87 Deathtraps' '87 4runner Build Thread
Old Sep 5, 2011 | 07:03 PM
  #81
87 Deathtrap's Avatar
I've been thinking the same thing. I figured I'd just cut some out of 3/16" or 1/4" scrap I have laying around.
Old Oct 10, 2011 | 03:03 PM
  #82
Wow, it's been over a month since I made any real progress. Been busy with way too many other things. Anyway, finally got back to working on the Poorunner this weekend. I moved the steering box forward 3 1/2 inches, and made a real hack job out of it in the process.
Before
After, still need to reinforce the core support
Chopped the body mount up a little too
All plated, welded, and painted
Old Oct 11, 2011 | 06:08 PM
  #83
3linked84's Avatar
Nice! What else do you need to do looks like just driveshafts?
Old Oct 11, 2011 | 06:57 PM
  #84
Thanks man. Still need to re-gear the rear, build a front driveshaft, extend the steering shaft, weld in the creeper joints, reconfigure the front springs, and pick up some new shocks. Whew!
Old Oct 12, 2011 | 12:05 AM
  #85
3linked84's Avatar
Thats not to bad, geting close
Old Oct 18, 2011 | 10:32 AM
  #86
rustED's Avatar
Nice build! Its really coming along. I can't wait to start my SAS on my 86' 4runner, but I have to get it running first, lol. Thanks for all the detailed pics, it will give me something to refer back to when I do mine. Keep up the good work!
Old Oct 23, 2011 | 09:51 PM
  #87
LGcrawler's Avatar
sweet buildup man, ill be watchin
Old Nov 7, 2011 | 01:35 PM
  #88
Thanks a lot guys.
I got the steering shaft extended 3 1/2 inches a couple of weekends ago, but didn't think to take any pictures of the process. So now I have the ability to steer, but have since decided that I don't trust any of the other steering components. Ordered all new tie rod ends, tie rod, and drag link, as well as a ton of other "little stuff" that came up, from WabFab last week.
Old Nov 7, 2011 | 02:00 PM
  #89
This weekend's project was a front driveshaft. Surprisingly enough, I did it, and have pretty good confidence that it's the strongest thing on the truck now. I used 2 1/2" square reciever hitch tubing (no weld seam) for the female portion and 2" square for the male end, all 1/4" wall. I went with a double cardon joint because that's what I had.
Made the round shaft of the cv fit in the square hole.
Same deal on the single u-joint end.
Capped the male end and rounded the edges to prevent it from scoring the larger tube as it slides.
Tacked together and double checking my measurements. 27 1/2" at full compression.
Falls apart at just over 43".
Fully welded and painted.
Installed. At ride height I have 5 1/2" inches of compression and 10" of extension. That's right, 15 1/2" of slip for under $40!
Old Nov 7, 2011 | 07:14 PM
  #90
snowshredder555's Avatar
Nice work on the driveshaft. How do you think the vibration is gonna be on it? I've never researched a square tube drive line that's why I ask.
-Ted
Oh...! How bout a close up of the weld's?? Interested to see how you're progressing.
Old Nov 7, 2011 | 08:13 PM
  #91
Thanks Ted. I'm sure vibration will be killer at any speed. Fortunately, we don't have many situations where I would need 4wd and speed at the same time since snow's not an issue here. It should be pretty noisy though, as there's a lot of play between the two tubes. I might address that later if it gets annoying. As far as welds, let's just say I ground them all down to help it slip smoothly, yeah, we'll go with that.
Old Nov 14, 2011 | 08:38 PM
  #92
yeehaw1's Avatar
subscribed....
looking good so far...
Old Nov 14, 2011 | 10:27 PM
  #93
Okay, that work's too. Vibration...I'll talk to Wayne tomorrow about brazing a bronze alloy between them...maybe he know's of a trick.
-Ted
Old Nov 14, 2011 | 11:02 PM
  #94
russ_'s Avatar
Wow was that thing sketchy to start with. I can't believe anyone would even think of driving it the way it was. You've done a ton of good work to it and should be proud of the progress you've made.
Old Nov 15, 2011 | 06:11 AM
  #95
Outsane's Avatar
watching..
Old Nov 17, 2011 | 11:33 AM
  #96
guzzifreak750's Avatar
tire size
[/quote]
does the stock looking 4 runner have any kind of lift to it and if not what size are those tires thanks for the info.
Old Nov 17, 2011 | 03:35 PM
  #97
In that pic the brown truck is at stock height aside from an add-a-leaf in the rear for increased load carrying ability and sitting on 33x12.50's with 15x8" wheels. Had a little rubbing in the front on turns but nothing major with the pinch weld hammered flat. I eventually lifted it a little for clearance and added a Downey long travel kit, but it did great on the stock suspension. Most of the video below is with stock suspension (although it is locked with 5.29"s)
http://www.youtube.com/watch?v=HyXDe...layer_embedded
Old Nov 17, 2011 | 06:02 PM
  #98
You demonstrated mad driving skills there Mr. Nate. But I think you left some of your rear bumper on the rocks. So....do you miss it yet? Or just wheeling all together?
-Ted
Old Nov 17, 2011 | 06:09 PM
  #99
Thanks Ted. Yeah man! Wish I would of SAS'd that one instead of starting the current build. Definately getting withdrawels, especially with this weather lately.
Old Nov 19, 2011 | 09:01 AM
  #100
85 T4Runner's Avatar
Nate, that was a great collection of video. Now I have withdrawals too!!!
Did ya get all of the front end parts in yet?
