Sons 85 Toyota build
Old May 14, 2012 | 12:31 PM
Rntduckman's Avatar
We bought this truck about 3 months ago. Got it home and it was 3 quarts low on oil checked it before I bought it and it was full. Had oil all over the bottom of the motor and the valves where making alot of noise now. So took it to a friend of mine and said the motor was toast only had 135lbs of compression in each cyclinder. Said that somebody had put JB weld in the timing cover to cover the leaking oil. So i bought a rebuilt engine from Oregon engine builders and got put in with very few problems. Did alot of work to clean up parts on engine bay and the underneath side of the truck. Now it looks like a brand new truck. I have few questions what year of brake booster, master cyclinder,calipers, and rotors can i put on to make it stop better?
Old May 14, 2012 | 12:33 PM
Rntduckman's Avatar
I hope the pictures turned out okay. First time using photobucket.
Old May 14, 2012 | 01:57 PM
Vang530's Avatar
v6 brake boosters & master cylinders from any v6 4runner/pickup 90+
I don't even have the v6 rotors and calipers in my 85 yet but wow what a difference it made. Brake feel is much better, its a must have IMO.
Old May 14, 2012 | 02:26 PM
85TurboRunner's Avatar
I have an '87 4runner dual diaphragm brake booster and master cylinder.
I also have the v6 minitruck calipers and vented rotors from an fj60.
This thing stops so much better then my old 4runner and I'm running 35" tires.
This is on an '85 extra cab.
Old May 14, 2012 | 11:07 PM
Rntduckman's Avatar
Yes its on 85 xcab. We are struggling to get it ready for his 16th b-day which was last week. We still have alot of things we want to do to it but we can't get them done all at once. But my son thinks we can. Now we have a real bad exhaust leak on the manifold the engine builder thinks that I have a older exhaust manifold. So we have to take it back off now to see if it's the right year that's post to be on there.
Old May 15, 2012 | 02:43 PM
Rntduckman's Avatar
So all that stuff bolts right up to my 85 with no modifications? It was the wrong exhaust manifold put the new one on and no leaks now sounds alot better.
Old May 15, 2012 | 02:53 PM
conquistador's Avatar
some of it bolts right up, some you'll have to tweak a bit
Old May 15, 2012 | 03:06 PM
All my stuff bolted right up.
I forgot to mention I also have the wider IFS rear axle with the larger brake drums.
Old May 15, 2012 | 04:32 PM
Not so you will at the least have to bend one of the brake lines when upgrading the master cylinder
Old May 16, 2012 | 11:20 AM
Rntduckman's Avatar
Did anybody look at the pictures did they come out?
Old May 16, 2012 | 01:53 PM
Ok yeah I bent some brake lines but it still bolted together without having to cut, weld or fabricate new parts.
I don't see any pictures.
Old May 16, 2012 | 10:47 PM
Rntduckman's Avatar
http://s1263.photobucket.com/albums/ii635/Rntduckman/ Here they are I must of done something wrong. Sorry
Old May 26, 2012 | 12:18 AM
Rntduckman's Avatar
Well got my brake booster,and master cyclinder yesterday got it off a 90 4x4 4runner hope to get it on this weekend. The motor is done and running very strong I only have about 250 miles on it so far. I'll start posting more pics of it this weekend. Thanks for everybodys help I know well need more later on in this project.
Old May 26, 2012 | 05:54 AM
waskillywabbit's Avatar
Go here and read how to post pictures
https://www.yotatech.com/forums/f122/
:wabbit2:
Old Jun 8, 2012 | 04:54 PM
Rntduckman's Avatar
Got all the parts put on the other weekend now it stops on a dime. HopefullyI can get the caliper and rotors put on in the next few weeks. Truck is coming along real good got the first 500 miles put on it and change the oil can't wait to put in royal purple when I hit that 2000 mile mark. I'll see if I can get some new pictures posted this weekend.
Old Jun 8, 2012 | 05:28 PM
91 4Runner's Avatar
Old Jun 8, 2012 | 05:41 PM
Swimmerboy2112's Avatar
I swapped the brakes on my 4Runner with those off a 1995 Toyota T-100 1Ton.
Corax has a good install on them.
Old Jun 14, 2012 | 03:04 PM
toy4rox's Avatar
That truck is almost identical to mine!
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
Colington
Mar 8, 2020 09:51 AM
toyoda8488
Jul 5, 2015 10:18 PM
