87 4runner build
Old Jan 9, 2013 | 05:00 PM
bmxmike's Avatar
87 4runner build
just starting a full build on my 87 4runner that i just picked up
.i bought it with a blown tranny and oil leaks....but the frames solid and theres not much rust at all
.already came with a 3in body lift, bilstein shocks in the front and air shocks in the back and 54in leafs for the rear that werent installed yet
.i have the rear disk conversion kit and a marlin built heavy duty tranny is on the way
.i plan to do a sas and all the suspension in the near future
.pulling the motor and tranny all tomorrow so i figured id start the thread now and see if you guys got any tips along the way
Old Jan 9, 2013 | 05:10 PM
bmxmike's Avatar
couple pics of when i got it
Old Jan 9, 2013 | 05:16 PM
kornhuskerwizard's Avatar
why pull the motor?? does it have problems??
Old Jan 9, 2013 | 05:46 PM
bmxmike's Avatar
no just alot of leaks...i figured i just pull it now and do seals it does have 180k on it
Old Jan 9, 2013 | 05:49 PM
bmxmike's Avatar
i figured drivetrain would be the first...i plan on dumping alot of money into it...i cant be the little toyota when we just put 1 tons in my buddies bronco lol
Old Jan 9, 2013 | 06:06 PM
cool. if you pull your valve cover off check the condition of your timing cover and guides with that mileage unless you know theyve been replaced. check for grooves in the drivers side of the cover and the conditon of the plastic guides.
Old Jan 9, 2013 | 06:34 PM
bmxmike's Avatar
exactley why i started this...thanks man...i hope to be pulling it all apart next week..is there anything else in the motor i should look for...ive done some motor work before but nothing fuel injected or 4 cyl...im not sure if theres anything else to look out for
Old Jan 9, 2013 | 06:45 PM
just start reading peoples build threads youll learn alot that way.
Old Jan 9, 2013 | 06:51 PM
bmxmike's Avatar
ok thanks
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
XtraCab
Apr 12, 2020 05:25 AM
toyoda8488
Jul 5, 2015 10:18 PM
