88 Runner
Old Dec 9, 2012 | 05:42 PM
88_Red_Runner's Avatar
Cool 88 Runner
New to YotaTech...
Old Dec 9, 2012 | 05:46 PM
waskillywabbit's Avatar
:wabbit2:
Old Dec 9, 2012 | 05:58 PM
It says my pics are too big to upload any suggestions?
Old Dec 9, 2012 | 06:06 PM
Erik Hinch's Avatar
put your pictures on www.photobucket.com then post em up.
Old Dec 10, 2012 | 06:38 AM
https://www.yotatech.com/attachment....1&d=1355153851
Picture of old 85 with T-100 3.4 and R150...
Old Dec 10, 2012 | 10:46 AM
B-yodaful's Avatar
Thats awesome we are going to need to see some more pic
Old Dec 10, 2012 | 11:39 AM
Philbert's Avatar
Welcome....
Now follow the steps in my linked photo posting DIY below and get us some truck porn STAT!!!
Old Dec 10, 2012 | 03:36 PM
So far the 88 red runner had a 3.0 w/auto. The engine and transmission have been removed in place of a 3.4 out of a 96 T-100 manual, and the transmission is out of 95 3.0 4Runner. The T-100 had 195,000 miles, the tranny had 95,000 miles. These were both in my 85 carbed Toyota.https://www.yotatech.com/attachment....1&d=1355186480
Old Dec 10, 2012 | 04:08 PM
Smile
A few things for the conversion you will need are the 3 liter oil pan pickup tube windage tray dip stick and tube, also the thermostat housing and lower radiator hose off of the 3 liter. The 3 liter engine mounts will also be needed. The engine harness and ecu, also the 2 body harness plugs that go into the ecu are the ones needed to be spliced into the donors harness along with the obd2 port and wires.
I also use an auto t-case crossmember for a quick bolt on application, because it swings forward to mate to the 3.4, also use the 3.4 flywheel pressure plate and disk. Then use a 3 liter clutch release bearing. Modifying the crossover pipe is a must, for it is too wide to fit between the frame rails.
The T-100 high pressure fuel line is long enough to simply cross over to the passenger side and connects to your high pressure fitting off of the frame. You will have to buy roughly 4 feet of EFI return line, simply because toyota never made one that long. (fortunately the T-100 has most all of the parts on the 3.4 besides what i have mentioned)
Old Dec 10, 2012 | 04:14 PM
Cool
https://www.yotatech.com/attachment....1&d=1355188420
These photos were taken in Vaughn, MT at the Big Boy Motorsports course...
Attached Thumbnails 88 Runner-8260616213_d13118f8f8_m.jpg   88 Runner-8260615969_11200011e8_m.jpg
Old Dec 10, 2012 | 04:26 PM
Talking
https://www.yotatech.com/attachment....1&d=1355189141
Here is a picture of the donor vehicle 88 sr5 v6 auto fully loaded, and a pile of parts on the shelf. Who knows, it might just get that FJ80 front. I have a 84 mini truck front that might just go in there. For now it came with a 4 inch rancho IFS lift in front and some 4 inch blocks in the back lol. Also came with some 33x12.50x15 pro comp mud terrains on 15x10 mags.
Attached Thumbnails 88 Runner-8262060603_0a6ed7c5a7_m.jpg   88 Runner-8262060773_700147dfe7_m.jpg   88 Runner-8262061509_be3b619c18_m.jpg
Old Dec 11, 2012 | 05:11 PM
So today i have routed the heater core hose from the 3.4 to the 3.0, modified the fan shroud to fit the offset fan (3.0 fan on 3.4 fan clutch) tacoma upper radiator hose and 3.0 thermostat housing and lower hose.
I have also replaced with all factory parts: thermostat, spark plugs, and wires.
Much more to do...
Old Dec 12, 2012 | 06:16 PM
Originally Posted by waskillywabbit
:wabbit2:
Pics are up more to come as i keep building.
Old Dec 15, 2012 | 02:34 PM
Almost have the jumper built. Wiring spaghetti...
It is nice having the 96 T100 EWD and the 88 Truck/4Runner EWD and FSM's...
Old Dec 15, 2012 | 03:20 PM
Philbert's Avatar
Your pics are still too darn small
Follow up how-to in my sig on posting pics - it's really, really easy, and will let you upload much larger photos in the post so we can actually see what you did (which we want to!).
Old Dec 18, 2012 | 04:41 PM
When i go to photobucket it just loads page, then goes blank. I am not very computer savy.
Old Dec 18, 2012 | 04:50 PM
https://www.yotatech.com/attachment....1&d=1355881809
R150 going into auto 88...
Attached Thumbnails 88 Runner-8262061201_536e9e5ace_z.jpg   88 Runner-8263130072_a0801de2eb.jpg
Old Dec 20, 2012 | 02:58 PM
Just started up the engine today!!! Still need to wire in the OBD2? Still unclear about the shielded wire thing any input would be nice...
Old Dec 20, 2012 | 03:00 PM
Talking
Also there is a quick video posted by Anne Marie on FACEBOOK.
Type in bigboymotorsports in face book to check it out!!!
Old Dec 23, 2012 | 05:09 PM
Talking
Well i have not been up to date on this thread, but it is alive. I will post some pictures up hopefully soon.
