1UZFE into my 95 runner
Old Mar 31, 2011 | 07:16 AM
  #161
SHAGGY21's Avatar
Well I got my headache yesterday. Thanks again RMA. The poor lady at the post office gave me this devastated look when she saw they were mine. And said something about them being so heavy. But my plans are to have the engine sitting in tonight. I'll post some pictures when I get home.
Old Mar 31, 2011 | 10:05 AM
  #162
Dunkin's Avatar
Hahahaha. I love to let the people complain at the post office. I figure, the more they vent, the less they shoot.
Grats on getting those parts! It always feels great to make progress.
Old Mar 31, 2011 | 10:09 AM
  #163
SHAGGY21's Avatar
Yeah now I just gotta get another set of head gaskets and valve seals
Old Mar 31, 2011 | 08:20 PM
  #164
SHAGGY21's Avatar
Well I didn't get as far as I wanted tonight. I only got the new perches for the motor mounts put on the frame. Turned out real nice. I won't get to touch it tell next Tuesday. So ill put some pics on tomorrow before I go to la junta tomorrow.
Old Mar 31, 2011 | 11:04 PM
  #165
85toyman's Avatar
Cant wait for pics!!!!!
Old Apr 4, 2011 | 05:19 PM
  #166
Datsayota's Avatar
Shaggy,
Did you install the body lift to help reduce clearance issues with the 1uz swap?
Old Apr 4, 2011 | 05:33 PM
  #167
SHAGGY21's Avatar
Yeah. I'm hanging the motor right now and looking at it if I didn't do the lift it wouldn't have worked I think. I went with a 3 inch because it was about 40 bucks less. I'll have pictures up tonight of the engine sitting in and my mounts me an my friend are making. Had to redo the hole setup coz the mounts I got. I think they will be stronger then the 3vz mounts as well.
Old Apr 4, 2011 | 08:07 PM
  #168
SHAGGY21's Avatar
well here it is i got the engine in,
check out my high tech measurement device.
Old Apr 4, 2011 | 08:21 PM
  #169
RMA's Avatar
RMA
those are some big rubbers man ..nice set up .. im gonna try some solid mounts on this 4runner im working on now .. i wanna see what happens .. ill go ahead and make 2 sets one solid and one with the 3.0 rubbers . just in case though .
Old Apr 4, 2011 | 08:22 PM
  #170
SHAGGY21's Avatar
this is befor i picked up the back of the tranny. its right against the firewall.
here is is jacked up.
and there it is in all its glory.
Old Apr 4, 2011 | 08:26 PM
  #171
SHAGGY21's Avatar
i just gotta pull the mounts out one more time to clean up the rough tedges and paint them.
o and dunkin here is a pick for you on the inputshaft it sits just inside the crank.
yeah RMA i liked them because they are almost just like the oe lexus mounts. so i think they will hold up nice. and they are a rubber hydro mount so they will have some play but still be stiff at the same time.
Old Apr 4, 2011 | 08:31 PM
  #172
RMA's Avatar
RMA
yea this engine moves a bit with the 3.0 mounts .. mainly forward .. on both the maroon runner and my black one .. and the maroon runner has all new rubbers tranny and engine. still moves forward id say 1" more or less.
and this is only when slamming on the brakes and gassing it .. honestly not sure if thats supposed to be normal or not , just doesnt look right .
Old Apr 4, 2011 | 08:35 PM
  #173
SHAGGY21's Avatar
yeah it really shouldnt move that much. it may be because the mounts are to soft. ill let you know when i get mine all finished. as long as i have the funds i should have it all finished by june. im hopeing.
Old Apr 4, 2011 | 08:38 PM
  #174
RMA's Avatar
RMA
yea im gonna try the solid mounts ...good luck bro !
Old Apr 4, 2011 | 08:40 PM
  #175
SHAGGY21's Avatar
thanks man. i wish i could work on it all night.
Old Apr 4, 2011 | 09:17 PM
  #176
Dunkin's Avatar
I know the feeling man! Looking great!
I'm curious, why didn't you just use the original Lexus aluminum bracket and rubber mount? Now that I see what you did there, it looks easy...
Thanks for the input shaft pic, that makes me feel better about my spacing. Which flywheel are you using again?
Old Apr 5, 2011 | 04:44 AM
  #177
SHAGGY21's Avatar
It's the 3.0 flywheel.
And I wanted to use the factory engine mounts and perches but Lexus mounts are not cheap. And as for the perches I was going to use them but if u look at the mounts sitting on my box u can see they are not the same as each other. The same part number I just happen to get two that were made by two different suppliers. One of them has shorter studs. It wouldn't fit. So what I did was mimic the angles of the aluminum ones and made them. It all worked in the end kit took a little longer.
Old Apr 5, 2011 | 10:24 PM
  #178
85toyman's Avatar
Sorry, if I already asked this guys. I have so many different things that have come up and I want to cover all my bases.
Does the stock clutch fork fit the ks racing bell housing? I emailed them and asked for measurements of the fork but have not gotten a response. I plan on ordering the kit this weekend and don't want to have to order the whole things since I plan on doing what shaggy has done and using my stock 3.0 flywheel once it is machined and buying the marlin 2100 lb clutch kit. I am thinking this should save me some money as long as the fork fits and I don't need their fork because it has some weird lengh to what not to it.
Old Apr 6, 2011 | 05:45 AM
  #179
SHAGGY21's Avatar
yeah the fork fits with some adjustment to the pivot ball. but the only way you wont save money is if having ur flywheel milled is more then 150 i think because the flywheel on its owne from ks is 170ish
Old Apr 6, 2011 | 05:30 PM
  #180
4.0 Pickup's Avatar
I had my flywheel machined for about 60$ and 2-3 beer cans(I think one was for me). I guess it will depends on is friends/contacts.
