1991 ext cab build
Old Dec 15, 2012 | 07:15 AM
  #201
racerflea's Avatar
Woo hoo!!!!
Old Dec 15, 2012 | 07:58 AM
  #202
vang_22re's Avatar
Good luck on the swap!
Old Dec 15, 2012 | 11:00 AM
  #203
Buck&DuckRig's Avatar
Originally Posted by runs-on-4
whats the back spacing on your wheels you shouldnt need anymore lift, my 33s were swampers which are close to a true 33, if you measure your tire there more like 31 or 32 inches tall. never had a problem rubbing with my 4inch bracket lif and blocks in the rear.
try pounding down your pinch welds in the front to give yourself anothe half inch or so
people run 35s with no lift (with some minor tubbing)
i run coopers they are a true 33 also but the BS of the rims is a 3.75 they are 15x10 but im thinking about taking a cut off wheel to the bottom of the finder and then maybe the 2" BJ spacer just for a lil extra i dont think it will make it look bad and i was also looking into those longer skackels for the rear
Old Dec 16, 2012 | 09:03 PM
  #204
vang_22re's Avatar
Are you sure u have a 4 inch lift. With the 15x10 n 3.75 bs you shouldn't even have to worry about rubbing. My buddy runs 15x7 on a 4inch lift n no problem at all.
Old Dec 19, 2012 | 10:03 PM
  #205
runs-on-4's Avatar
3.4 update
starting to pull the 3.0
had to move out of the garage to pull it trucks a bit tall
motor out
(3.4)
bit of slug in the valve covers, brought them down to get steamed cleaned look brand new again
good amount of sludge on the head, anyone think its worth the time and money to get rebuilt or even popped off and cleaned?Name:  34swap2043_zps132c633a.jpg
and i may have broken that coolent tube in the back of the motor where its y's off into a smaller line. anyidea where i can find another one of these?
anyways im not expert by any means on motor and whats good and bad, but any input on what to do with the build up in the valves as pictured and amout of sludge on the heads would be apperciated.
Old Dec 20, 2012 | 06:21 AM
  #206
racerflea's Avatar
Wabbit would be best at this i think.. he just rebuilt a 3.4
Old Dec 24, 2012 | 12:02 AM
  #207
runs-on-4's Avatar
picked up a 5sp ecu today, relocated the dipstick, got the 3.0 pan and pick from the guy i sold it to, forgot to get the baffle... gonna need to fine one. i should have the motor back together soon, wiring is next
Old Dec 24, 2012 | 09:06 AM
  #208
racerflea's Avatar
Why do you need the pan and baffle??
Old Dec 24, 2012 | 12:51 PM
  #209
runs-on-4's Avatar
to clear the highsteer
Old Jan 10, 2013 | 02:05 PM
  #210
Hellvision251's Avatar
How did the swap go? or did you get it finished?
Old Jan 10, 2013 | 03:41 PM
  #211
runs-on-4's Avatar
Motor is in the truck ordered motor mounts but they were the wrong ones. Once I get those ill be ready to wire and fire up
Old Jan 10, 2013 | 07:19 PM
  #212
racerflea's Avatar
Awsome!!
Old Jan 12, 2013 | 08:57 PM
  #213
runs-on-4's Avatar
Got my conversion harness back from vital22re! Time to we this truck back on the road
Old Jan 13, 2013 | 12:44 PM
  #214
vital22re's Avatar
totally a bro
Sooo is the harness in yet? sheeesh slacker...
Old Jan 13, 2013 | 05:40 PM
  #215
racerflea's Avatar
Burn outs are a proper engine break procedure... just saying
Old Jan 15, 2013 | 10:38 AM
  #216
day1977's Avatar
solid axle swap
im wanting to do a solid axle swap on my 91 taco but i dont know where to start can anyone give me some advice.1991 ext cab build-100_0529.jpg
Old Jan 15, 2013 | 11:23 AM
  #217
runs-on-4's Avatar
What do you want to know?
Old Jan 15, 2013 | 01:25 PM
  #218
kornhuskerwizard's Avatar
Nice work!! Youll not no your in the same rig goin from a 3.0 to 3.4.
Old Jan 15, 2013 | 01:30 PM
  #219
day1977's Avatar
thats ok i have a 4bt cummins in it now i hate v6 power i love my diesel.
Old Jan 15, 2013 | 01:36 PM
  #220
day1977's Avatar
how long it will take gears where i can find things you know just basics.
