller signal lights. May pick up up some KC lights as well later.
Old May 16, 2013 | 07:50 PM
  #87
A2theK's Avatar
Winch is in! Picked up a Rugged Ridge 8,500lbs winch. Easy install, wiring was all pretty straight forward. Spent more time trying to mount the control box somewhere because it kept on hitting my grille; ended up just resting it snug next to it until I fab up a mount for it somewhere. All tested and ready for action. To add a stinger or not is the question.. Maybe a smaller one or keep it as it is, decisions decisions.
Thinking paint next? Like dark charcoal grey or something. Also noticed a few straight axles on CL lately; might see if I can get one cheap!
Old May 18, 2013 | 06:46 AM
  #88
kbe151's Avatar
Looks awesome! Quick question for you A2, what years did the 4.88 gears come in? I am putting 33x10.50's on my 4Runner and need the added torque bad.
Old May 18, 2013 | 10:56 PM
  #89
A2theK's Avatar
From what I know they're mostly in the later 4runner models, 93-95 with the factory 31" wheels. The gear code on the inside door panel is G144. Can get em fairly cheap in your local picknpull if you happen to cross one.
Old May 19, 2013 | 07:19 AM
  #90
bone collector's Avatar
Nice looking truck! I really like the bumper and wheels. Keep up the good work!!
Old May 19, 2013 | 07:55 AM
  #91
kbe151's Avatar
Sweet, thanks boss
Old May 29, 2013 | 01:34 PM
  #92
A2theK's Avatar
Well decided instead of getting some LED lights to replace my signals; I ended up doing the corner light mod which only took like 30 minutes to swap everything over and looks pretty good! Quick, easy and free.
Basically just removed the marker lights and drilled the hole out bigger in my corner lights with small cutouts for it to slide into and lock so I didn't have to use epoxy or anything to hold the light in place.
Plugged all in and no more taped/zip tied lights on the bumper!
Old May 29, 2013 | 04:19 PM
  #93
JeremyW94's Avatar
Solid truck man, love it.
Old May 29, 2013 | 04:44 PM
  #94
good job on the corner lights. I did that on my 87, and it was great. keep up the good work!
Old May 29, 2013 | 06:08 PM
  #95
rustyangel's Avatar
That bumper looks awesome. Nice job!
Old Jun 16, 2013 | 10:59 AM
  #96
A2theK's Avatar
Thanks man!
Well found a great deal on some SR5 4runner bucket seats! No rips or tears, just a very small cigarette burn and the driver side was stitched up as you can see in the picture but overall they're in amazing shape for being 20 years old. Compared the the old ripped up bench seat WOW, insanely comfortable.
Going to head over to a picknpull next week to grab a center console that I remember seeing a little while ago and maybe I'll get lucky and find some SR5 door panels.
Old Jun 16, 2013 | 11:28 AM
  #97
Great score on the seats! that is something i want to do as well. how hard were they to install?
Old Jun 16, 2013 | 04:46 PM
  #98
A2theK's Avatar
Super easy actually.. 3 out of the 4 mounting holes actually fit on each seat so really only had to drill one hole on the front inner bracket.
Old Jun 17, 2013 | 05:12 AM
  #99
JeremyW94's Avatar
Awesome score on the bucket seats, might have to go get me some now. Looks good man.
Old Nov 6, 2013 | 05:09 PM
  #100
A2theK's Avatar
Scored an awesome deal on an 85' front axle, guess what that means... Ordered a rebuild kit, should be in the mail tomorrow! Will start gathering more parts and hopefully will get started on the project within the month!
