85Toyman's 1994 4Runner Build up Thread
Old Jul 23, 2014 | 09:10 PM
  #261
dropzone's Avatar
Fossilized
Originally Posted by rustED
Sweet build, I don't know how I missed this one, I'll have to go back and read from the start! Like the front bumper too! Look forward to seeing the sas when your finished!
if you ever get to see this truck in person it is a dang fine piece of work.
The engine install looks factory..
Old Jul 29, 2014 | 03:21 PM
  #262
85toyman's Avatar
Ok,
Here is a bit of an update on the SAS. I have welded up the engine mounts, the brake lines are installed and the front hanger is tack welded and bolt in place. All the shackles and ubolts are torqued and it is sitting on its own. I will weld the front hanger up complete tomorrow as long as nothing else comes up.
Things to finish.
1. Finish weld the front hanger in place.
2. Bleed brake lines and clean rotors before use.
3. Finish painting the front hanger and surrounding area's.
4. Fill the diff with oil.
5. Flex the front out and figure out which shocks will work, either 10" or 12"
6. Weld the front shock hoops in place with new shocks.
7. Install relay bar for the cross over steering. it is in the paint booth.
8. Wire up the front HP elocker
9. Install bump stops
10. Install steering stabilizer
Here are some pictures of the product so far. I am sitting butt low again about 1". I will run the springs thru some run time and hope they settle a bit. If not level then I might add a small spacer to the rear or try a slightly longer rear spring.
I had issues with the front hanger in the flush mount location. I moved it forward 1" and this is how the shackles sit now. Much better.
Here is the tape mark showing the stock IFS hub center location. This current spring setup pushes the hub center forward about 3/4" for better fire wall clearance but not looking silly with the tire 3 to 4" forward like some other setups I have seen. I wanted the best performance but close to stock look. Again this is not a dedicated wheeler but rather an all around off road toy
Old Jul 29, 2014 | 03:31 PM
  #263
85toyman's Avatar
Want to get this finished up so I can start working on the roof rack I want to build, and also get that auxiliary fuel tank installed..... Its a labor of love
Old Jul 29, 2014 | 09:38 PM
  #264
dropzone's Avatar
Fossilized
Stance looks great.
Wish I was at the point of picking up a newer truck..I would have loved to pick up some of your IFS stuff.
Going to send you a pm about a possible project.
Old Jul 31, 2014 | 09:12 PM
  #265
85toyman's Avatar
Here is another project that I started working on today. It should look pretty good once the bed is painted to match the Zrunner...
Old Aug 7, 2014 | 07:32 PM
  #266
85toyman's Avatar
got bored tonight. Found this and was likin what I see. Thinking might have to think about a possible build for this newly sas'd 4runner......
http://www.expeditionportal.com/foru...x-build-thread
Old Aug 7, 2014 | 07:57 PM
  #267
kornhuskerwizard's Avatar
Nice!!!your runner sasd looks sweet.
Old Aug 7, 2014 | 08:04 PM
  #268
85toyman's Avatar
Thanks
Old Aug 7, 2014 | 08:12 PM
  #269
Boomerang shackles on the front look great.who you get them from???
Old Aug 7, 2014 | 08:25 PM
  #270
85toyman's Avatar
Thanks,
These shackles are from Sky Manufacturing...
Old Aug 9, 2014 | 08:16 PM
  #271
85toyman's Avatar
Swap is all finished up. I am thinking about getting a long spline front shaft as this one is a little short. I only have drive way shots yet. It will be a few weeks until I am able to get it out into the dirt.
Old Aug 11, 2014 | 04:59 PM
  #272
85toyman's Avatar
Well, I pulled the tractor out and built a nice mound of dirt to flex the rig out on.
It flex's out really nice, only issue is the rear tires make contact with the mud flaps pretty hard, so those are coming off along with the rear bumper. I guess I am going to fab up a nice rear bumper here soon. The front tires on full lock and under compression rub the pinch weld pretty good too, so I need to decide if I am gonna smooth out the pinch weld or move the axle forward another 3/4".....
Sorry no pics yet, busy checking things out and moving equipment and such under a time crunch so I didn't have time today.... Will get pics soon....
Old Aug 11, 2014 | 06:00 PM
  #273
rattlewagon's Avatar
Do the shackles hit the body mount?
Old Aug 11, 2014 | 06:17 PM
  #274
85toyman's Avatar
No they don't. It is very close at like 1/4" between the shackle and the frame. I think for next time, I would move the shackle mount back 1/2" instead of pushing it forward all the way when I burn my holes thru the frame if that makes sense. I would prefer a little bit more room between them. The last option since mine are set is to notch the body mount slightly to give them some more room. If they ever hit that is what I would do on this rig....
Old Aug 12, 2014 | 12:52 PM
  #275
85toyman's Avatar
Goofing off and trying it out for the first time really. Both tires tuck up nicely. I think I still have to fiddle with it and I should get more down travel out of it...
Old Aug 12, 2014 | 03:33 PM
  #276
dropzone's Avatar
Fossilized
definitely get a long spline front d/s..
worth it to prevent it from coming undone and causing a major headache..
Old Aug 12, 2014 | 08:12 PM
  #277
Red Wagon's Avatar
Nice and clean looking swap. Good work.
Old Aug 12, 2014 | 09:53 PM
  #278
Red Wagon's Avatar
What's the deal with the shackles? I've not seen that before.
Is that a mini axle? So an upgrade to the FJ60 rotors on a mini axle if I'm right.
I've got an FJ62 axle waiting to go in. Just have to get some money projects done first.
Old Aug 13, 2014 | 09:11 AM
  #279
85toyman's Avatar
Boomerang shackles just help with movement and wrapping around the body mount so they don't hit during flex...
Yes it is a mini axle. I used IFS hubs and fj60 rotors with a wide axle kit. This pushes the axle out to 58" so I match the rear but I don't have wheel spacers to deal with. Its a very nice look.
Well get that axle under the wagon!!!!!!
Old Aug 13, 2014 | 09:15 AM
  #280
85toyman's Avatar
I cut the pinch weld area. Thinking about tubing it out, we will see.... I also took the chrome trim around the wheel arches off as well and the rear mud flaps as the tires were hitting during full stuff.
Whats everybody think? Should I put the trim back on or leave it off?
