87 4runner intermittent starting issues
Old Oct 19, 2013 | 01:12 PM
inajjjam's Avatar
87 4Runner intermittent starting issue:
*Presently on 3rd starter in 3 years. Finally changed brands, totally rebuilt Bosch at present.
*New battery
* All connections are clean and tight
* Finally gave in and brought it to my trusted and wise Auto Tech. He traced it to the starter relay intermittently sending low voltage. Replaced it with a good one from a junk yard, a new one is $175.00. He said he has not seen issues with these relays before.
This work was done 3 days ago, started many times though had the clicking issue twice, fortunately I was in the hills and parked on one today. Could not get it to do it for the mechanic after it happened the first time. Help!
Old Oct 20, 2013 | 08:26 AM
Terrys87's Avatar
Go thru RADs fix. Cleaning the relays contacts helps alot. >>> https://www.yotatech.com/forums/f199...l#post51975700
Old Oct 20, 2013 | 01:27 PM
inajjjam's Avatar
Thank you, I will try cleaning the relays contacts. Will I still have the neutral safety switch with RAD's fix?
Old Oct 22, 2013 | 03:03 AM
Terrys87's Avatar
I am not sure of the neutral safety switch but here is what I meant to say about taking the cover off of the Starter Relay and cleaning the contacts.
Getting cover off, I used wire cutters to bend the tabs up on the cover. The rubber seal really makes it tough to get off. Luckily the wires are soldered on real well, I used a screw driver to work around the edges of the seal to help free the cover.
Here is the contacts that need cleaned.
Here is another problem I have found with these starters.
https://www.yotatech.com/forums/f116...ct-fix-193101/
Originally Posted by 91Toyota
This is my own version of the 22re starter solenoid fix. 4crawler did an excellent job, but I feel his pics are small and blurry. So I took better ones.
My truck would randomly just click and not start. Then it would start. Went away for weeks at a time, then just hit me and every time I tried to start it it would just click.
Anyway, I first removed the starter.
Next, I cleaned the starter a little bit then took it to the work bench. Where I then inspected it. I then took off the cover with three little bolts. I used a wrench to loosen/tighten them.
Here is the plunger thing coming out.
Here is what I will be replacing. See how worn out it is?
I then removed ONE contact at a time. I decided to do the really worn out one.
In order to get it off I stuck a small flat-head screwdriver between the copper bolt and the contact.
In order to get the new one back on. I carefully used a vice to squeeze it back on. Just be careful.
New vs. old
Now, I put it back on. One at a time. Next will be the left one.
Next, I did the other side. It was easier because the contact did not have to put be forced on. Just remember where everything went.
Next, I put the cover back on and cleaned the starter. Now its ready to go in!
The contacts were $11 each. I couldn't wait to buy them online as my truck is a DD. So I went to the dealership and they had them in stock.
This took about 3 hours from start to finish because I am slow and decided to clean it. It could be done faster.
Big thanks to 4Crawler and his site....http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
voiddweller
19
May 2, 2016 09:10 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
bobbybouche
Jun 18, 2015 10:22 AM
