3vze Fuel Injector Rebuid Kits
Old May 17, 2014 | 01:36 PM
Marcheetah's Avatar
Smile 3vze Fuel Injector Rebuid Kits
While I am replacing my HG, blown #6, I decided it to be prudent to go ahead and "rebuild" the injectors. I am looking around to see if anyone can guide me to a decent kit to do so AND just how difficult is it?
The way I figure if I could get the PITA crossover nuts off with out loosing my mind OR breaking them I surely should be able to handle the injectors.
OR should I just leave them alone? I did loosen the fuel rails and I am hoping it did not compromise the already tired yet fully functioning injectors.
Thank you and This site has so far saved my bacon on this HG project!
At least until I can to a 3.4 swap which ain't too soon!
Old May 17, 2014 | 04:46 PM
rworegon's Avatar
I highly recommend just sending the injectors out to www.witchhunter.com and they will test, clean, and rebuild them for $22 per injector plus a bit of shipping.
You may have a company more local to you that provides a similar service.
Old May 18, 2014 | 03:37 AM
Marcheetah's Avatar
R,
Thank you for the fast reply and the good advice. I had thought about doing just that but being broke as a joke I am looking to either do it myself. Hey, can I get by with just replacing the tiny o rings between the actual injector and the rail? If so I am thinking rockauto.com? Thoughts?
Thanks again.
M
Old May 18, 2014 | 06:21 AM
rworegon's Avatar
Yes, at a minimum, I'd replace the O-rings, seals, and insulators i.e. the rubber bits on each injector. As for cleaning the tips, soaking them in carb cleaner might be an option.
smthwsn357
May 1, 2024 07:28 AM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
karbin
Jul 5, 2015 11:37 PM
