1995 4Runner SR5 4x4 Reliability Build up
Old Jun 23, 2012 | 09:38 AM
  #41
ChefYota4x4's Avatar
Looks great, DD....
Hmmm, might have to relax them bars a lil bit after all, no? Lil bit high in the front? But looks nice and beefy, Sir, ...congratz on getting to drive her again, right?
"I FINALLY CLEAR MY TIRES".......... yep, very cool... but HOW'S IT RIDING? Do tell, yes? hahaha
Old Jun 23, 2012 | 02:12 PM
  #42
Red Wagon's Avatar
I think I'll relax mine too when I get home.
Old Jun 23, 2012 | 02:58 PM
  #43
Amazing how much softer it can ride with even 0.5" relaxed t-bars... let alone 1". If you go too low, it's funny.... it bounces like a LowRider! hahaha.
Old Jun 23, 2012 | 03:00 PM
  #44
I always recommend people lube the lock and adjustment nut up for a day or so.... They have been known to snap right off, on many on here. Also, ...don't forget to lift it off the ground up front to relax them as much as they'll go before cracking that lock nut away.
2- 22mm WRENCHES and a Hammer did the trick for me to break em loose....
Old Jun 23, 2012 | 03:05 PM
  #45
Red Wagon's Avatar
To get .5" how many turns was that?
I hope I can drop mine and still clear my 35's. Mind you I have no problem with trimming and when they sort of did that a bit on their own. Ripped the hell out of the plastic lining in the wheel well. I wonder if I can just take all of it out?
Plus they rub the idler arm at full lock just a little. I think I'll fix the steering stop plate by welding on a small bit of steel. Should clear easy then, like I said they only just rub. The steering stop plate has a groove cut into it from years of wear.
Old Jun 23, 2012 | 10:19 PM
  #46
digitaldisciple's Avatar
Looks great, DD....
Definetly funny stance right now since the camber is off and the front being so high. As far as the ride goes: you can tell the road isnt totally smooth; you feel every bump and twist. I will be dropping them back down to level it out when I get the rear lift on.
Old Jun 23, 2012 | 10:24 PM
  #47
28'' Tires
33'' Tires
33" Tires+ BJ Spacers+ ES 3000+ Torsion Crank
Old Jun 23, 2012 | 10:45 PM
  #48
Can't remember how many turns it was, exactly, SJumper.... Just a few, as I remember. I just kept doing a couple and then measuring, while counting... Then I did the other side to my same count... Then adjusted back or forward to as close to even as I could get... I got within 1/16th of an inch in the end.
Old Jun 24, 2012 | 03:20 AM
  #49
Red Wagon's Avatar
What kind of rims ae those? I really like them. Are they deep enough to stop any rubbing?
Old Jun 24, 2012 | 05:26 PM
  #50
blakefogt's Avatar
lookin good!
Old Jun 24, 2012 | 07:56 PM
  #51
Im not sure but I sure dig em too. The offset is barely enough to keep from rubbing and they are mega wide 10". Kinda thinking about painting the lug face flat black when I do the rocker panels with bedliner.
Originally Posted by blakefogt
lookin good!
Thank you
Old Jun 25, 2012 | 06:10 AM
  #52
Red Wagon's Avatar
My rims are only 15" so I'm stuck with them until I get now rubber which is years away considering I just bought new ones. Plus the missus would have my nuts if I did that now.
I figure at some point I will take them off blast em and get them powder coated.
Old Jun 25, 2012 | 04:15 PM
  #53
My rims are only 15" .....I figure at some point I will take them off blast em and get them powder coated.
Thank god for craigslist, i can have a different set of good mt tires everyday of the week for less than 25% of retail. That would look way clean once ya got em coated. Mine are 15s too but super wide so I like the look and feel of em. My plan is to run 35's on 18's x12.5 after I get my body lift and gearing to 5.29.
Old Jun 26, 2012 | 11:18 PM
  #54
Got my shock adapters today, now for rear lift!
TIP: These adapters are LEGIT! the bonus to them is it makes changing out shocks even easier and it gives you an extra inch of lift
Old Jun 27, 2012 | 03:25 AM
  #55
Red Wagon's Avatar
I hear you. One down side of living up near the arctic is finding deals on anything. Its awesome way up here but finding good second hand stuff or proper sales is a pain. I have been waiting two months to find a matching rim. Even then its not even going to be a perfect match when it does get here.
Mine are American racing and glossy. What the shop can get me is pro comp and flat black. At least the backspacing and style match though.
Old Jun 27, 2012 | 12:10 PM
  #56
Yep, and grab a can of glossy and you're in! I hear that a lot from the Great White Northerners.... "Hard to get stuff, and when I do, it's 'iffy' half the time... and Shipping is a PITA!" that could be tough to deal with at times.. But you'll get there, man
Old Jun 27, 2012 | 12:13 PM
  #57
MaK92-4RnR's Avatar
why shock adapters? why didn't you just buy shocks that work instead of running those sketchy things?
Old Jun 27, 2012 | 09:31 PM
  #58
Ordered the wrong shock style and rather than doing the weeks of shipping back and forth I just ordered the adapters. You should see these things, they are beefy nothing to worry about with these adapters. Also the "correct" shocks are on back order everywhere.
Old Jul 26, 2012 | 12:36 AM
  #59
I can always ship parts for you if you find something ya need (want) From Eugene, Salem, or Portland.
http://eugene.craigslist.org/
Old Jul 26, 2012 | 01:02 AM
  #60
Been 30 days since I posted on here so update time!
Busy at work and have been using this runner as my DD. Runs solid, used it to tow a 5x8 trailer twice, also took it on a 100 mile camping voyage last weekend and it performed solidly. The only flaws are the oil leak continues I cant find the source....(gonna have my ase buddy get hands on with it to see if he can find something) Also from the torsion bars being cranked down so much, squeaky at points. Handles intown and freeway driving just fine, road noise is a bit much from the tires but I really have no issue with it. My Civic's exhaust was more noticeable and annoying.
Have to finish getting the rear springs and shocks on but due to no compressor I have had to wait to finish out the kit. It was payday today so I will be finishing up ordering all my suspension parts this week. There was a newer looking drivers side cv joint when I got the runner. Welp it blew out already so that will be getting replaced.
FINALLY THE COOL INFO
Picked up a set of nerf bars today. They are designed for a single cab Chevy but due to the fact my 4runner is a 2 seater IMO, they were $15 dollars and BRAND NEW I decided that I can make em fit
A major purpose of this vehicle is to serve as my towing rig. Roughly 1/2 ton of equipment before trailer weight.
