88 4runner 3.4 wiring adventure
Started out as a good toy but after a few months of driving it the 3.0 went kaput. So it has been on the back burner for about a year or so and I found a low mile 97 t100 and decided to bring the runner back to life. I am doing the 3.4 swap on my 88 manual 3.0 4runner, I bought 97 2wd t100 with auto and then I found a 97 t100 4x4 manual ecu. My problem is finding all the ends for the ecu so I can repin the auto harness for manual ecu. Does any one have suggestions on plug ends? I found the 22 pin at toyota but I still need the 26 pin, 16 pin, 12 pin. Any help would be appreciated!
Colt
Colt
Check out the 3.4 swap forum https://www.yotatech.com/forums/f160/ for answers to all your questions (you will need to look around for a bit).
Threads that might be of the most use for you:
3.4 Swap 101: https://www.yotatech.com/forums/f160...-101-a-239002/ (This has ECU connector part numbers that should work for you).
3.4 Swap Wiring Theory: https://www.yotatech.com/forums/f160...emonch-223093/
Also check out TIS for all your wiring diagrams: http://www.techinfo.toyota.com
You might also find the following thread useful:
88 wiring diagram: https://www.yotatech.com/forums/f160.../#post51885494
97 manual trans cpu calls for EGR Wiring
I got the harness ends from the stealership, they charged me ten bucks a piece for them after they quoted me 7. Guess I will be looking for another source for OEM parts!
