22RE Head-ache! Opinions
Old Aug 28, 2013 | 11:36 AM
jakeasinsnake's Avatar
Recently pulled the head on my 93 pickup. Found this. What do you guys and gals think?
Old Aug 28, 2013 | 11:47 AM
Note the chewed up aluminum at about 11 o'clock
Old Aug 28, 2013 | 11:48 AM
john22rebuilder's Avatar
I see now that looks pretty chewed how does cylnder walls look? Could it be from a broke ring? Isnt that where the pistion almost makes contact with head or is it more like corrosion at the gasket contact area?
Old Aug 28, 2013 | 12:04 PM
The walls look pretty good. Weird thing is the head gasket doesn't seem to have sustained damage to that particular area...I'm wondering if a machine shop will just shake their heads and send me on my way?
Old Aug 28, 2013 | 12:20 PM
yotie's Avatar
what was the reason for you taking the head off??
Old Aug 28, 2013 | 12:34 PM
derockus's Avatar
deleted
Old Aug 28, 2013 | 12:46 PM
yotie's Avatar
Originally Posted by derockus
SERIOUSLY?!?!! Get outta this guy's thread with this crap. You can't start a CLASSIFIED AD until 15 posts. Regular threads are fine. READ THE RULES. And yes I know what that screw is for.
wow man ...................
Old Aug 28, 2013 | 12:49 PM
Blowing white smoke from the exhaust with bits of what appeared to be gasket.
Old Aug 28, 2013 | 01:00 PM
You might be able to find someone that could fill in the chewed up section and resurface but you might end up paying out after all said and done as much as a reconditioned one would be. You should really take a look at that piston and walls something had to cause that . But then again maybe just file it down slap on a new hg and see how it goes. And hopefully whatever that was blew out the tailpipe. Check the guides under the valves couldhave cracked off. Or even if something foreign was in there.
Old Aug 28, 2013 | 03:42 PM
I appreciate all the help guys. I'll post on the outcome.
crammit442
7
Nov 29, 2017 12:30 PM
matrad
Aug 8, 2015 03:00 PM
bighaydn
Aug 4, 2015 07:17 PM
jbandt
Aug 3, 2015 03:23 PM
A2theK
Jul 12, 2015 10:46 AM
